Fender Mustang Micro
Started by admin, January 12, 2021, 01:54:29 PM
This little headphone unit features a selection of tones found in Fender's Mustang series of amps. it can plug directly into a guitar, and play through a pair of headphones or speakers. Practising to backing tracks is easy too, thanks to its Bluetooth connectivity. In total, there are 12 amp models on-board as well as 13 effects, and an overall adjustable EQ and large, easy-to-use volume control.
It charges via USB, with an estimated runtime of four hours of playing before needing a recharge.
The Mustang Micro lists for $99.99 / £89.99 / €99.99.
[URL unfurl="true"]https://shop.fender.com/en-US/guitar-amplifiers/headphone-amplifiers/mustang-micro/2311300000.html[/URL]
Mustang Micro is a complete personal guitar amplifier featuring a wide selection of tones from the wildly popular Mustang series amps. Plug Mustang Micro directly into your guitar, connect a pair of headphones, and choose your amp and effects. It's ideal for any player from beginner to pro, making it quick and easy to get great tones when jamming silently at home or on the go. And you can play along to your favorite tracks or instructional videos using the built-in Bluetooth audio connection.
FEATURES
All-in-one personal headphone amplifier with onboard DSP
12 amp models from Mustang GTX for a wide range of clean and dirty tones
13 effect models with parameter modify control
Adjustable EQ
Convenient volume control
Bluetooth audio streaming with audio/video sync for playing along in real time
Rechargeable lithium ion battery (charged via USB)
4 hours of continuous play time
Rotating input plug for compatibility with most guitars and basses
USB interface for recording output and firmware updates
HIGHLIGHTS
POWERFUL ON-BOARD DSP
Mustang Micro's self-contained signal processing allows the freedom to play without being tethered to an external device to operate.
12 AMP MODELS
Everything from clean to mean, you can cover any style of music with classic Tweed to modern high gain amp tones.
13 EFFECTS
Enjoy a wide variety of effects including modulation, overdrive, compression, stereo delays and reverbs.
BLUETOOTH STREAMING WITH AUDIO VIDEO SYNC
Jam along to your favorite songs or instructional videos in real time.
270° ROTATING INPUT PLUG
Compatible with virtually all electric guitars and basses.
USB-C
Record out to MAC/PC, update firmware, and recharge the internal battery
Owners Manual
https://www.fmicassets.com/Damroot/Original/10001/OM_2311300000_Mustang_Micro_US.pdf
https://www.thegearpage.net/board/index.php?threads/fender-mustang-micro-headphone-amp.2218100/page-29#post-32373243
stilwel wrote>
QuoteAll of the videos I posted were streaming audio over Bluetooth from my laptop. Most (if not all) were playing backing tracks from Youtube.
The Micro sends both the processed guitar AND the streamed Bluetooth audio to it's headphones and USB-C output jack.
Which is a unique feature somewhat exclusive to Mustang Micro
Compare to NUX Mighty Plug, Bluetooth backing tracks are headphone only -not sent to USB.
This feature alone (sends both the processed guitar AND the streamed Bluetooth audio to it's headphones and USB-C output jack)
makes Mustang Micro very attractive for educators and Youtube content creators
Updated Description
Mustang Micro is a complete personal guitar amplifier featuring a wide selection of tones from the wildly popular Mustang series amps. Plug Mustang Micro directly into your guitar, connect your favorite wired headphones, and choose your perfect amp and effect settings. It's ideal for any player from beginner to pro, making it quick and easy to get great tones when jamming at home or on the go. Mustang Micro's 1/8" stereo headphone out allows the flexibility to use your favorite wired headphones or earbuds and silently play with a responsive touch and feel without annoying latency. Want to jam along with tunes from your music library or favorite streaming service? Mustang Micro supports Bluetooth audio streaming from your mobile device, tablet or computer to Mustang Micro and features automatic Audio/Visual sync, making it a great tool for practicing and learning songs.
And you can even record your favorite guitar tones and the Bluetooth audio stream simultaneously using Mustang Micro's USB-C output. It's the ultimate guitar karaoke machine!
FEATURES
12 amp models for a wide range of clean and dirty tones
12 effect combinations with parameter modify control
Adjustable EQ
Antonuzzo
You kind of sense that they wanted to get this video out first... hence five minutes of chatter and about 15 seconds of actual demo...
Quote from: Quad4, post: 32387402, member: 213812
I see mention of a "audio/video sync" feature.
Is this basically standard Bluetooth audio pairing or is there some other magic going on?
Mustang Micro employs Bluetooth 5.0 APTx Low Latency ( 40ms) receiver - but you must have a Bluetooth 5.0 APTx Low Latency ( 40ms)  Transmitter ( new iPad Pro) or this adapter ( amazon $35)
ELEGIANT  BTI-066
Bluetooth 5.0 Transmitter Receiver Wireless Audio Adapter Low Latency
https://www.amazon.com/dp/B07V3F3ZCZ/ref=emc_b_5_t
https://www.aptx.com/aptx-low-latency
More detail on enabling Youtube Audio / Video Sync with Chromebooks
https://chrome.google.com/webstore/detail/youtube-audiovideo-sync/mknmhikmjljhpccebpnplhicmcfjkgbk?hl=en
There is always a delay when streaming audio from your device to a receiver (Apple TV, AirPlay speakers, Sonos, Network Player, TuneBlade, Bluetooth, etc.). This is not a big issue when streaming music but any video will become out of sync. This Chrome Extension attempts to solve this problem for YouTube.
The extension allows adjusting to a positive delay as well as a negative one making it possible also to correct any YouTube video that has been uploaded out of sync.
One time set up:
- Play a YouTube video
- Click on the YouTube Audio/Video Sync icon in the YouTube player (next to the player's Settings button)
- Use the + and - buttons or click on the delay value and edit it directly.
Elmo hates it- which in my world means I like it so it must be good ;)
firmware update available for Mustang Micro users.
http://fender.com/mmfirmware
Release Notes:
Version 1.0.54 May 27, 2021
Minor tonal improvements to Spring Reverb, Hall Reverb, 2290 Delay
Minor tonal improvements to BB-15, FBE-100
Increased volume for '65 Deluxe + Greenbox OD Amp setting
Improved USB recording level by disconnecting it from the master volume
Revised tone control to NOT affect Bluetooth audio
Other bug fixes and enhancements
