AMT U-2 Pangaea Ultima Brain Frame
Started by donaldduck, September 01, 2020, 03:23:48 AM
donaldduck
https://amtelectronics.com/new/start-of-sales-amt-ultima-u-2/
https://amtelectronics.com/new/amt-pangaea-ultima-u2/
(not just a pedal IR loader, it has preamp, reverb and more).
It is possible to load different firmwares with different functions/effects (see below).
When (if?) they add a tuner it will be all-in-one my swiss army knife pedal.
01 – IR CabSim Fx
The main firmware that comes with the device by default.
A feature is an analog-digital preamp section with three channels: clean, low & high gain.
    Noise Gate (global setting)
    Compressor
    Analog Preamp (Clean / Low gain / High gain)
    Power Amp (9 types)
    IR cabsim (1 IR for both L/R channels per preset)
    Parametric Pre/Post EQ
    Hi/Low pass filters + Presence
    Delay or Reverb effect per preset
    + other features
02 – Modulation FX
The firmware that turns "Ultima" into an effects processor is designed for the case when your Pedalboard, which already has preamp/distortion pedals, requires expanding the sound palette due to various modulation effects.
    Compressor
    Resonance Filter (wah-wah etc.)
    Flanger
    Chorus
    Delay
    Tremolo
    + other features
03 – IR Stereo CabSim
The firmware that turns the device into a powerful stereo IR impulse responses cabinet emulator.
    IR Stereo cabsim (2 IR's per preset: the first wav IR for the LEFT channel, another one wav IR – for the RIGHT channel)
04 – Stereo Delay
Multifunctional STEREO IN/OUT Delay effect.
05 – Stereo Reverb
Multifunctional STEREO IN/OUT Reverb with the following types:
    Gold Reverb
    Hall
    Room
    Plate
    Spring
    Gate
    Reverse
06 – Pre/Post FX
The firmware that turns the Ultima U-2 device to the PRE / POST effect processor.
PRE section:
    Compressor
    Phaser
    Flanger
POST section:
    + other features
SPECIFICATIONS
IN L, IN R – Inputs of the Left and Right channels:
– input impedance 470 kОм
– rated input voltage of audio signal 0.316Vrms (-10dBV)
– maximum sinusoidal voltage 2.5V (+8dBV)
AUX IN
– Input impedance 2kOhm
– maximum sinusoidal voltage 0.85V (-1.4dBV)
OUT L, OUT_R – Outputs of the Left and Right channels:
– output impedance 1,5kOhm (unbalanced output)
– maximum sinusoidal voltage 2,6V (unbalanced output)
– phantom power protection – present
PHONES – Output to headphones:
– minimum headphone impedance 32 Ohm
– maximum output sinusoidal voltage (no load) 2,6V (8dBV)
– output impedance 12 Ohm
POWER
– Voltage DC 12V
– Current consumption Approx. 300mA
CHARACTERISTICS OF IR FILES
– Type: WAV, IR A/D – D/A converters 24 bit
– Sampling frequency: 48 kHz
– IR length: 1024 samples (21.3 msec)
– S/N: 115dB.
– Latency: 1.2 ms / 0.0012 s
– Codec: AD\DA AK4621
DIMENSION (HxWxD) 47mm x 55mm x 95mm
WEIGHT 270 g (without package)
