ROLAND FC-300 SYSEX Mode for HX STOMP (MIDI Designer Pro 2 Layout)
Started by Ed_Saxman, May 24, 2020, 09:01:18 AM
Ed_Saxman
Wouldn't it be wonderful if our HX Stomp had a dedicated professional, gig worthy, Plug & Play controller, where you don't have to program anything?
What if it could also work with batteries, and... wirelessly?
Better with a large touch screen as H.U.D?
ROLAND FC-300 SYSEX MODE For HX STOMP
https://gum.co/AnHuek
Version 1.0 (5 Presets)
Preset Mode:
Stomp Mode:
iPad Main view
Looper controls
This is a MIDI Layout Made to work with MIDI Designer Pro 2 (sold separately).
Allows to use a Roland FC-300 MIDI pedalboard with the Line 6 HX STOMP, using SYSEX messages to control all the onboard LEDs, expression pedals and footswitches.
Plug & Play. No config needed.
Partially Wireless!! Plug your FC-300+iPad together, then control your HX Stomp Wirelessly!
Requires some aditional hardware. Please read carefully the following requeriment list.
Requeriments:
- Line 6 HX STOMP
- Apple iPad + MIDI Designer 2 + this MIDI Layout
- Roland FC-300
- Roland UM-ONE MIDI Interface
- Yamaha MD-BT01 Wireless MIDI Interface
- Apple Lightning to USB 3.0 camera adapter
Making connections:
-Connnect the Roland UM-ONE MIDI DINs (In, Out) to the Roland FC-300, then plug the USB to the Apple Lighning to USB 3.0 camera adapter, plugged to your Ipad.
- Plug the Yamaha MD-BT01 to your HX Stomp, then connect Wirelessy once in MIDI Designer Pro 2
Features:
- Premapped SYSEX Mode to make both devices work seamlessly together.
- Offers control over five preset on the FX STOMP (1 to 5)
- Expression Pedals with real-time movement on the iPad screen.
-Bypass and Tuner functions assigned to the Footswitches under the Exp pedals (including On/Off LEDs)
- 3 FS assigned to Snapshots (One LED active)
- One FS to Switch Stomp and Preset Modes, that also works as Tap Tempo.
- 5 FS (lower row on the FC-300) with double function: single press to turn On/Off effects, Long Press to change presets 1-5
- Looper Controls onscreen
- Control over the FC-300 screen brightness and ECO mode.
Version 1.0 - Released 24-MAY-2020
Future versions may include additional features. All updates will be free of charge for current costumers.
