Logic Pro 8 Project Template for MIDI Guitar using Multi MIDI channels.
Started by Elantric-fgn, April 15, 2010, 06:05:02 PM
Elantric-fgn
http://www.guitarhelper.net/Music.html
Here's a Logic Pro 8 Project Template for MIDI Guitars using Multiple Midi channels. This allows the user to play/record 6 plugins on the 6 individual strings, and support individual string bending on each string.
It is a .zip file.
Save it to User/Library/App support/Logic/Project Template
http://www.guitarhelper.net/uploads/axon_multi.logic.zip
Elantric-fgn
Other than create 6 instruments in Logic -- one per midi channel, you also have to separate them. How that is done depends on what version of Logic you're running, how the environment is set, etc etc. The first and most important thing is to select "auto demix by channel", because simply creating an instrument and assign a midi channel does NOT make each instrument respond to a single channel.
This link will give you some extra info:
http://www.logicprohelp.com/viewtopic.php?t=32201
Controlling multiple instruments on different MIDI channels in Logic is easy, and it does not require you to ever open the environment! It also allows you to record different controller keyboards on different software instrument or external MIDI tracks. Whether you're trying to use an external sequencer (like an MPC 2000, or even another computer running Logic) to trigger instruments within Logic, or whether you're simply trying to play different instruments using different MIDI controllers, read on.
merman9393
Elantric, the link you posted above is no longer valid. Could you post an update? I believe I had the templet from that zip file at one time but can no longer find it.
Elantric-fgn
these links were merely reposted here as a courtesy for those who needed it.
observe these were posted three years ago back in 2010.
suggest contact guitarhelper.net for a new link
guitarhelper@optonline.net
http://www.guitarhelper.net/Technology%20home/Technology%20home.html
or here
http://www.logicprohelp.com/forum/viewtopic.php?t=67959
