24 FRET Bass
Started by brownANDsticky, January 24, 2022, 01:14:57 AM
brownANDsticky
Would a GR55/GK3B work with a 24 EDO bass.
GR-55
Propellerhead Reason  Balance
GK-3 Ibanez AS-200AV
GK-3B on Washburn XB-400
http://chrisvaisvil.com/microtonal-theory-pages/about-24-edo/
I know the amp/effects will, the HRM instrument modeling will, as for the PCM synths, I think so long as the "CHROMATIC" option is switched off, it should work, not 100% sure.
Otherwise the note generator will have to generate the nearest standard tuning note and compensate with pitch bend from there.
brownANDsticky
Thanks for your answer. I kept looking and found discussion on fretless bass here:
https://www.vguitarforums.com/smf/index.php?topic=16564.0.
GR-55
brownANDsticky
And here:
http://chrisvaisvil.com/diy-temporary-cable-tie-guitar-frets-version-2/
Might be a way to test it before committing to a 24 EDO bass spend.
GR-55
I can give the cable-tie thing a go and let you know, but it will be tomorrow.
Meanwhile check out the SY-1000 too, it won't have any issues with microtonal tunings.
