Set Expression Pedal Min and Max value to control Parameter 3 (Depth) via CC#
Started by ghoi88, January 14, 2022, 07:54:35 PM
ghoi88
Looking for help to setup my expression pedal (CC#16) to control Parameter 3 (Depth) in Boss SY-200.
I have turned on "CC In" function and assigned Parameter 3 (Depth) with CC#16. The expression pedal works to change the value of Depth, but only 0 - 100. I will need the Min value to be 50 and Max value at 75.
Any idea ?
Gary
Describe the whole setup?
I assume you have an external MIDI CONTROLER? (AirStep, MIDI Commander, Moningstar?)
That is where you assign the range of the value for MIDI CC#16
SY-200 EXP Pedal Function has Min and Max settings, try adjusting those to your required levels.
ghoi88
Quote from: admin on January 14, 2022, 10:25:02 PM
I have the Old Boss FC-50 MIDI Foot Controller which is not capable of assigning range of parameter. The actual MIDI connection chain is :
FC-50 MIDI Out > Boss GT-1000CORE MIDI IN > GT-1000CORE MIDI Out > Boss SY-200 MIDI IN. The expression pedal is M-Audio EX-P.
ghoi88
Quote from: gumtown on January 14, 2022, 11:06:39 PM
Thanks for the info. However, the info from the manual is only for connection of expression pedal via CTL2/3 jack, not for MIDI CC connection.
Quote from: ghoi88 on January 15, 2022, 06:56:11 AM
Then the  old FC-50 will not be suitable for your needs
An external MIDI SOLUTIONS MIDI PRICESSOR could convert incoming MIDI CC#16 Value 0-127, to value 25-100
Or consider a more robust full featured MIDI Controller. all are listed here
https://www.vguitarforums.com/smf/index.php?board=7.0
