Fixed: Any thoughts on why a GK internal D string goes quiet after a while?
Started by Bendy, August 09, 2020, 01:45:32 PM
Bendy
Hi
So it all starts ok but sometimes just the D string goes quiet. Still sounds but volume down by maybe 70% so very noticeable. Other strings fine
If I leave it for a while unplugged it comes back ok, but will go again.
Any thoughts?
Do you think i need to replace?
Thanks Guys
Piter
There can be a multitude of reasons why this happens.
The GK cable is a good place to start the process of elimination.
DeOxit spray is recommended to clean the GK cable pins and GK socket pins.
What type of GK unit are you plugging into?
If it is an old unit like the GR1, GR-30, GR-33,
has the internal memory battery been replaced ?
Tried a different GK cable ?
As gumtown suggests...
Read this thread in detail...
...this is the best and quickest way to start diagnosing the problem.
HTH
Peter
Bendy
Quote from: Piter on August 09, 2020, 04:55:01 PM
I got reed of similar problem by replacing 13-pin cable.
Yeah tried that no joy, but thanks :-)
What hardware are you using, and what brand (standard of) cable ??
Have you / Can you try your guitar with another synth?    ...or another guitar with your synth?
Bendy
Quote from: gumtown on August 09, 2020, 05:36:20 PM
OK thanks for the info.
Pickups - GK-2 (working fine on both units) Internal Gk3 (built in pickup) that is showing the problem
Units - I have a GP-10 main unit and a GR-30 (not used much)
The fault is displayed on both units only with the internal pickup. I have 3 13pin cables and again its just the one pickup.
Ta
Bendy
Quote from: gumbo on August 10, 2020, 03:21:10 AM
HTH
Peter
Thanks Peter looks good
Bendy
I did a bit more testing
I use  the GP10 and this blends the real pickups and the HEX ones on a lot of the patches. I have found that the the hex pickup is always quiet on the D and and it is only on the HEX only patches that the D goes quiet.
I think that the pickup may be shot
Also, check and clean (if you are confident of your skills) the connections from the pickup to the mainboard, and those from the mainboard to the 13-pin jack.
Assuming you are using the Roland 13-pin jack that came with the Internal Kit, also check and clean the connections at the JACK end of the cabling that goes from the mainboard to the jack..
HTH
Peter
Bendy
Quote from:  Bluesbird on August 10, 2020, 07:11:08 AM
If it is always quiet on the D string, then maybe there is more space between the string and the pickup than the other strings.  Increase the sensitivity for the D string.
The distance thing is a good idea, I will try that.
The sensitivity thing is less appealing, i would rather replace as i have multiple GK's
Bendy
Quote from: gumbo on August 10, 2020, 06:07:01 AM
I have 3 cables that came with the gear, I have two BOSS units, and 2 GK pickups on different guitars. By a process of elimination  its the pickup that exhibits the issue.
Thanks Mate :-)
Bendy
Quote from: gumbo on August 10, 2020, 05:32:27 PM
HTH
Peter
That's a good call, I am fairly good with that stuff so i will get my screwdriver out today. I may even try swapping the pickup with my other GK see if the issue moves with the swap.
Bendy
OK Fixed thanks to @gumbo !!!!!
:) ;D >:(
So I disconnected, cleaned, and then reseated the pickup connector to the main board and the thing is now perfect!!
Thanks guys one happy guy and a friendly and helpful forum.
Now to get back to playing
