Midi amp switching
Started by Welshman-fgn, March 25, 2010, 01:57:04 PM
Welshman-fgn
This is actually a spill over from my other thread, but it fits in both here and in the studio section.
Since ordering my G system, I've been looking for ways to use it to switch my Mk V and also the other amp I have yet to decide on.
Apparently, the Mk V doesn't like the switches on the G system as they use a common ground. A visit to the TC support page has led me to the perfect solution to my problem!
http://www.rjmmusic.com/ampgizmo.php
This is a midi switching unit that either has its own relays or a custom made lead that plugs in to your amp and completely replaces your amp's foot pedal. There is another product called the mini amp gizmo that only uses the custom lead.
Either of these products would be the perfect solution to my problem. If I bought the Blackstar s1 100, that has midi switching as standard and I could program the Gizmo to switch the same Mk V channels as the Blackstar which would allow me to easily swap between amps or even use them together in a stereo rig.
rjm have a UK distributor and they even have stock - looks VERY promising.
If you find a cure for GAS let me know!!!!!
MCK-fgn
There was some mention of this gizmo on the TGP thread on Mk V I posted the other day. If you wish to hear more on experience with it you can approach folks who posted there. Looks great to me!
