SY-1000 - FAQ
Started by admin, December 12, 2019, 11:37:46 AM
QuoteSo I was looking through the manual and stuff but I'm half asleep and about to go to bed but where can I find the section about changing each string to whatever sound I want etc
Each INST has a STR LEVEL (and PAN) parameter. Adjust STR LEVEL to zero at the strings that you don't want to assign that sound, and voila!
THIS is how its done
Quote from: jozart on February 06, 2020, 12:57:28 AM
I was looking at some GT-1000 programming tutorials and noticed how its (measly) looper was used to loop a short strumming sample while the patch maestro tweaked the settings. What's the best way to emulate this time saving technique on the SY-1000?
Use a Win/Mac computer and SY-1000 USB Driver
then record 6 tracks of dry guitar into a DAW
then rewind  and loop those dry guitar tracks
then feedback into the SY-1000 via USB "RE-SYNTH" modes, and tweak / build new SY-1000 patches
SY-1000 USB Driver has an important "README.HTM" file you must read  inside the download zip  file)
Audio input/output device
Of the total audio input/output channels provided by the SY-1000, there are 8 INs and 8 OUTs
[WAVE OUT Devices]
OUT (SY-1000)
GK 1-2 (SY-1000)  = High E & B String
GK 3-4 (SY-1000)  = G & D String
GK 5-6 (SY-1000)  = A & Low E String
*   If you've specified a different name in the "Sound" settings of the Control Panel, the name you specified will be displayed.
[WAVE IN Devices]
IN (SY-1000)
QuoteIDK -if the GK S1, S2 Controls  can be disabled. I find them useful for the SY-1000. I really like being able to scroll presets with my fingers rather than my fumbling feet.
You may Remap your onboard Guitar GK Controls as desired
Even remap GK S1, S2 Momentary Switches change the current INST "E-Guitar PU Selection
Tuner Activate OPTIONS
Press both Bank Up / Bank Down Footswitches
Assign an  Expression Pedal to activate the Tuner when in the Heel Down position
The SY-1000 features a CONTROL FUNCTION for "CUR NUM" which means the current Patch Number Foot switch can Toggle between the Current Patch or Manual Mode or Tuner Mode  - depending on how long the Current Patch Number foot switch is held down
( ^typo on the description )
Manual Control  mode and bottom three left footswitches  toggle on off INST1, INST2, INST3
There are user definable configurations for Switch 1,2,3,4 in MANUAL MODE
Enable  Momentary mode for each bottom 4 foot switches (INST1,INST2,INST1,NRML
Boss SY-1000 MIDI Implementation
https://static.roland.com/assets/media/pdf/SY-1000_MIDI_Implementation.pdf
See page 13
"00 34 | 0000 000a | Manual Num1 Mode (0 - 1) |
| | | TOGGLE, MOMENT "
00 36 | 0000 000a | Manual Num2 Mode (0 - 1) |
| | | TOGGLE, MOMENT |
00 38 | 0000 000a | Manual Num3 Mode (0 - 1) |
| | | TOGGLE, MOMENT
ASSIGN FOOT SWITCHES
Set the Control Mode to manual. Then go into the assigns and assign Inst 1 min state off, max state On to a ctl/num switch. Make the same assignment to the other instrument you wish to control but reverse the min state and max state.
Choose which active input to use when creating patches
GK 13 pin input
or
1/4" Guitar Input
Go to MASTER block at End and Toggle "Change Patch Type"
Quote from: gearhound22 on February 12, 2020, 02:14:56 PM
Where exactly does the FX loop sit in the chain? Took a read thru the manual but didn't seem to indicate where.
You can move FX S/R loop as desired within the FX BLOCK
Boss SY-1000 F.A.Q.
https://www.vguitarforums.com/smf/index.php?topic=26924.0
Quote from: stub on February 14, 2020, 03:19:17 PM
Maybe partially on-topic, I'll use this little expression pedal for the missing built-in pedal. I also have a cool dual footswitch that I modded so that there are both toggle and momentary switches that work together---
TOGGLE ON, MOMENTARY OFF's
TOGGLE OFF, MOMENTARY ON's
Unfortunately I didn't have the kind of switches where I could hook up some LEDs, so it's kind of a crap shoot to know the switch states.
External CTL Pedals
https://www.vguitarforums.com/smf/index.php?topic=7952.0
Which Footswitch do I need? .. Latch or Unlatch?
SY-1000 Control Assign  [toggle] + FS-7 / FS-6  [Latch] = double latching, pedal requires 2 presses to do one function (effect on/off)
SY-1000 Control Assign  [toggle] + FS-7/FS-6  [Moment] = press once to toggle effect on/off, pedal led only lights while held down
SY-1000 Control Assign  [moment] + FS-7/FS-6  [moment] = effect only on while pedal held down, pedal led only on while held down
SY-1000 Control Assign  [moment] + FS-7/FS-6  [Latch] = press once to toggle effect on/off, pedal led toggles with effect status
Quote from: tjontheroad on February 15, 2020, 02:14:40 PM
Anyone noticed this bug with the Dynamic Synth sequencer? The sequencer runs double speed when you clock sync it via USB. That is, if you set the sequence rate at run at a 1/4 note, it'll play at an 1/8 note when clock sync'd. Turn off the sync and it'll return to the correct setting.
Edit; I just verified this issue also effects the LFOs with external clock sync'd.
Review the SY-1000 USB Driver file README.htm file
( MUST READ)
https://www.vguitarforums.com/smf/index.php?topic=27182.0
Please select the following device in your MIDI compatible application.
[MIDI OUT devices]
SY-1000
SY-1000 DAW CTRL
[MIDI IN devices]
SY-1000
SY-1000 DAW CTRL
Problems arise if you assign MIDI CLOCK to more than one SY-1000 MIDI Device
Why wont SY-1000 USB 64 bit Core Audio  / MIDI Driver work on my macOS10.14 / macOS10.15?
Boss Support wrote>
SY-1000 USB MIDI trouble caused by interference by 3rd party USB MIDI driver.
To meet security requirement for mac OS 10.14, our USB MIDI Driver works only for 64bit MIDI Server.
If you use 32bit USB MIDI Driver, MIDI Server works as 32bit and USB MIDI for SY-1000 doesn't work.
For your information, your MIDI Server was boot as 32bit.
Roland/BOSS USB drivers you installed to your Mac work as 64bit.
But some 3rd party USB Driver works as 32bit and make interference to our USB MIDI Driver.
If you could uninstall all of 32bit MIDI driver, your MIDI Server works as 64bit, SY-1000 USB MIDI works.
SY-1000 - USB Driver
https://www.vguitarforums.com/smf/index.php?topic=27182.msg199090#msg199090
Solve SY-1000 Win 10 USB Driver installation problem
Contact RolandUS Guitar Product Support @ Zendesk
https://rolandus.zendesk.com/hc/en-us/sections/200467249-Knowledge-Base
The Roland Zendesk support sent me a zipped driver for Windows 10 and the SY-1000
It at least loads now!
https://rolandus.zendesk.com/hc/en-us/requests/new
Be sure you have checked out the NORMAL INPUT Settings
PHASE is a crucial parameter when mixing the 1/"4 Normal Input signal with the GK Input INST blocks
When All inputs are active, Toggle the NORMAL INPUT PHASE  and set for best sound
and check out the CABLE SIM,
QuoteQuote
Aaron Marino A: very subtle, but Cable SIM(on) = 12M/40FT = Darker tone
when compared to Cable SIM = OFF
THANK YOU!
So in a practical application, many old Blues artists ( Buddy Guy) used to perform with a 100 foot guitar cable and go off stage into the crowd during solos. The Long Cable Length with its higher capacitance became part of his guitar tone , attenuating high frequencies, and delivering a rounder full bodied tone
the SY-1000 Cable Sim replicates this effect.
2. Cable Sim
So, I wasn't happy with the sound I was getting out of the NORMAL path with my guitars. Everything was sounding dark and muffled to me and I just wasn't getting the clarity and depth I expect. Sounded like an old school digital amp.
I discovered this was all being caused by the cable sim at the input! I turned it off and instantly everything came to life and sounded 1000% better!
Seriously, I don't know why they default it to being on because it makes everything sound so much darker and muffled.
After turning it off, I'm really getting a lot happier with the electric guitar tones.
Quote from: gtlist on February 22, 2020, 12:51:33 PM
By the way, Is there any way to set the key during the live gig ?  I really need to change the key not by hand with bending my back. but use my foot ( foot control). but I can't find the solution. in
GP-10 has no problem.
Is this a bug?
Buried in the MASTER section is
1 MASTER BPM
2 MASTER KEY
3 MASTER PATCH LEVEL
AFAIK - MASTER KEY also impacts the Guitar to MIDI output too ( just as it did on GR-55, VG-99)
All above can be  Controlled by MIDI CC# as  Assignment targets too.
(see Page 66)
SY-1000 REFERENCE MANUAL (01)
https://static.roland.com/assets/media/pdf/SY-1000_reference_eng01_W.pdf
Each of the Knobs under the LCD display may be mapped to specific user functions on each patch
* TABLE 1 : KNOB SETTING TABLE FOR GUITAR MODE
# CATEGORY                   TARGET
0 PATCH                           PATCH SELECT
1 TUNER                           ON/OFF
2 MASTER                         BPM
3 MASTER                         KEY
4 MASTER                         PATCH LEVEL
5 CONTROL MODE             CONTROL MODE
6 INPUT SETTING              GK SET
7 INPUT SETTING              NORMAL SET
8 OUTPUT SETTING            MAIN OUTPUT-L LEVEL
9 OUTPUT SETTING            MAIN OUTPUT-R LEVEL
10 OUTPUT SETTING          MAIN OUTPUT-L SELECT
11 OUTPUT SETTING          MAIN OUTPUT-R SELECT
12 OUTPUT SETTING          SUB OUTPUT-L LEVEL
13 OUTPUT SETTING          SUB OUTPUT-R LEVEL
14 OUTPUT SETTING          SUB OUTPUT-L SELECT
15 OUTPUT SETTING          SUB OUTPUT-R SELECT
16 TOTAL                          TOTAL REVERB LEVEL
17 TOTAL                          TOTAL NS THRESHOLD
18 MAIN GLOBAL EQ L/S    LOW CUT
19 MAIN GLOBAL EQ L/S    LOW GAIN
20 MAIN GLOBAL EQ L/S    LOW-MID FREQ
21 MAIN GLOBAL EQ L/S    LOW-MID Q
22 MAIN GLOBAL EQ L/S    LOW-MID GAIN
23 MAIN GLOBAL EQ L/S    HIGH-MID FREQ
24 MAIN GLOBAL EQ L/S    HIGH-MID Q
25 MAIN GLOBAL EQ L/S    HIGH-MID GAIN
26 MAIN GLOBAL EQ L/S    HIGH GAIN
27 MAIN GLOBAL EQ L/S    HIGH CUT
28 MAIN GLOBAL EQ R       LOW CUT
29 MAIN GLOBAL EQ R       LOW GAIN
30 MAIN GLOBAL EQ R       LOW MID FREQ
31 MAIN GLOBAL EQ R       LOW MID Q
32 MAIN GLOBAL EQ R       LOW MID GAIN
33 MAIN GLOBAL EQ R       HIGH MID FREQ
34 MAIN GLOBAL EQ R       HIGH-MID Q
35 MAIN GLOBAL EQ R       HIGH-MID GAIN
36 MAIN GLOBAL EQ R       HIGH GAIN
37 MAIN GLOBAL EQ R       HIGH CUT
38 SUB GLOBAL EQ L/S      LOW CUT
39 SUB GLOBAL EQ L/S      LOW GAIN
40 SUB GLOBAL EQ L/S      LOW-MID FREQ
41 SUB GLOBAL EQ L/S      LOW-MID Q
42 SUB GLOBAL EQ L/S      LOW-MID GAIN
43 SUB GLOBAL EQ L/S      HIGH-MID FREQ
44 SUB GLOBAL EQ L/S      HIGH-MID Q
45 SUB GLOBAL EQ L/S      HIGH-MID GAIN
46 SUB GLOBAL EQ L/S      HIGH GAIN
47 SUB GLOBAL EQ L/S      HIGH CUT
48 SUB GLOBAL EQ R         LOW CUT
49 SUB GLOBAL EQ R         LOW GAIN
50 SUB GLOBAL EQ R         LOW-MID FREQ
51 SUB GLOBAL EQ R         LOW-MID Q
52 SUB GLOBAL EQ R         LOW-MID GAIN
53 SUB GLOBAL EQ R         HIGH-MID FREQ
54 SUB GLOBAL EQ R         HIGH-MID Q
55 SUB GLOBAL EQ R         HIGH-MID GAIN
56 SUB GLOBAL EQ R         HIGH GAIN
57 SUB GLOBAL EQ R         HIGH CUT
58 USB AUDIO MAIN          MIX LEVEL
59 USB AUDIO SUB           MIX LEVEL
60 USB AUDIO IN             LEVEL
61 USB AUDIO OUT          LEVEL
62 USB AUDIO USB          AUDIO ROUTING
63 USB AUDIO USB          IN POSITION
64 USB AUDIO USB         OUT POSITION
65 GUITAR TO MIDI        GUITAR TO MIDI SW
* TABLE 5 : ASSIGN TARGET TABLE FOR GUITAR MODE
# CATEGORY TARGET
0 TUNER ON/OFF
1 MASTER BPM
2 MASTER KEY
4 TAP BPM TAP
5 TAP DLY1 TAP
6 TAP DLY2 TAP
7 TAP MST DLY TAP
8 TAP FX1 DLY TAP
9 TAP FX2 DLY TAP
10 TAP FX3 DLY TAP
11 INST1 ON/OFF
12 INST1 TYPE
13 INST1 LEVEL
14 INST1 NOR MIX SW
15 INST1 NOR MIX LEVEL
16 INST1 STRING LEVEL 6
17 INST1 STRING LEVEL 5
18 INST1 STRING LEVEL 4
19 INST1 STRING LEVEL 3
20 INST1 STRING LEVEL 2
21 INST1 STRING LEVEL 1
22 INST1 STRING PAN 6
23 INST1 STRING PAN 5
24 INST1 STRING PAN 4
25 INST1 STRING PAN 3
26 INST1 STRING PAN 2
27 INST1 STRING PAN 1
28 INST1:ALT TUNE ON/OFF
29 INST1:ALT TUNE TUNING TYPE
30 INST1:ALT TUNE PITCH 6
31 INST1:ALT TUNE PITCH 5
32 INST1:ALT TUNE PITCH 4
33 INST1:ALT TUNE PITCH 3
34 INST1:ALT TUNE PITCH 2
35 INST1:ALT TUNE PITCH 1
36 INST1:ALT TUNE FINE 6
37 INST1:ALT TUNE FINE 5
38 INST1:ALT TUNE FINE 4
39 INST1:ALT TUNE FINE 3
40 INST1:ALT TUNE FINE 2
41 INST1:ALT TUNE FINE 1
42 INST1:ALT TUNE 12STR SW
43 INST1:ALT TUNE 12STR TYPE
44 INST1:ALT TUNE 12STR PITCH 6
45 INST1:ALT TUNE 12STR PITCH 5
46 INST1:ALT TUNE 12STR PITCH 4
47 INST1:ALT TUNE 12STR PITCH 3
48 INST1:ALT TUNE 12STR PITCH 2
49 INST1:ALT TUNE 12STR PITCH 1
50 INST1:ALT TUNE 12STR FINE 6
51 INST1:ALT TUNE 12STR FINE 5
52 INST1:ALT TUNE 12STR FINE 4
53 INST1:ALT TUNE 12STR FINE 3
54 INST1:ALT TUNE 12STR FINE 2
55 INST1:ALT TUNE 12STR FINE 1
56 INST1:ALT TUNE 12STR LEVEL 6
57 INST1:ALT TUNE 12STR LEVEL 5
58 INST1:ALT TUNE 12STR LEVEL 4
59 INST1:ALT TUNE 12STR LEVEL 3
60 INST1:ALT TUNE 12STR LEVEL 2
61 INST1:ALT TUNE 12STR LEVEL 1
62 INST1:ALT TUNE 12STR DELAY 6
63 INST1:ALT TUNE 12STR DELAY 5
64 INST1:ALT TUNE 12STR DELAY 4
65 INST1:ALT TUNE 12STR DELAY 3
66 INST1:ALT TUNE 12STR DELAY 2
67 INST1:ALT TUNE 12STR DELAY 1
68 INST1:ALT TUNE STR BEND SW
69 INST1:ALT TUNE BEND DEPTH 6
70 INST1:ALT TUNE BEND DEPTH 5
71 INST1:ALT TUNE BEND DEPTH 4
72 INST1:ALT TUNE BEND DEPTH 3
73 INST1:ALT TUNE BEND DEPTH 2
74 INST1:ALT TUNE BEND DEPTH 1
75 INST1:ALT TUNE BEND CONTROL
76 INST1:DYNAMIC SYNTH:OSC WAVEFORM
77 INST1:DYNAMIC SYNTH:OSC PITCH
78 INST1:DYNAMIC SYNTH:OSC FINE
79 INST1:DYNAMIC SYNTH:OSC PULSE WIDTH
80 INST1:DYNAMIC SYNTH:OSC PWM ENV ATTACK
81 INST1:DYNAMIC SYNTH:OSC PWM ENV DEPTH
82 INST1:DYNAMIC SYNTH:OSC DETUNE
83 INST1:DYNAMIC SYNTH:OSC SHARPNESS
84 INST1:DYNAMIC SYNTH:OSC FEEDBACK
85 INST1:DYNAMIC SYNTH:OSC HARMONICS
86 INST1:DYNAMIC SYNTH:OSC S-SAW DETUNE
87 INST1:DYNAMIC SYNTH:OSC P. ENV ATTACK
88 INST1:DYNAMIC SYNTH:OSC P. ENV DEPTH
89 INST1:DYNAMIC SYNTH:OSC P. BEND DEPTH
90 INST1:DYNAMIC SYNTH:OSC P. BEND CTL
91 (RESERVED)
92 INST1:DYNAMIC SYNTH:FILTER ON/OFF
93 INST1:DYNAMIC SYNTH:FILTER TYPE
94 INST1:DYNAMIC SYNTH:FILTER SLOPE
95 INST1:DYNAMIC SYNTH:FILTER CUTOFF
96 INST1:DYNAMIC SYNTH:FILTER RESONANCE
97 INST1:DYNAMIC SYNTH:FILTER F. ENV ATTACK
98 INST1:DYNAMIC SYNTH:FILTER F. ENV DEPTH
99 INST1:DYNAMIC SYNTH:AMP A. ENV ATTACK
100 INST1:DYNAMIC SYNTH:AMP LOW CUT
101 INST1:DYNAMIC SYNTH:AMP HIGH CUT
102 INST1:DYNAMIC SYNTH:LFO1 ON/OFF
103 INST1:DYNAMIC SYNTH:LFO1 SHAPE
104 INST1:DYNAMIC SYNTH:LFO1 RATE
105 INST1:DYNAMIC SYNTH:LFO1 DYNAMIC DEPTH
106 INST1:DYNAMIC SYNTH:LFO1 PITCH DEPTH
107 INST1:DYNAMIC SYNTH:LFO1 FILTER DEPTH
108 INST1:DYNAMIC SYNTH:LFO1 AMP DEPTH
109 INST1:DYNAMIC SYNTH:LFO1 PWM DEPTH
110 INST1:DYNAMIC SYNTH:LFO1 FADE TIME
111 INST1:DYNAMIC SYNTH:LFO1 SYNC
112 INST1:DYNAMIC SYNTH:LFO2 ON/OFF
113 INST1:DYNAMIC SYNTH:LFO2 SHAPE
114 INST1:DYNAMIC SYNTH:LFO2 RATE
115 INST1:DYNAMIC SYNTH:LFO2 DYNAMIC DEPTH
116 INST1:DYNAMIC SYNTH:LFO2 PITCH DEPTH
117 INST1:DYNAMIC SYNTH:LFO2 FILTER DEPTH
118 INST1:DYNAMIC SYNTH:LFO2 AMP DEPTH
119 INST1:DYNAMIC SYNTH:LFO2 PWM DEPTH
120 INST1:DYNAMIC SYNTH:LFO2 FADE TIME
121 INST1:DYNAMIC SYNTH:LFO2 SYNC
122 INST1:DYNAMIC SYNTH:SEQ COMMON PITCH TARGET
123 INST1:DYNAMIC SYNTH:SEQ COMMON CUTOFF TARGET
124 INST1:DYNAMIC SYNTH:SEQ COMMON LEVEL TARGET
125 INST1:DYNAMIC SYNTH:SEQ1 ON/OFF
126 INST1:DYNAMIC SYNTH:SEQ1 SYNC
127 INST1:DYNAMIC SYNTH:SEQ1 LOOP LENGTH
128 INST1:DYNAMIC SYNTH:SEQ1 RATE
129 INST1:DYNAMIC SYNTH:SEQ1 1 SHOT
130 INST1:DYNAMIC SYNTH:SEQ1 TURBO
131 INST1:DYNAMIC SYNTH:SEQ2 ON/OFF
132 INST1:DYNAMIC SYNTH:SEQ2 SYNC
133 INST1:DYNAMIC SYNTH:SEQ2 LOOP LENGTH
134 INST1:DYNAMIC SYNTH:SEQ2 RATE
135 INST1:DYNAMIC SYNTH:SEQ2 1 SHOT
136 INST1:DYNAMIC SYNTH:SEQ2 TURBO
137 INST1:DYNAMIC SYNTH:LAYER L. FADE
138 INST1:DYNAMIC SYNTH:LAYER LOWER
139 INST1:DYNAMIC SYNTH:LAYER UPPER
140 INST1:DYNAMIC SYNTH:LAYER U. FADE
141 INST1:OSC SYNTH:OSC MODE
142 INST1:OSC SYNTH:OSC WAVEFORM1
143 INST1:OSC SYNTH:OSC PITCH 1
144 INST1:OSC SYNTH:OSC FINE 1
145 INST1:OSC SYNTH:OSC PULSE WIDTH 1
146 INST1:OSC SYNTH:OSC PW MOD RATE 1
147 INST1:OSC SYNTH:OSC P. ENV ATTACK 1
148 INST1:OSC SYNTH:OSC P. ENV DECAY 1
149 INST1:OSC SYNTH:OSC P. ENV DEPTH 1
150 INST1:OSC SYNTH:OSC LEVEL 1
151 INST1:OSC SYNTH:OSC WAVEFORM 2
152 INST1:OSC SYNTH:OSC PITCH 2
153 INST1:OSC SYNTH:OSC FINE 2
154 INST1:OSC SYNTH:OSC PULSE WIDTH 2
155 INST1:OSC SYNTH:OSC PW MOD RATE 2
156 INST1:OSC SYNTH:OSC P. ENV ATTACK 2
157 INST1:OSC SYNTH:OSC P. ENV DECAY 2
158 INST1:OSC SYNTH:OSC P. ENV DEPTH 2
159 INST1:OSC SYNTH:OSC LEVEL 2
160 INST1:OSC SYNTH:OSC MONO/POLY SW
161 INST1:OSC SYNTH:OSC CHROMATIC
162 INST1:OSC SYNTH:OSC PORTA SW
163 INST1:OSC SYNTH:OSC PORTA TIME
164 INST1:OSC SYNTH:OSC PORTA MODE
165 INST1:OSC SYNTH:OSC HOLD MODE
166 INST1:OSC SYNTH:OSC LOW VELO CUT
167 INST1:OSC SYNTH:FILTER ON/OFF
168 INST1:OSC SYNTH:FILTER TYPE
169 INST1:OSC SYNTH:FILTER SLOPE
170 INST1:OSC SYNTH:FILTER CUTOFF
171 INST1:OSC SYNTH:FILTER CUTOFF FOLLOW
172 INST1:OSC SYNTH:FILTER RESONANCE
173 INST1:OSC SYNTH:FILTER VELOCITY SENS
174 INST1:OSC SYNTH:FILTER F. ENV ATTACK
175 INST1:OSC SYNTH:FILTER F. ENV DECAY
176 INST1:OSC SYNTH:FILTER F. ENV SUSTAIN
177 INST1:OSC SYNTH:FILTER F. ENV RELEASE
178 INST1:OSC SYNTH:FILTER F. ENV DEPTH
179 INST1:OSC SYNTH:AMP VELOCITY SENS
180 INST1:OSC SYNTH:AMP A. ENV ATTACK
181 INST1:OSC SYNTH:AMP A. ENV DECAY
182 INST1:OSC SYNTH:AMP A. ENV SUSTAIN
183 INST1:OSC SYNTH:AMP A. ENV RELEASE
184 INST1:OSC SYNTH:AMP LOW CUT
185 INST1:OSC SYNTH:AMP HIGH CUT
186 INST1:OSC SYNTH:LFO1 ON/OFF
187 INST1:OSC SYNTH:LFO1 SHAPE
188 INST1:OSC SYNTH:LFO1 RATE
189 INST1:OSC SYNTH:LFO1 PITCH1 DEPTH
190 INST1:OSC SYNTH:LFO1 PITCH2 DEPTH
191 INST1:OSC SYNTH:LFO1 FILTER DEPTH
192 INST1:OSC SYNTH:LFO1 AMP DEPTH
193 INST1:OSC SYNTH:LFO1 DELAY TIME
194 INST1:OSC SYNTH:LFO1 FADE TIME
195 INST1:OSC SYNTH:LFO1 SYNC
196 INST1:OSC SYNTH:LFO2 ON/OFF
197 INST1:OSC SYNTH:LFO2 SHAPE
198 INST1:OSC SYNTH:LFO2 RATE
199 INST1:OSC SYNTH:LFO2 PITCH1 DEPTH
200 INST1:OSC SYNTH:LFO2 PITCH2 DEPTH
201 INST1:OSC SYNTH:LFO2 FILTER DEPTH
202 INST1:OSC SYNTH:LFO2 AMP DEPTH
203 INST1:OSC SYNTH:LFO2 DELAY TIME
204 INST1:OSC SYNTH:LFO2 FADE TIME
205 INST1:OSC SYNTH:LFO2 SYNC
206 INST1:GR-300 MODE
207 INST1:GR-300 COMP SW
208 INST1:GR-300 CUTOFF
209 INST1:GR-300 RESONANCE
210 INST1:GR-300 ENV MOD SW
211 INST1:GR-300 ENV MOD SENS
212 INST1:GR-300 ENV MOD ATTACK
213 INST1:GR-300 PITCH SW
214 INST1:GR-300 PITCH A
215 INST1:GR-300 FINE A
216 INST1:GR-300 PITCH B
217 INST1:GR-300 FINE B
218 INST1:GR-300 DUET SW
219 INST1:GR-300 SWEEP SW
220 INST1:GR-300 SWEEP RISE
221 INST1:GR-300 SWEEP FALL
222 INST1:GR-300 VIBRATO SW
223 INST1:GR-300 VIBRATO RATE
224 INST1:GR-300 VIBRATO DEPTH
225 INST1:GR-300 LOW CUT
226 INST1:GR-300 HIGH CUT
227 INST1:E.GTR TYPE
228 INST1:E.GTR PU SELECT
229 INST1:E.GTR PU SELECT UP
230 INST1:E.GTR PU SELECT DOWN
231 INST1:E.GTR TONE TYPE
232 INST1:E.GTR SENS
233 INST1:E.GTR DEPTH
234 INST1:E.GTR ATTACK
235 INST1:E.GTR RESONANCE
236 INST1:E.GTR DIRECT LEVEL
237 INST1:E.GTR VOLUME
238 INST1:E.GTR TONE
239 INST1:ACOUSTIC TYPE
240 INST1:ACOUSTIC BODY
241 INST1:ACOUSTIC ATTACK
242 INST1:ACOUSTIC PU SELECT
243 INST1:ACOUSTIC PU SELECT UP
244 INST1:ACOUSTIC PU SELECT DOWN
245 INST1:ACOUSTIC SENS
246 INST1:ACOUSTIC COLOR
247 INST1:ACOUSTIC DECAY
248 INST1:ACOUSTIC BUZZ
249 INST1:ACOUSTIC RESONANCE
250 INST1:ACOUSTIC SUSTAIN
251 INST1:ACOUSTIC VOLUME
252 INST1:ACOUSTIC TONE
253 INST1:E.BASS TYPE
254 INST1:E.BASS REAR VOLUME
255 INST1:E.BASS FRONT VOLUME
256 INST1:E.BASS TONE TYPE
257 INST1:E.BASS SENS
258 INST1:E.BASS DEPTH
259 INST1:E.BASS ATTACK
260 INST1:E.BASS RESONANCE
261 INST1:E.BASS DIRECT LEVEL
262 INST1:E.BASS VOLUME
263 INST1:E.BASS TONE
264 INST1:VIO GUITAR:GUITAR E.GTR TYPE
265 INST1:VIO GUITAR:GUITAR PU SELECT
266 INST1:VIO GUITAR:GUITAR PU SELECT UP
267 INST1:VIO GUITAR:GUITAR PU SELECT DOWN
268 INST1:VIO GUITAR:GUITAR TONE TYPE
269 INST1:VIO GUITAR:GUITAR SENS
270 INST1:VIO GUITAR:GUITAR DEPTH
271 INST1:VIO GUITAR:GUITAR ATTACK
272 INST1:VIO GUITAR:GUITAR RESONANCE
273 INST1:VIO GUITAR:GUITAR DIRECT LEVEL
274 INST1:VIO GUITAR:GUITAR VOLUME
275 INST1:VIO GUITAR:GUITAR TONE
276 INST1:VIO GUITAR:HARMO PITCH
277 INST1:VIO GUITAR:HARMO GAIN
278 INST1:VIO GUITAR:HARMO ATTACK
279 INST1:VIO GUITAR:HARMO DIRECT LEVEL
280 INST1:VIO GUITAR:FILTER OVERTONE
281 INST1:VIO GUITAR:FILTER ATTACK
282 INST1:VIO GUITAR:FILTER POWER BEND
283 INST1:VIO GUITAR:FILTER SLIDE TIME
284 INST1:VIO GUITAR:FILTER OCTAVE
285 INST1:VIO GUITAR:FILTER COLOR
286 INST1:VIO GUITAR:FILTER TOUCH SENS
287 INST1:VIO GUITAR:FILTER LEAD EMPHASIS
288 INST1:POLY FX TYPE
289 INST1:POLY FX GUITAR VOLUME
290 INST1:POLY FX GAIN
291 INST1:POLY FX GAIN BALANCE
292 INST1:POLY FX COLOR
293 INST1:POLY FX TONE
294 INST1:POLY FX FILTER MODE
295 INST1:POLY FX POLARITY
296 INST1:POLY FX SENS
297 INST1:POLY FX FREQUENCY
298 INST1:POLY FX DECAY
299 INST1:POLY FX PEAK
300 INST1:POLY FX TONE TYPE
301 INST1:POLY FX COMP SW
302 INST1:POLY FX COMP SUSTAIN
303 INST1:POLY FX COMP ATTACK
304 INST1:AMP ON/OFF
305 INST1:AMP TYPE
306 INST1:AMP GAIN
307 INST1:AMP SAG
308 INST1:AMP RESONANCE
309 INST1:AMP LEVEL
310 INST1:AMP BASS
311 INST1:AMP MIDDLE
312 INST1:AMP TREBLE
313 INST1:AMP PRESENCE
314 INST1:AMP BRIGHT
315 INST1:AMP GAIN SW
316 INST1:AMP SOLO SW
317 INST1:AMP SOLO LEVEL
318 INST1:AMP SP TYPE
319 INST1:AMP MIC TYPE
320 INST1:AMP MIC DISTANCE
321 INST1:AMP MIC POSITION
322 INST1:AMP MIC LEVEL
323 INST1:AMP DIRECT LEVEL
324 INST1:NS ON/OFF
325 INST1:NS THRESHOLD
326 INST1:NS RELEASE
327 INST1:EQ ON/OFF
328 INST1:EQ LOW CUT
329 INST1:EQ LOW GAIN
330 INST1:EQ LOW-MID FREQ
331 INST1:EQ LOW-MID Q
332 INST1:EQ LOW-MID GAIN
333 INST1:EQ HIGH-MID FREQ
334 INST1:EQ HIGH-MID Q
335 INST1:EQ HIGH-MID GAIN
336 INST1:EQ HIGH GAIN
337 INST1:EQ HIGH CUT
338 INST1:EQ LEVEL
# CATEGORY TARGET
(continued)
339 INST2 ON/OFF
340 INST2 TYPE
341 INST2 LEVEL
342 INST2 NOR MIX SW
343 INST2 NOR MIX LEVEL
344 INST2 STRING LEVEL 6
345 INST2 STRING LEVEL 5
346 INST2 STRING LEVEL 4
347 INST2 STRING LEVEL 3
348 INST2 STRING LEVEL 2
349 INST2 STRING LEVEL 1
350 INST2 STRING PAN 6
351 INST2 STRING PAN 5
352 INST2 STRING PAN 4
353 INST2 STRING PAN 3
354 INST2 STRING PAN 2
355 INST2 STRING PAN 1
356 INST2:ALT TUNE ON/OFF
357 INST2:ALT TUNE TUNING TYPE
358 INST2:ALT TUNE PITCH 6
359 INST2:ALT TUNE PITCH 5
360 INST2:ALT TUNE PITCH 4
361 INST2:ALT TUNE PITCH 3
362 INST2:ALT TUNE PITCH 2
363 INST2:ALT TUNE PITCH 1
364 INST2:ALT TUNE FINE 6
365 INST2:ALT TUNE FINE 5
366 INST2:ALT TUNE FINE 4
367 INST2:ALT TUNE FINE 3
368 INST2:ALT TUNE FINE 2
369 INST2:ALT TUNE FINE 1
370 INST2:ALT TUNE 12STR SW
371 INST2:ALT TUNE 12STR TYPE
372 INST2:ALT TUNE 12STR PITCH 6
373 INST2:ALT TUNE 12STR PITCH 5
374 INST2:ALT TUNE 12STR PITCH 4
375 INST2:ALT TUNE 12STR PITCH 3
376 INST2:ALT TUNE 12STR PITCH 2
377 INST2:ALT TUNE 12STR PITCH 1
378 INST2:ALT TUNE 12STR FINE 6
379 INST2:ALT TUNE 12STR FINE 5
380 INST2:ALT TUNE 12STR FINE 4
381 INST2:ALT TUNE 12STR FINE 3
382 INST2:ALT TUNE 12STR FINE 2
383 INST2:ALT TUNE 12STR FINE 1
384 INST2:ALT TUNE 12STR LEVEL 6
385 INST2:ALT TUNE 12STR LEVEL 5
386 INST2:ALT TUNE 12STR LEVEL 4
387 INST2:ALT TUNE 12STR LEVEL 3
388 INST2:ALT TUNE 12STR LEVEL 2
389 INST2:ALT TUNE 12STR LEVEL 1
390 INST2:ALT TUNE 12STR DELAY 6
391 INST2:ALT TUNE 12STR DELAY 5
392 INST2:ALT TUNE 12STR DELAY 4
393 INST2:ALT TUNE 12STR DELAY 3
394 INST2:ALT TUNE 12STR DELAY 2
395 INST2:ALT TUNE 12STR DELAY 1
396 INST2:ALT TUNE STR BEND SW
397 INST2:ALT TUNE BEND DEPTH 6
398 INST2:ALT TUNE BEND DEPTH 5
399 INST2:ALT TUNE BEND DEPTH 4
400 INST2:ALT TUNE BEND DEPTH 3
401 INST2:ALT TUNE BEND DEPTH 2
402 INST2:ALT TUNE BEND DEPTH 1
403 INST2:ALT TUNE BEND CONTROL
404 INST2:DYNAMIC SYNTH:OSC WAVEFORM
405 INST2:DYNAMIC SYNTH:OSC PITCH
406 INST2:DYNAMIC SYNTH:OSC FINE
407 INST2:DYNAMIC SYNTH:OSC PULSE WIDTH
408 INST2:DYNAMIC SYNTH:OSC PWM ENV ATTACK
409 INST2:DYNAMIC SYNTH:OSC PWM ENV DEPTH
410 INST2:DYNAMIC SYNTH:OSC DETUNE
411 INST2:DYNAMIC SYNTH:OSC SHARPNESS
412 INST2:DYNAMIC SYNTH:OSC FEEDBACK
413 INST2:DYNAMIC SYNTH:OSC HARMONICS
414 INST2:DYNAMIC SYNTH:OSC S-SAW DETUNE
415 INST2:DYNAMIC SYNTH:OSC P. ENV ATTACK
416 INST2:DYNAMIC SYNTH:OSC P. ENV DEPTH
417 INST2:DYNAMIC SYNTH:OSC P. BEND DEPTH
418 INST2:DYNAMIC SYNTH:OSC P. BEND CTL
419 INST2:DYNAMIC SYNTH:OSC SYNC SW
420 INST2:DYNAMIC SYNTH:OSC RING SW
421 (RESERVED)
422 INST2:DYNAMIC SYNTH:FILTER ON/OFF
423 INST2:DYNAMIC SYNTH:FILTER TYPE
424 INST2:DYNAMIC SYNTH:FILTER SLOPE
425 INST2:DYNAMIC SYNTH:FILTER CUTOFF
426 INST2:DYNAMIC SYNTH:FILTER RESONANCE
427 INST2:DYNAMIC SYNTH:FILTER F. ENV ATTACK
428 INST2:DYNAMIC SYNTH:FILTER F. ENV DEPTH
429 INST2:DYNAMIC SYNTH:AMP A. ENV ATTACK
430 INST2:DYNAMIC SYNTH:AMP LOW CUT
431 INST2:DYNAMIC SYNTH:AMP HIGH CUT
432 INST2:DYNAMIC SYNTH:LFO1 ON/OFF
433 INST2:DYNAMIC SYNTH:LFO1 SHAPE
434 INST2:DYNAMIC SYNTH:LFO1 RATE
435 INST2:DYNAMIC SYNTH:LFO1 DYNAMIC DEPTH
436 INST2:DYNAMIC SYNTH:LFO1 PITCH DEPTH
437 INST2:DYNAMIC SYNTH:LFO1 FILTER DEPTH
438 INST2:DYNAMIC SYNTH:LFO1 AMP DEPTH
439 INST2:DYNAMIC SYNTH:LFO1 PWM DEPTH
440 INST2:DYNAMIC SYNTH:LFO1 FADE TIME
441 INST2:DYNAMIC SYNTH:LFO1 SYNC
442 INST2:DYNAMIC SYNTH:LFO2 ON/OFF
443 INST2:DYNAMIC SYNTH:LFO2 SHAPE
444 INST2:DYNAMIC SYNTH:LFO2 RATE
445 INST2:DYNAMIC SYNTH:LFO2 DYNAMIC DEPTH
446 INST2:DYNAMIC SYNTH:LFO2 PITCH DEPTH
447 INST2:DYNAMIC SYNTH:LFO2 FILTER DEPTH
448 INST2:DYNAMIC SYNTH:LFO2 AMP DEPTH
449 INST2:DYNAMIC SYNTH:LFO2 PWM DEPTH
450 INST2:DYNAMIC SYNTH:LFO2 FADE TIME
451 INST2:DYNAMIC SYNTH:LFO2 SYNC
452 INST2:DYNAMIC SYNTH:SEQ COMMON PITCH TARGET
453 INST2:DYNAMIC SYNTH:SEQ COMMON CUTOFF TARGET
454 INST2:DYNAMIC SYNTH:SEQ COMMON LEVEL TARGET
455 INST2:DYNAMIC SYNTH:SEQ1 ON/OFF
456 INST2:DYNAMIC SYNTH:SEQ1 SYNC
457 INST2:DYNAMIC SYNTH:SEQ1 LOOP LENGTH
458 INST2:DYNAMIC SYNTH:SEQ1 RATE
459 INST2:DYNAMIC SYNTH:SEQ1 1 SHOT
460 INST2:DYNAMIC SYNTH:SEQ1 TURBO
461 INST2:DYNAMIC SYNTH:SEQ2 ON/OFF
462 INST2:DYNAMIC SYNTH:SEQ2 SYNC
463 INST2:DYNAMIC SYNTH:SEQ2 LOOP LENGTH
464 INST2:DYNAMIC SYNTH:SEQ2 RATE
465 INST2:DYNAMIC SYNTH:SEQ2 1 SHOT
466 INST2:DYNAMIC SYNTH:SEQ2 TURBO
467 INST2:DYNAMIC SYNTH:LAYER L. FADE
468 INST2:DYNAMIC SYNTH:LAYER LOWER
469 INST2:DYNAMIC SYNTH:LAYER UPPER
470 INST2:DYNAMIC SYNTH:LAYER U. FADE
471 INST2:OSC SYNTH:OSC MODE
472 INST2:OSC SYNTH:OSC WAVEFORM1
473 INST2:OSC SYNTH:OSC PITCH 1
474 INST2:OSC SYNTH:OSC FINE 1
475 INST2:OSC SYNTH:OSC PULSE WIDTH 1
476 INST2:OSC SYNTH:OSC PW MOD RATE 1
477 INST2:OSC SYNTH:OSC P. ENV ATTACK 1
478 INST2:OSC SYNTH:OSC P. ENV DECAY 1
479 INST2:OSC SYNTH:OSC P. ENV DEPTH 1
480 INST2:OSC SYNTH:OSC LEVEL 1
481 INST2:OSC SYNTH:OSC WAVEFORM 2
482 INST2:OSC SYNTH:OSC PITCH 2
483 INST2:OSC SYNTH:OSC FINE 2
484 INST2:OSC SYNTH:OSC PULSE WIDTH 2
485 INST2:OSC SYNTH:OSC PW MOD RATE 2
486 INST2:OSC SYNTH:OSC P. ENV ATTACK 2
487 INST2:OSC SYNTH:OSC P. ENV DECAY 2
488 INST2:OSC SYNTH:OSC P. ENV DEPTH 2
489 INST2:OSC SYNTH:OSC LEVEL 2
490 INST2:OSC SYNTH:OSC MONO/POLY SW
491 INST2:OSC SYNTH:OSC CHROMATIC
492 INST2:OSC SYNTH:OSC PORTA SW
493 INST2:OSC SYNTH:OSC PORTA TIME
494 INST2:OSC SYNTH:OSC PORTA MODE
495 INST2:OSC SYNTH:OSC HOLD MODE
496 INST2:OSC SYNTH:OSC LOW VELO CUT
497 INST2:OSC SYNTH:FILTER ON/OFF
498 INST2:OSC SYNTH:FILTER TYPE
499 INST2:OSC SYNTH:FILTER SLOPE
500 INST2:OSC SYNTH:FILTER CUTOFF
501 INST2:OSC SYNTH:FILTER CUTOFF FOLLOW
502 INST2:OSC SYNTH:FILTER RESONANCE
503 INST2:OSC SYNTH:FILTER VELOCITY SENS
504 INST2:OSC SYNTH:FILTER F. ENV ATTACK
505 INST2:OSC SYNTH:FILTER F. ENV DECAY
506 INST2:OSC SYNTH:FILTER F. ENV SUSTAIN
507 INST2:OSC SYNTH:FILTER F. ENV RELEASE
508 INST2:OSC SYNTH:FILTER F. ENV DEPTH
509 INST2:OSC SYNTH:AMP VELOCITY SENS
510 INST2:OSC SYNTH:AMP A. ENV ATTACK
511 INST2:OSC SYNTH:AMP A. ENV DECAY
512 INST2:OSC SYNTH:AMP A. ENV SUSTAIN
513 INST2:OSC SYNTH:AMP A. ENV RELEASE
514 INST2:OSC SYNTH:AMP LOW CUT
515 INST2:OSC SYNTH:AMP HIGH CUT
516 INST2:OSC SYNTH:LFO1 ON/OFF
517 INST2:OSC SYNTH:LFO1 SHAPE
518 INST2:OSC SYNTH:LFO1 RATE
519 INST2:OSC SYNTH:LFO1 PITCH1 DEPTH
520 INST2:OSC SYNTH:LFO1 PITCH2 DEPTH
521 INST2:OSC SYNTH:LFO1 FILTER DEPTH
522 INST2:OSC SYNTH:LFO1 AMP DEPTH
523 INST2:OSC SYNTH:LFO1 DELAY TIME
524 INST2:OSC SYNTH:LFO1 FADE TIME
525 INST2:OSC SYNTH:LFO1 SYNC
526 INST2:OSC SYNTH:LFO2 ON/OFF
527 INST2:OSC SYNTH:LFO2 SHAPE
528 INST2:OSC SYNTH:LFO2 RATE
529 INST2:OSC SYNTH:LFO2 PITCH1 DEPTH
530 INST2:OSC SYNTH:LFO2 PITCH2 DEPTH
531 INST2:OSC SYNTH:LFO2 FILTER DEPTH
532 INST2:OSC SYNTH:LFO2 AMP DEPTH
533 INST2:OSC SYNTH:LFO2 DELAY TIME
534 INST2:OSC SYNTH:LFO2 FADE TIME
535 INST2:OSC SYNTH:LFO2 SYNC
536 INST2:GR-300 MODE
537 INST2:GR-300 COMP SW
538 INST2:GR-300 CUTOFF
539 INST2:GR-300 RESONANCE
540 INST2:GR-300 ENV MOD SW
541 INST2:GR-300 ENV MOD SENS
542 INST2:GR-300 ENV MOD ATTACK
543 INST2:GR-300 PITCH SW
544 INST2:GR-300 PITCH A
545 INST2:GR-300 FINE A
546 INST2:GR-300 PITCH B
547 INST2:GR-300 FINE B
548 INST2:GR-300 DUET SW
549 INST2:GR-300 SWEEP SW
550 INST2:GR-300 SWEEP RISE
551 INST2:GR-300 SWEEP FALL
552 INST2:GR-300 VIBRATO SW
553 INST2:GR-300 VIBRATO RATE
554 INST2:GR-300 VIBRATO DEPTH
555 INST2:GR-300 LOW CUT
556 INST2:GR-300 HIGH CUT
557 INST2:E.GTR TYPE
558 INST2:E.GTR PU SELECT
559 INST2:E.GTR PU SELECT UP
560 INST2:E.GTR PU SELECT DOW
561 INST2:E.GTR TONE TYPE
562 INST2:E.GTR SENS
563 INST2:E.GTR DEPTH
564 INST2:E.GTR ATTACK
565 INST2:E.GTR RESONANCE
566 INST2:E.GTR DIRECT LEVEL
567 INST2:E.GTR VOLUME
568 INST2:E.GTR TONE
569 INST2:ACOUSTIC TYPE
570 INST2:ACOUSTIC BODY
571 INST2:ACOUSTIC ATTACK
572 INST2:ACOUSTIC PU SELECT
573 INST2:ACOUSTIC PU SELECT UP
574 INST2:ACOUSTIC PU SELECT DOWN
575 INST2:ACOUSTIC SENS
576 INST2:ACOUSTIC COLOR
577 INST2:ACOUSTIC DECAY
578 INST2:ACOUSTIC BUZZ
579 INST2:ACOUSTIC RESONANCE
580 INST2:ACOUSTIC SUSTAIN
581 INST2:ACOUSTIC VOLUME
582 INST2:ACOUSTIC TONE
583 INST2:E.BASS TYPE
584 INST2:E.BASS REAR VOLUME
585 INST2:E.BASS FRONT VOLUME
586 INST2:E.BASS TONE TYPE
587 INST2:E.BASS SENS
588 INST2:E.BASS DEPTH
589 INST2:E.BASS ATTACK
590 INST2:E.BASS RESONANCE
591 INST2:E.BASS DIRECT LEVEL
592 INST2:E.BASS VOLUME
593 INST2:E.BASS TONE
594 INST2:VIO GUITAR:GUITAR E.GTR TYPE
595 INST2:VIO GUITAR:GUITAR PU SELECT
596 INST2:VIO GUITAR:GUITAR PU SELECT UP
597 INST2:VIO GUITAR:GUITAR PU SELECT DOWN
598 INST2:VIO GUITAR:GUITAR TONE TYPE
599 INST2:VIO GUITAR:GUITAR SENS
600 INST2:VIO GUITAR:GUITAR DEPTH
601 INST2:VIO GUITAR:GUITAR ATTACK
602 INST2:VIO GUITAR:GUITAR RESONANCE
603 INST2:VIO GUITAR:GUITAR DIRECT LEVEL
604 INST2:VIO GUITAR:GUITAR VOLUME
605 INST2:VIO GUITAR:GUITAR TONE
606 INST2:VIO GUITAR:HARMO PITCH
607 INST2:VIO GUITAR:HARMO GAIN
608 INST2:VIO GUITAR:HARMO ATTACK
609 INST2:VIO GUITAR:HARMO DIRECT LEVEL
610 INST2:VIO GUITAR:FILTER OVERTONE
611 INST2:VIO GUITAR:FILTER ATTACK
612 INST2:VIO GUITAR:FILTER POWER BEND
613 INST2:VIO GUITAR:FILTER SLIDE TIME
614 INST2:VIO GUITAR:FILTER OCTAVE
615 INST2:VIO GUITAR:FILTER COLOR
616 INST2:VIO GUITAR:FILTER TOUCH SENS
617 INST2:VIO GUITAR:FILTER LEAD EMPHASIS
618 INST2:POLY FX TYPE
619 INST2:POLY FX GUITAR VOLUME
620 INST2:POLY FX GAIN
621 INST2:POLY FX GAIN BALANCE
622 INST2:POLY FX COLOR
623 INST2:POLY FX TONE
624 INST2:POLY FX FILTER MODE
625 INST2:POLY FX POLARITY
626 INST2:POLY FX SENS
627 INST2:POLY FX FREQUENCY
628 INST2:POLY FX DECAY
629 INST2:POLY FX PEAK
630 INST2:POLY FX TONE TYPE
631 INST2:POLY FX COMP SW
632 INST2:POLY FX COMP SUSTAIN
633 INST2:POLY FX COMP ATTACK
634 INST2:AMP ON/OFF
635 INST2:AMP TYPE
636 INST2:AMP GAIN
637 INST2:AMP SAG
638 INST2:AMP RESONANCE
639 INST2:AMP LEVEL
640 INST2:AMP BASS
641 INST2:AMP MIDDLE
642 INST2:AMP TREBLE
643 INST2:AMP PRESENCE
644 INST2:AMP BRIGHT
645 INST2:AMP GAIN SW
646 INST2:AMP SOLO SW
647 INST2:AMP SOLO LEVEL
648 INST2:AMP SP TYPE
649 INST2:AMP MIC TYPE
650 INST2:AMP MIC DISTANCE
651 INST2:AMP MIC POSITION
652 INST2:AMP MIC LEVEL
653 INST2:AMP DIRECT LEVEL
654 INST2:NS ON/OFF
655 INST2:NS THRESHOLD
656 INST2:NS RELEASE
657 INST2:EQ ON/OFF
658 INST2:EQ LOW CUT
659 INST2:EQ LOW GAIN
660 INST2:EQ LOW-MID FREQ
661 INST2:EQ LOW-MID Q
662 INST2:EQ LOW-MID GAIN
663 INST2:EQ HIGH-MID FREQ
664 INST2:EQ HIGH-MID Q
665 INST2:EQ HIGH-MID GAIN
666 INST2:EQ HIGH GAIN
667 INST2:EQ HIGH CUT
668 INST2:EQ LEVEL
# CATEGORY TARGET
(continued)
669 INST3 ON/OFF
670 INST3 TYPE
671 INST3 LEVEL
672 INST3 NOR MIX SW
673 INST3 NOR MIX LEVEL
674 INST3 STRING LEVEL 6
675 INST3 STRING LEVEL 5
676 INST3 STRING LEVEL 4
677 INST3 STRING LEVEL 3
678 INST3 STRING LEVEL 2
679 INST3 STRING LEVEL 1
680 INST3 STRING PAN 6
681 INST3 STRING PAN 5
682 INST3 STRING PAN 4
683 INST3 STRING PAN 3
684 INST3 STRING PAN 2
685 INST3 STRING PAN 1
686 INST3:ALT TUNE ON/OFF
687 INST3:ALT TUNE TUNING TYPE
688 INST3:ALT TUNE PITCH 6
689 INST3:ALT TUNE PITCH 5
690 INST3:ALT TUNE PITCH 4
691 INST3:ALT TUNE PITCH 3
692 INST3:ALT TUNE PITCH 2
693 INST3:ALT TUNE PITCH 1
694 INST3:ALT TUNE FINE 6
695 INST3:ALT TUNE FINE 5
696 INST3:ALT TUNE FINE 4
697 INST3:ALT TUNE FINE 3
698 INST3:ALT TUNE FINE 2
699 INST3:ALT TUNE FINE 1
700 INST3:ALT TUNE 12STR SW
701 INST3:ALT TUNE 12STR TYPE
702 INST3:ALT TUNE 12STR PITCH 6
703 INST3:ALT TUNE 12STR PITCH 5
704 INST3:ALT TUNE 12STR PITCH 4
705 INST3:ALT TUNE 12STR PITCH 3
706 INST3:ALT TUNE 12STR PITCH 2
707 INST3:ALT TUNE 12STR PITCH 1
708 INST3:ALT TUNE 12STR FINE 6
709 INST3:ALT TUNE 12STR FINE 5
710 INST3:ALT TUNE 12STR FINE 4
711 INST3:ALT TUNE 12STR FINE 3
712 INST3:ALT TUNE 12STR FINE 2
713 INST3:ALT TUNE 12STR FINE 1
714 INST3:ALT TUNE 12STR LEVEL 6
715 INST3:ALT TUNE 12STR LEVEL 5
716 INST3:ALT TUNE 12STR LEVEL 4
717 INST3:ALT TUNE 12STR LEVEL 3
718 INST3:ALT TUNE 12STR LEVEL 2
719 INST3:ALT TUNE 12STR LEVEL 1
720 INST3:ALT TUNE 12STR DELAY 6
721 INST3:ALT TUNE 12STR DELAY 5
722 INST3:ALT TUNE 12STR DELAY 4
723 INST3:ALT TUNE 12STR DELAY 3
724 INST3:ALT TUNE 12STR DELAY 2
725 INST3:ALT TUNE 12STR DELAY 1
726 INST3:ALT TUNE STR BEND SW
727 INST3:ALT TUNE BEND DEPTH 6
728 INST3:ALT TUNE BEND DEPTH 5
729 INST3:ALT TUNE BEND DEPTH 4
730 INST3:ALT TUNE BEND DEPTH 3
731 INST3:ALT TUNE BEND DEPTH 2
732 INST3:ALT TUNE BEND DEPTH 1
733 INST3:ALT TUNE BEND CONTROL
734 INST3:DYNAMIC SYNTH:OSC WAVEFORM
735 INST3:DYNAMIC SYNTH:OSC PITCH
736 INST3:DYNAMIC SYNTH:OSC FINE
737 INST3:DYNAMIC SYNTH:OSC PULSE WIDTH
738 INST3:DYNAMIC SYNTH:OSC PWM ENV ATTACK
739 INST3:DYNAMIC SYNTH:OSC PWM ENV DEPTH
740 INST3:DYNAMIC SYNTH:OSC DETUNE
741 INST3:DYNAMIC SYNTH:OSC SHARPNESS
742 INST3:DYNAMIC SYNTH:OSC FEEDBACK
743 INST3:DYNAMIC SYNTH:OSC HARMONICS
744 INST3:DYNAMIC SYNTH:OSC S-SAW DETUNE
745 INST3:DYNAMIC SYNTH:OSC P. ENV ATTACK
746 INST3:DYNAMIC SYNTH:OSC P. ENV DEPTH
747 INST3:DYNAMIC SYNTH:OSC P. BEND DEPTH
748 INST3:DYNAMIC SYNTH:OSC P. BEND CTL
749 INST3:DYNAMIC SYNTH:OSC SYNC SW
750 INST3:DYNAMIC SYNTH:OSC RING SW
751 (RESERVED)
752 INST3:DYNAMIC SYNTH:FILTER ON/OFF
753 INST3:DYNAMIC SYNTH:FILTER TYPE
754 INST3:DYNAMIC SYNTH:FILTER SLOPE
755 INST3:DYNAMIC SYNTH:FILTER CUTOFF
756 INST3:DYNAMIC SYNTH:FILTER RESONANCE
757 INST3:DYNAMIC SYNTH:FILTER F. ENV ATTACK
758 INST3:DYNAMIC SYNTH:FILTER F. ENV DEPTH
759 INST3:DYNAMIC SYNTH:AMP A. ENV ATTACK
760 INST3:DYNAMIC SYNTH:AMP LOW CUT
761 INST3:DYNAMIC SYNTH:AMP HIGH CUT
762 INST3:DYNAMIC SYNTH:LFO1 ON/OFF
763 INST3:DYNAMIC SYNTH:LFO1 SHAPE
764 INST3:DYNAMIC SYNTH:LFO1 RATE
765 INST3:DYNAMIC SYNTH:LFO1 DYNAMIC DEPTH
766 INST3:DYNAMIC SYNTH:LFO1 PITCH DEPTH
767 INST3:DYNAMIC SYNTH:LFO1 FILTER DEPTH
768 INST3:DYNAMIC SYNTH:LFO1 AMP DEPTH
769 INST3:DYNAMIC SYNTH:LFO1 PWM DEPTH
770 INST3:DYNAMIC SYNTH:LFO1 FADE TIME
771 INST3:DYNAMIC SYNTH:LFO1 SYNC
772 INST3:DYNAMIC SYNTH:LFO2 ON/OFF
773 INST3:DYNAMIC SYNTH:LFO2 SHAPE
774 INST3:DYNAMIC SYNTH:LFO2 RATE
775 INST3:DYNAMIC SYNTH:LFO2 DYNAMIC DEPTH
776 INST3:DYNAMIC SYNTH:LFO2 PITCH DEPTH
777 INST3:DYNAMIC SYNTH:LFO2 FILTER DEPTH
778 INST3:DYNAMIC SYNTH:LFO2 AMP DEPTH
779 INST3:DYNAMIC SYNTH:LFO2 PWM DEPTH
780 INST3:DYNAMIC SYNTH:LFO2 FADE TIME
781 INST3:DYNAMIC SYNTH:LFO2 SYNC
782 INST3:DYNAMIC SYNTH:SEQ COMMON PITCH TARGET
783 INST3:DYNAMIC SYNTH:SEQ COMMON CUTOFF TARGET
784 INST3:DYNAMIC SYNTH:SEQ COMMON LEVEL TARGET
785 INST3:DYNAMIC SYNTH:SEQ1 ON/OFF
786 INST3:DYNAMIC SYNTH:SEQ1 SYNC
787 INST3:DYNAMIC SYNTH:SEQ1 LOOP LENGTH
788 INST3:DYNAMIC SYNTH:SEQ1 RATE
789 INST3:DYNAMIC SYNTH:SEQ1 1 SHOT
790 INST3:DYNAMIC SYNTH:SEQ1 TURBO
791 INST3:DYNAMIC SYNTH:SEQ2 ON/OFF
792 INST3:DYNAMIC SYNTH:SEQ2 SYNC
793 INST3:DYNAMIC SYNTH:SEQ2 LOOP LENGTH
794 INST3:DYNAMIC SYNTH:SEQ2 RATE
795 INST3:DYNAMIC SYNTH:SEQ2 1 SHOT
796 INST3:DYNAMIC SYNTH:SEQ2 TURBO
797 INST3:DYNAMIC SYNTH:LAYER L. FADE
798 INST3:DYNAMIC SYNTH:LAYER LOWER
799 INST3:DYNAMIC SYNTH:LAYER UPPER
800 INST3:DYNAMIC SYNTH:LAYER U. FADE
801 INST3:OSC SYNTH:OSC MODE
802 INST3:OSC SYNTH:OSC WAVEFORM1
803 INST3:OSC SYNTH:OSC PITCH 1
804 INST3:OSC SYNTH:OSC FINE 1
805 INST3:OSC SYNTH:OSC PULSE WIDTH 1
806 INST3:OSC SYNTH:OSC PW MOD RATE 1
807 INST3:OSC SYNTH:OSC P. ENV ATTACK 1
808 INST3:OSC SYNTH:OSC P. ENV DECAY 1
809 INST3:OSC SYNTH:OSC P. ENV DEPTH 1
810 INST3:OSC SYNTH:OSC LEVEL 1
811 INST3:OSC SYNTH:OSC WAVEFORM 2
812 INST3:OSC SYNTH:OSC PITCH 2
813 INST3:OSC SYNTH:OSC FINE 2
814 INST3:OSC SYNTH:OSC PULSE WIDTH 2
815 INST3:OSC SYNTH:OSC PW MOD RATE 2
816 INST3:OSC SYNTH:OSC P. ENV ATTACK 2
817 INST3:OSC SYNTH:OSC P. ENV DECAY 2
818 INST3:OSC SYNTH:OSC P. ENV DEPTH 2
819 INST3:OSC SYNTH:OSC LEVEL 2
820 INST3:OSC SYNTH:OSC MONO/POLY SW
821 INST3:OSC SYNTH:OSC CHROMATIC
822 INST3:OSC SYNTH:OSC PORTA SW
823 INST3:OSC SYNTH:OSC PORTA TIME
824 INST3:OSC SYNTH:OSC PORTA MODE
825 INST3:OSC SYNTH:OSC HOLD MODE
826 INST3:OSC SYNTH:OSC LOW VELO CUT
827 INST3:OSC SYNTH:FILTER ON/OFF
828 INST3:OSC SYNTH:FILTER TYPE
829 INST3:OSC SYNTH:FILTER SLOPE
830 INST3:OSC SYNTH:FILTER CUTOFF
831 INST3:OSC SYNTH:FILTER CUTOFF FOLLOW
832 INST3:OSC SYNTH:FILTER RESONANCE
833 INST3:OSC SYNTH:FILTER VELOCITY SENS
834 INST3:OSC SYNTH:FILTER F. ENV ATTACK
835 INST3:OSC SYNTH:FILTER F. ENV DECAY
836 INST3:OSC SYNTH:FILTER F. ENV SUSTAIN
837 INST3:OSC SYNTH:FILTER F. ENV RELEASE
838 INST3:OSC SYNTH:FILTER F. ENV DEPTH
839 INST3:OSC SYNTH:AMP VELOCITY SENS
840 INST3:OSC SYNTH:AMP A. ENV ATTACK
841 INST3:OSC SYNTH:AMP A. ENV DECAY
842 INST3:OSC SYNTH:AMP A. ENV SUSTAIN
843 INST3:OSC SYNTH:AMP A. ENV RELEASE
844 INST3:OSC SYNTH:AMP LOW CUT
845 INST3:OSC SYNTH:AMP HIGH CUT
846 INST3:OSC SYNTH:LFO1 ON/OFF
847 INST3:OSC SYNTH:LFO1 SHAPE
848 INST3:OSC SYNTH:LFO1 RATE
849 INST3:OSC SYNTH:LFO1 PITCH1 DEPTH
850 INST3:OSC SYNTH:LFO1 PITCH2 DEPTH
851 INST3:OSC SYNTH:LFO1 FILTER DEPTH
852 INST3:OSC SYNTH:LFO1 AMP DEPTH
853 INST3:OSC SYNTH:LFO1 DELAY TIME
854 INST3:OSC SYNTH:LFO1 FADE TIME
855 INST3:OSC SYNTH:LFO1 SYNC
856 INST3:OSC SYNTH:LFO2 ON/OFF
857 INST3:OSC SYNTH:LFO2 SHAPE
858 INST3:OSC SYNTH:LFO2 RATE
859 INST3:OSC SYNTH:LFO2 PITCH1 DEPTH
860 INST3:OSC SYNTH:LFO2 PITCH2 DEPTH
861 INST3:OSC SYNTH:LFO2 FILTER DEPTH
862 INST3:OSC SYNTH:LFO2 AMP DEPTH
863 INST3:OSC SYNTH:LFO2 DELAY TIME
864 INST3:OSC SYNTH:LFO2 FADE TIME
865 INST3:OSC SYNTH:LFO2 SYNC
866 INST3:GR-300 MODE
867 INST3:GR-300 COMP SW
868 INST3:GR-300 CUTOFF
869 INST3:GR-300 RESONANCE
870 INST3:GR-300 ENV MOD SW
871 INST3:GR-300 ENV MOD SENS
872 INST3:GR-300 ENV MOD ATTACK
873 INST3:GR-300 PITCH SW
874 INST3:GR-300 PITCH A
875 INST3:GR-300 FINE A
876 INST3:GR-300 PITCH B
877 INST3:GR-300 FINE B
878 INST3:GR-300 DUET SW
879 INST3:GR-300 SWEEP SW
880 INST3:GR-300 SWEEP RISE
881 INST3:GR-300 SWEEP FALL
882 INST3:GR-300 VIBRATO SW
883 INST3:GR-300 VIBRATO RATE
884 INST3:GR-300 VIBRATO DEPTH
885 INST3:GR-300 LOW CUT
886 INST3:GR-300 HIGH CUT
887 INST3:E.GTR TYPE
888 INST3:E.GTR PU SELECT
889 INST3:E.GTR PU SELECT UP
890 INST3:E.GTR PU SELECT DOWN
891 INST3:E.GTR TONE TYPE
892 INST3:E.GTR SENS
893 INST3:E.GTR DEPTH
894 INST3:E.GTR ATTACK
895 INST3:E.GTR RESONANCE
896 INST3:E.GTR DIRECT LEVEL
897 INST3:E.GTR VOLUME
898 INST3:E.GTR TONE
899 INST3:ACOUSTIC TYPE
900 INST3:ACOUSTIC BODY
901 INST3:ACOUSTIC ATTACK
902 INST3:ACOUSTIC PU SELECT
903 INST3:ACOUSTIC PU SELECT UP
904 INST3:ACOUSTIC PU SELECT DOWN
905 INST3:ACOUSTIC SENS
906 INST3:ACOUSTIC COLOR
907 INST3:ACOUSTIC DECAY
908 INST3:ACOUSTIC BUZZ
909 INST3:ACOUSTIC RESONANCE
910 INST3:ACOUSTIC SUSTAIN
911 INST3:ACOUSTIC VOLUME
912 INST3:ACOUSTIC TONE
913 INST3:E.BASS TYPE
914 INST3:E.BASS REAR VOLUME
915 INST3:E.BASS FRONT VOLUME
916 INST3:E.BASS TONE TYPE
917 INST3:E.BASS SENS
918 INST3:E.BASS DEPTH
919 INST3:E.BASS ATTACK
920 INST3:E.BASS RESONANCE
921 INST3:E.BASS DIRECT LEVEL
922 INST3:E.BASS VOLUME
923 INST3:E.BASS TONE
924 INST3:VIO GUITAR:GUITAR E.GTR TYPE
925 INST3:VIO GUITAR:GUITAR PU SELECT
926 INST3:VIO GUITAR:GUITAR PU SELECT UP
927 INST3:VIO GUITAR:GUITAR PU SELECT DOWN
928 INST3:VIO GUITAR:GUITAR TONE TYPE
929 INST3:VIO GUITAR:GUITAR SENS
930 INST3:VIO GUITAR:GUITAR DEPTH
931 INST3:VIO GUITAR:GUITAR ATTACK
932 INST3:VIO GUITAR:GUITAR RESONANCE
933 INST3:VIO GUITAR:GUITAR DIRECT LEVEL
934 INST3:VIO GUITAR:GUITAR VOLUME
935 INST3:VIO GUITAR:GUITAR TONE
936 INST3:VIO GUITAR:HARMO PITCH
937 INST3:VIO GUITAR:HARMO GAIN
938 INST3:VIO GUITAR:HARMO ATTACK
939 INST3:VIO GUITAR:HARMO DIRECT LEVEL
940 INST3:VIO GUITAR:FILTER OVERTONE
941 INST3:VIO GUITAR:FILTER ATTACK
942 INST3:VIO GUITAR:FILTER POWER BEND
943 INST3:VIO GUITAR:FILTER SLIDE TIME
944 INST3:VIO GUITAR:FILTER OCTAVE
945 INST3:VIO GUITAR:FILTER COLOR
946 INST3:VIO GUITAR:FILTER TOUCH SENS
947 INST3:VIO GUITAR:FILTER LEAD EMPHASIS
948 INST3:POLY FX TYPE
949 INST3:POLY FX GUITAR VOLUME
950 INST3:POLY FX GAIN
951 INST3:POLY FX GAIN BALANCE
952 INST3:POLY FX COLOR
953 INST3:POLY FX TONE
954 INST3:POLY FX FILTER MODE
955 INST3:POLY FX POLARITY
956 INST3:POLY FX SENS
957 INST3:POLY FX FREQUENCY
958 INST3:POLY FX DECAY
959 INST3:POLY FX PEAK
960 INST3:POLY FX TONE TYPE
961 INST3:POLY FX COMP SW
962 INST3:POLY FX COMP SUSTAIN
963 INST3:POLY FX COMP ATTACK
964 INST3:AMP ON/OFF
965 INST3:AMP TYPE
966 INST3:AMP GAIN
967 INST3:AMP SAG
968 INST3:AMP RESONANCE
969 INST3:AMP LEVEL
970 INST3:AMP BASS
971 INST3:AMP MIDDLE
972 INST3:AMP TREBLE
973 INST3:AMP PRESENCE
974 INST3:AMP BRIGHT
975 INST3:AMP GAIN SW
976 INST3:AMP SOLO SW
977 INST3:AMP SOLO LEVEL
978 INST3:AMP SP TYPE
979 INST3:AMP MIC TYPE
980 INST3:AMP MIC DISTANCE
981 INST3:AMP MIC POSITION
982 INST3:AMP MIC LEVEL
983 INST3:AMP DIRECT LEVEL
984 INST3:NS ON/OFF
985 INST3:NS THRESHOLD
986 INST3:NS RELEASE
987 INST3:EQ ON/OFF
988 INST3:EQ LOW CUT
989 INST3:EQ LOW GAIN
990 INST3:EQ LOW-MID FREQ
991 INST3:EQ LOW-MID Q
992 INST3:EQ LOW-MID GAIN
993 INST3:EQ HIGH-MID FREQ
994 INST3:EQ HIGH-MID Q
995 INST3:EQ HIGH-MID GAIN
996 INST3:EQ HIGH GAIN
997 INST3:EQ HIGH CUT
998 INST3:EQ LEVEL
999 INST:CONTROL INST1 HOLD
1000 INST:CONTROL INST2 HOLD
1001 INST:CONTROL INST3 HOLD
1002 INST:CONTROL INST ALL HOLD
1003 INST:CONTROL INST1 SEQ1 RETRIGGER
1004 INST:CONTROL INST1 SEQ2 RETRIGGER
1005 INST:CONTROL INST1 SEQ1&2 RETRIGGER
1006 INST:CONTROL INST2 SEQ1 RETRIGGER
1007 INST:CONTROL INST2 SEQ2 RETRIGGER
1008 INST:CONTROL INST2 SEQ1&2 RETRIGGER
1009 INST:CONTROL INST3 SEQ1 RETRIGGER
1010 INST:CONTROL INST3 SEQ2 RETRIGGER
1011 INST:CONTROL INST3 SEQ1&2 RETRIGGER
1012 INST:CONTROL INST ALL SEQ RETRIGGER
1013 INST:CONTROL SYNC RETRIGGER
1014 NORMAL ON/OFF
1015 NORMAL LEVEL
1016 NORMAL CABLE SIM
1017 NORMAL PHASE SW
# CATEGORY TARGET
(continued)
1018 FX1 ON/OFF
1019 FX1 TYPE
1020 FX1:AC RESONANCE TYPE
1021 FX1:AC RESONANCE RESONANCE
1022 FX1:AC RESONANCE TONE
1023 FX1:AC RESONANCE LEVEL
1024 FX1:AUTO WAH FILTER MODE
1025 FX1:AUTO WAH RATE
1026 FX1:AUTO WAH DEPTH
1027 FX1:AUTO WAH EFFECT LEVEL
1028 FX1:AUTO WAH FREQUENCY
1029 FX1:AUTO WAH RESONANCE
1030 FX1:AUTO WAH WAVEFORM
1031 FX1:AUTO WAH DIRECT LEVEL
1032 FX1:CHORUS MODE
1033 FX1:CHORUS RATE
1034 FX1:CHORUS DEPTH
1035 FX1:CHORUS PRE-DELAY
1036 FX1:CHORUS EFFECT LEVEL
1037 FX1:CHORUS WAVEFORM
1038 FX1:CHORUS LOW CUT
1039 FX1:CHORUS HIGH CUT
1040 FX1:CHORUS DIRECT LEVEL
1041 FX1:CHORUS RATE1
1042 FX1:CHORUS DEPTH1
1043 FX1:CHORUS PRE-DELAY1
1044 FX1:CHORUS EFFECT LEVEL1
1045 FX1:CHORUS WAVEFORM1
1046 FX1:CHORUS LOW CUT1
1047 FX1:CHORUS HIGH CUT1
1048 FX1:CHORUS RATE2
1049 FX1:CHORUS DEPTH2
1050 FX1:CHORUS PRE-DELAY2
1051 FX1:CHORUS EFFECT LEVEL2
1052 FX1:CHORUS WAVEFORM2
1053 FX1:CHORUS LOW CUT2
1054 FX1:CHORUS HIGH CUT2
1055 FX1:CHORUS OUTPUT MODE
1056 FX1:CLASSIC-VIBE RATE
1057 FX1:CLASSIC-VIBE DEPTH
1058 FX1:CLASSIC-VIBE EFFECT LEVEL
1059 FX1:COMPRESSOR TYPE
1060 FX1:COMPRESSOR SUSTAIN
1061 FX1:COMPRESSOR ATTACK
1062 FX1:COMPRESSOR EFFECT LEVEL
1063 FX1:COMPRESSOR DIRECT LEVEL
1064 FX1:COMPRESSOR TONE
1065 FX1:DEFRETTER SENS
1066 FX1:DEFRETTER DEPTH
1067 FX1:DEFRETTER TONE
1068 FX1:DEFRETTER EFFECT LEVEL
1069 FX1:DEFRETTER ATTACK
1070 FX1:DEFRETTER RESONANCE
1071 FX1:DEFRETTER DIRECT LEVEL
1072 FX1:DEFRETTER BASS SENS
1073 FX1:DEFRETTER BASS TONE
1074 FX1:DEFRETTER BASS EFFECT LEVEL
1075 FX1:DEFRETTER BASS ATTACK
1076 FX1:DEFRETTER BASS DIRECT LEVEL
1077 FX1:DELAY TYPE
1078 FX1:DELAY TIME
1079 FX1:DELAY FEEDBACK
1080 FX1:DELAY EFFECT LEVEL
1081 FX1:DELAY HIGH CUT
1082 FX1:DELAY DIRECT LEVEL
1083 FX1:DELAY TAP TIME
1084 FX1:DELAY TRIGGER
1085 FX1:DELAY CARRY OVER
1086 FX1:DELAY DUAL D1 TIME
1087 FX1:DELAY DUAL D1 FEEDBACK
1088 FX1:DELAY DUAL D1 HIGH CUT
1089 FX1:DELAY DUAL D1 EFFECT LEVEL
1090 FX1:DELAY DUAL D2 TIME
1091 FX1:DELAY DUAL D2 FEEDBACK
1092 FX1:DELAY DUAL D2 HIGH CUT
1093 FX1:DELAY DUAL D2 EFFECT LEVEL
1094 FX1:DELAY MOD MOD RATE
1095 FX1:DELAY MOD MOD DEPTH
1096 FX1:DELAY TWIST MODE
1097 FX1:DELAY TWIST RISE TIME
1098 FX1:DELAY TWIST FALL TIME
1099 FX1:DELAY TWIST FADE TIME
1100 FX1:FLANGER RATE
1101 FX1:FLANGER DEPTH
1102 FX1:FLANGER RESONANCE
1103 FX1:FLANGER MANUAL
1104 FX1:FLANGER SEPARATION
1105 FX1:FLANGER LOW CUT
1106 FX1:FLANGER HIGH CUT
1107 FX1:FLANGER EFFECT LEVEL
1108 FX1:FLANGER DIRECT LEVEL
1109 FX1:FLANGER BASS RATE
1110 FX1:FLANGER BASS DEPTH
1111 FX1:FLANGER BASS RESONANCE
1112 FX1:FLANGER BASS MANUAL
1113 FX1:FLANGER BASS SEPARATION
1114 FX1:FLANGER BASS LOW CUT
1115 FX1:FLANGER BASS HIGH CUT
1116 FX1:FLANGER BASS EFFECT LEVEL
1117 FX1:FLANGER BASS DIRECT LEVEL
1118 FX1:FOOT VOLUME VOLUME MIN
1119 FX1:FOOT VOLUME VOLUME MAX
1120 FX1:FOOT VOLUME VOLUME CURVE
1121 FX1:FOOT VOLUME PEDAL POSITION
1122 FX1:GRAPHIC EQ 100Hz
1123 FX1:GRAPHIC EQ 200Hz
1124 FX1:GRAPHIC EQ 400Hz
1125 FX1:GRAPHIC EQ 800Hz
1126 FX1:GRAPHIC EQ 1.6kHz
1127 FX1:GRAPHIC EQ 3.2kHz
1128 FX1:GRAPHIC EQ 6.4kHz
1129 FX1:GRAPHIC EQ LEVEL
1130 FX1:HARMONIST VOICE
1131 FX1:HARMONIST HR1:HARMONY
1132 FX1:HARMONIST HR2:HARMONY
1133 FX1:HARMONIST HR1:LEVEL
1134 FX1:HARMONIST HR1:PRE-DELAY
1135 FX1:HARMONIST HR1:FEEDBACK
1136 FX1:HARMONIST DIRECT LEVEL
1137 FX1:HARMONIST HR2:LEVEL
1138 FX1:HARMONIST HR2:PRE-DELAY
1139 FX1:HUMANIZER MODE
1140 FX1:HUMANIZER VOWEL1
1141 FX1:HUMANIZER VOWEL2
1142 FX1:HUMANIZER SENS
1143 FX1:HUMANIZER RATE
1144 FX1:HUMANIZER DEPTH
1145 FX1:HUMANIZER MANUAL
1146 FX1:HUMANIZER EFFECT LEVEL
1147 FX1:ISOLATOR BAND
1148 FX1:ISOLATOR RATE
1149 FX1:ISOLATOR DEPTH
1150 FX1:ISOLATOR BAND LEVEL
1151 FX1:LIMITER TYPE
1152 FX1:LIMITER THRESHOLD
1153 FX1:LIMITER RATIO
1154 FX1:LIMITER EFFECT LEVEL
1155 FX1:LIMITER ATTACK
1156 FX1:LIMITER RELEASE
1157 FX1:LO-FI BIT DEPTH
1158 FX1:LO-FI SAMPLE RATE
1159 FX1:LO-FI BALANCE
1160 FX1:OCTAVE -2OCT
1161 FX1:OCTAVE -1OCT
1162 FX1:OCTAVE DIRECT LEVEL
1163 FX1:OCTAVE BASS -2OCT
1164 FX1:OCTAVE BASS -1OCT
1165 FX1:OCTAVE BASS DIRECT LEVEL
1166 FX1:PAN TYPE
1167 FX1:PAN WAVE SHAPE
1168 FX1:PAN RATE
1169 FX1:PAN DEPTH
1170 FX1:PAN EFFECT LEVEL
1171 FX1:PAN POSITION
1172 FX1:PARAMETRIC EQ LOW CUT
1173 FX1:PARAMETRIC EQ LOW GAIN
1174 FX1:PARAMETRIC EQ LOW-MID FREQ
1175 FX1:PARAMETRIC EQ LOW-MID Q
1176 FX1:PARAMETRIC EQ LOW-MID GAIN
1177 FX1:PARAMETRIC EQ HIGH-MID FREQ
1178 FX1:PARAMETRIC EQ HIGH-MID Q
1179 FX1:PARAMETRIC EQ HIGH-MID GAIN
1180 FX1:PARAMETRIC EQ HIGH GAIN
1181 FX1:PARAMETRIC EQ HIGH CUT
1182 FX1:PARAMETRIC EQ LEVEL
1183 FX1:PEDAL BEND PITCH
1184 FX1:PEDAL BEND PEDAL POSITION
1185 FX1:PEDAL BEND EFFECT LEVEL
1186 FX1:PEDAL BEND DIRECT LEVEL
1187 FX1:PHASER TYPE
1188 FX1:PHASER RATE
1189 FX1:PHASER DEPTH
1190 FX1:PHASER RESONANCE
1191 FX1:PHASER MANUAL
1192 FX1:PHASER STEP RATE
1193 FX1:PHASER EFFECT LEVEL
1194 FX1:PHASER DIRECT LEVEL
1195 FX1:PITCH SHIFTER VOICE
1196 FX1:PITCH SHIFTER PS1:PITCH
1197 FX1:PITCH SHIFTER PS2:PITCH
1198 FX1:PITCH SHIFTER DIRECT LEVEL
1199 FX1:PITCH SHIFTER PS1:MODE
1200 FX1:PITCH SHIFTER PS1:FINE
1201 FX1:PITCH SHIFTER PS1:PRE-DELAY
1202 FX1:PITCH SHIFTER PS1:LEVEL
1203 FX1:PITCH SHIFTER PS1:FEEDBACK
1204 FX1:PITCH SHIFTER PS2:MODE
1205 FX1:PITCH SHIFTER PS2:FINE
1206 FX1:PITCH SHIFTER PS2:PRE-DELAY
1207 FX1:PITCH SHIFTER PS2:LEVEL
1208 FX1:REVERB TYPE
1209 FX1:REVERB TIME
1210 FX1:REVERB PRE-DELAY
1211 FX1:REVERB EFFECT LEVEL
1212 FX1:REVERB LOW CUT
1213 FX1:REVERB HIGH CUT
1214 FX1:REVERB DENSITY
1215 FX1:REVERB DIRECT LEVEL
1216 FX1:REVERB CARRY OVER
1217 FX1:REVERB SPRING SENS
1218 FX1:RING MOD INTELLIGENT
1219 FX1:RING MOD FREQUENCY
1220 FX1:RING MOD FREQ MOD RATE
1221 FX1:RING MOD FREQ MOD DEPTH
1222 FX1:RING MOD EFFECT LEVEL
1223 FX1:RING MOD DIRECT LEVEL
1224 FX1:ROTARY SPEED SELECT
1225 FX1:ROTARY RATE SLOW
1226 FX1:ROTARY RATE FAST
1227 FX1:ROTARY DEPTH
1228 FX1:ROTARY RISE TIME
1229 FX1:ROTARY FALL TIME
1230 FX1:ROTARY EFFECT LEVEL
1231 FX1:ROTARY DIRECT LEVEL
1232 FX1:SITAR SIM SENS
1233 FX1:SITAR SIM DEPTH
1234 FX1:SITAR SIM TONE
1235 FX1:SITAR SIM EFFECT LEVEL
1236 FX1:SITAR SIM RESONANCE
1237 FX1:SITAR SIM BUZZ
1238 FX1:SITAR SIM DIRECT LEVEL
1239 FX1:SLICER PATTERN
1240 FX1:SLICER RATE
1241 FX1:SLICER TRIGGER
1242 FX1:SLICER EFFECT LEVEL
1243 FX1:SLICER ATTACK
1244 FX1:SLICER DUTY
1245 FX1:SLICER DIRECT LEVEL
1246 FX1:SLOW GEAR SENS
1247 FX1:SLOW GEAR RISE TIME
1248 FX1:SLOW GEAR EFFECT LEVEL
1249 FX1:SLOW GEAR BASS SENS
1250 FX1:SLOW GEAR BASS RISE TIME
1251 FX1:SLOW GEAR BASS EFFECT LEVEL
1252 FX1:SOUND HOLD TRIGGER
1253 FX1:SOUND HOLD RISE TIME
1254 FX1:SOUND HOLD EFFECT LEVEL
1255 FX1:TOUCH WAH FILTER MODE
1256 FX1:TOUCH WAH POLARITY
1257 FX1:TOUCH WAH SENS
1258 FX1:TOUCH WAH FREQUENCY
1259 FX1:TOUCH WAH RESONANCE
1260 FX1:TOUCH WAH DECAY
1261 FX1:TOUCH WAH EFFECT LEVEL
1262 FX1:TOUCH WAH DIRECT LEVEL
1263 FX1:TOUCH WAH BASS FILTER MODE
1264 FX1:TOUCH WAH BASS POLARITY
1265 FX1:TOUCH WAH BASS SENS
1266 FX1:TOUCH WAH BASS FREQUENCY
1267 FX1:TOUCH WAH BASS RESONANCE
1268 FX1:TOUCH WAH BASS DECAY
1269 FX1:TOUCH WAH BASS EFFECT LEVEL
1270 FX1:TOUCH WAH BASS DIRECT LEVEL
1271 FX1:TREMOLO WAVE SHAPE
1272 FX1:TREMOLO RATE
1273 FX1:TREMOLO DEPTH
1274 FX1:TREMOLO EFFECT LEVEL
1275 FX1:TREMOLO DIRECT LEVEL
1276 FX1:VIBRATO RATE
1277 FX1:VIBRATO DEPTH
1278 FX1:VIBRATO TRIGGER
1279 FX1:VIBRATO RISE TIME
1280 FX1:VIBRATO EFFECT LEVEL
1281 FX1:VIBRATO DIRECT LEVEL
1282 FX1:WAH TYPE
1283 FX1:WAH PEDAL POSITION
1284 FX1:WAH PEDAL MIN
1285 FX1:WAH PEDAL MAX
1286 FX1:WAH EFFECT LEVEL
1287 FX1:WAH DIRECT LEVEL
1288 FX2 ON/OFF
1289 FX2 TYPE
1290 FX2:AC RESONANCE TYPE
1291 FX2:AC RESONANCE RESONANCE
1292 FX2:AC RESONANCE TONE
1293 FX2:AC RESONANCE LEVEL
1294 FX2:AUTO WAH FILTER MODE
1295 FX2:AUTO WAH RATE
1296 FX2:AUTO WAH DEPTH
1297 FX2:AUTO WAH EFFECT LEVEL
1298 FX2:AUTO WAH FREQUENCY
1299 FX2:AUTO WAH RESONANCE
1300 FX2:AUTO WAH WAVEFORM
1301 FX2:AUTO WAH DIRECT LEVEL
1302 FX2:CHORUS MODE
1303 FX2:CHORUS RATE
1304 FX2:CHORUS DEPTH
1305 FX2:CHORUS PRE-DELAY
1306 FX2:CHORUS EFFECT LEVEL
1307 FX2:CHORUS WAVEFORM
1308 FX2:CHORUS LOW CUT
1309 FX2:CHORUS HIGH CUT
1310 FX2:CHORUS DIRECT LEVEL
1311 FX2:CHORUS RATE1
1312 FX2:CHORUS DEPTH1
1313 FX2:CHORUS PRE-DELAY1
1314 FX2:CHORUS EFFECT LEVEL1
1315 FX2:CHORUS WAVEFORM1
1316 FX2:CHORUS LOW CUT1
1317 FX2:CHORUS HIGH CUT1
1318 FX2:CHORUS RATE2
1319 FX2:CHORUS DEPTH2
1320 FX2:CHORUS PRE-DELAY2
1321 FX2:CHORUS EFFECT LEVEL2
1322 FX2:CHORUS WAVEFORM2
1323 FX2:CHORUS LOW CUT2
1324 FX2:CHORUS HIGH CUT2
1325 FX2:CHORUS OUTPUT MODE
1326 FX2:CLASSIC-VIBE RATE
1327 FX2:CLASSIC-VIBE DEPTH
1328 FX2:CLASSIC-VIBE EFFECT LEVEL
1329 FX2:COMPRESSOR TYPE
1330 FX2:COMPRESSOR SUSTAIN
1331 FX2:COMPRESSOR ATTACK
1332 FX2:COMPRESSOR EFFECT LEVEL
1333 FX2:COMPRESSOR DIRECT LEVEL
1334 FX2:COMPRESSOR TONE
1335 FX2:DEFRETTER SENS
1336 FX2:DEFRETTER DEPTH
1337 FX2:DEFRETTER TONE
1338 FX2:DEFRETTER EFFECT LEVEL
1339 FX2:DEFRETTER ATTACK
1340 FX2:DEFRETTER RESONANCE
1341 FX2:DEFRETTER DIRECT LEVEL
1342 FX2:DEFRETTER BASS SENS
1343 FX2:DEFRETTER BASS TONE
1344 FX2:DEFRETTER BASS EFFECT LEVEL
1345 FX2:DEFRETTER BASS ATTACK
1346 FX2:DEFRETTER BASS DIRECT LEVEL
1347 FX2:DELAY TYPE
1348 FX2:DELAY TIME
1349 FX2:DELAY FEEDBACK
1350 FX2:DELAY EFFECT LEVEL
1351 FX2:DELAY HIGH CUT
1352 FX2:DELAY DIRECT LEVEL
1353 FX2:DELAY TAP TIME
1354 FX2:DELAY TRIGGER
1355 FX2:DELAY CARRY OVER
1356 FX2:DELAY DUAL D1 TIME
1357 FX2:DELAY DUAL D1 FEEDBACK
1358 FX2:DELAY DUAL D1 HIGH CUT
1359 FX2:DELAY DUAL D1 EFFECT LEVEL
1360 FX2:DELAY DUAL D2 TIME
1361 FX2:DELAY DUAL D2 FEEDBACK
1362 FX2:DELAY DUAL D2 HIGH CUT
1363 FX2:DELAY DUAL D2 EFFECT LEVEL
1364 FX2:DELAY MOD MOD RATE
1365 FX2:DELAY MOD MOD DEPTH
1366 FX2:DELAY TWIST MODE
1367 FX2:DELAY TWIST RISE TIME
1368 FX2:DELAY TWIST FALL TIME
1369 FX2:DELAY TWIST FADE TIME
1370 FX2:FLANGER RATE
1371 FX2:FLANGER DEPTH
1372 FX2:FLANGER RESONANCE
1373 FX2:FLANGER MANUAL
1374 FX2:FLANGER SEPARATION
1375 FX2:FLANGER LOW CUT
1376 FX2:FLANGER HIGH CUT
1377 FX2:FLANGER EFFECT LEVEL
1378 FX2:FLANGER DIRECT LEVEL
1379 FX2:FLANGER BASS RATE
1380 FX2:FLANGER BASS DEPTH
1381 FX2:FLANGER BASS RESONANCE
1382 FX2:FLANGER BASS MANUAL
1383 FX2:FLANGER BASS SEPARATION
1384 FX2:FLANGER BASS LOW CUT
1385 FX2:FLANGER BASS HIGH CUT
1386 FX2:FLANGER BASS EFFECT LEVEL
1387 FX2:FLANGER BASS DIRECT LEVEL
1388 FX2:FOOT VOLUME VOLUME MIN
1389 FX2:FOOT VOLUME VOLUME MAX
1390 FX2:FOOT VOLUME VOLUME CURVE
1391 FX2:FOOT VOLUME PEDAL POSITION
1392 FX2:GRAPHIC EQ 100Hz
1393 FX2:GRAPHIC EQ 200Hz
1394 FX2:GRAPHIC EQ 400Hz
1395 FX2:GRAPHIC EQ 800Hz
1396 FX2:GRAPHIC EQ 1.6kHz
1397 FX2:GRAPHIC EQ 3.2kHz
1398 FX2:GRAPHIC EQ 6.4kHz
1399 FX2:GRAPHIC EQ LEVEL
1400 FX2:HARMONIST VOICE
1401 FX2:HARMONIST HR1:HARMONY
1402 FX2:HARMONIST HR2:HARMONY
1403 FX2:HARMONIST HR1:LEVEL
1404 FX2:HARMONIST HR1:PRE-DELAY
1405 FX2:HARMONIST HR1:FEEDBACK
1406 FX2:HARMONIST DIRECT LEVEL
1407 FX2:HARMONIST HR2:LEVEL
1408 FX2:HARMONIST HR2:PRE-DELAY
1409 FX2:HUMANIZER MODE
1410 FX2:HUMANIZER VOWEL1
1411 FX2:HUMANIZER VOWEL2
1412 FX2:HUMANIZER SENS
1413 FX2:HUMANIZER RATE
1414 FX2:HUMANIZER DEPTH
1415 FX2:HUMANIZER MANUAL
1416 FX2:HUMANIZER EFFECT LEVEL
1417 FX2:ISOLATOR BAND
1418 FX2:ISOLATOR RATE
1419 FX2:ISOLATOR DEPTH
1420 FX2:ISOLATOR BAND LEVEL
1421 FX2:LIMITER TYPE
1422 FX2:LIMITER THRESHOLD
1423 FX2:LIMITER RATIO
1424 FX2:LIMITER EFFECT LEVEL
1425 FX2:LIMITER ATTACK
1426 FX2:LIMITER RELEASE
1427 FX2:LO-FI BIT DEPTH
1428 FX2:LO-FI SAMPLE RATE
1429 FX2:LO-FI BALANCE
1430 FX2:OCTAVE -2OCT
1431 FX2:OCTAVE -1OCT
1432 FX2:OCTAVE DIRECT LEVEL
1433 FX2:OCTAVE BASS -2OCT
1434 FX2:OCTAVE BASS -1OCT
1435 FX2:OCTAVE BASS DIRECT LEVEL
1436 FX2:PAN TYPE
1437 FX2:PAN WAVE SHAPE
1438 FX2:PAN RATE
1439 FX2:PAN DEPTH
1440 FX2:PAN EFFECT LEVEL
1441 FX2:PAN POSITION
1442 FX2:PARAMETRIC EQ LOW CUT
1443 FX2:PARAMETRIC EQ LOW GAIN
1444 FX2:PARAMETRIC EQ LOW-MID FREQ
1445 FX2:PARAMETRIC EQ LOW-MID Q
1446 FX2:PARAMETRIC EQ LOW-MID GAIN
1447 FX2:PARAMETRIC EQ HIGH-MID FREQ
1448 FX2:PARAMETRIC EQ HIGH-MID Q
1449 FX2:PARAMETRIC EQ HIGH-MID GAIN
1450 FX2:PARAMETRIC EQ HIGH GAIN
1451 FX2:PARAMETRIC EQ HIGH CUT
1452 FX2:PARAMETRIC EQ LEVEL
1453 FX2:PEDAL BEND PITCH
1454 FX2:PEDAL BEND PEDAL POSITION
1455 FX2:PEDAL BEND EFFECT LEVEL
1456 FX2:PEDAL BEND DIRECT LEVEL
1457 FX2:PHASER TYPE
1458 FX2:PHASER RATE
1459 FX2:PHASER DEPTH
1460 FX2:PHASER RESONANCE
1461 FX2:PHASER MANUAL
1462 FX2:PHASER STEP RATE
1463 FX2:PHASER EFFECT LEVEL
1464 FX2:PHASER DIRECT LEVEL
1465 FX2:PITCH SHIFTER VOICE
1466 FX2:PITCH SHIFTER PS1:PITCH
1467 FX2:PITCH SHIFTER PS2:PITCH
1468 FX2:PITCH SHIFTER DIRECT LEVEL
1469 FX2:PITCH SHIFTER PS1:MODE
1470 FX2:PITCH SHIFTER PS1:FINE
1471 FX2:PITCH SHIFTER PS1:PRE-DELAY
1472 FX2:PITCH SHIFTER PS1:LEVEL
1473 FX2:PITCH SHIFTER PS1:FEEDBACK
1474 FX2:PITCH SHIFTER PS2:MODE
1475 FX2:PITCH SHIFTER PS2:FINE
1476 FX2:PITCH SHIFTER PS2:PRE-DELAY
1477 FX2:PITCH SHIFTER PS2:LEVEL
1478 FX2:REVERB TYPE
1479 FX2:REVERB TIME
1480 FX2:REVERB PRE-DELAY
1481 FX2:REVERB EFFECT LEVEL
1482 FX2:REVERB LOW CUT
1483 FX2:REVERB HIGH CUT
1484 FX2:REVERB DENSITY
1485 FX2:REVERB DIRECT LEVEL
1486 FX2:REVERB CARRY OVER
1487 FX2:REVERB SPRING SENS
1488 FX2:RING MOD INTELLIGENT
1489 FX2:RING MOD FREQUENCY
1490 FX2:RING MOD FREQ MOD RATE
1491 FX2:RING MOD FREQ MOD DEPTH
1492 FX2:RING MOD EFFECT LEVEL
1493 FX2:RING MOD DIRECT LEVEL
1494 FX2:ROTARY SPEED SELECT
1495 FX2:ROTARY RATE SLOW
1496 FX2:ROTARY RATE FAST
1497 FX2:ROTARY DEPTH
1498 FX2:ROTARY RISE TIME
1499 FX2:ROTARY FALL TIME
1500 FX2:ROTARY EFFECT LEVEL
1501 FX2:ROTARY DIRECT LEVEL
1502 FX2:SITAR SIM SENS
1503 FX2:SITAR SIM DEPTH
1504 FX2:SITAR SIM TONE
1505 FX2:SITAR SIM EFFECT LEVEL
1506 FX2:SITAR SIM RESONANCE
1507 FX2:SITAR SIM BUZZ
1508 FX2:SITAR SIM DIRECT LEVEL
1509 FX2:SLICER PATTERN
1510 FX2:SLICER RATE
1511 FX2:SLICER TRIGGER
1512 FX2:SLICER EFFECT LEVEL
1513 FX2:SLICER ATTACK
1514 FX2:SLICER DUTY
1515 FX2:SLICER DIRECT LEVEL
1516 FX2:SLOW GEAR SENS
1517 FX2:SLOW GEAR RISE TIME
1518 FX2:SLOW GEAR EFFECT LEVEL
1519 FX2:SLOW GEAR BASS SENS
1520 FX2:SLOW GEAR BASS RISE TIME
1521 FX2:SLOW GEAR BASS EFFECT LEVEL
1522 FX2:SOUND HOLD TRIGGER
1523 FX2:SOUND HOLD RISE TIME
1524 FX2:SOUND HOLD EFFECT LEVEL
1525 FX2:TOUCH WAH FILTER MODE
1526 FX2:TOUCH WAH POLARITY
1527 FX2:TOUCH WAH SENS
1528 FX2:TOUCH WAH FREQUENCY
1529 FX2:TOUCH WAH RESONANCE
1530 FX2:TOUCH WAH DECAY
1531 FX2:TOUCH WAH EFFECT LEVEL
1532 FX2:TOUCH WAH DIRECT LEVEL
1533 FX2:TOUCH WAH BASS FILTER MODE
1534 FX2:TOUCH WAH BASS POLARITY
1535 FX2:TOUCH WAH BASS SENS
1536 FX2:TOUCH WAH BASS FREQUENCY
1537 FX2:TOUCH WAH BASS RESONANCE
1538 FX2:TOUCH WAH BASS DECAY
1539 FX2:TOUCH WAH BASS EFFECT LEVEL
1540 FX2:TOUCH WAH BASS DIRECT LEVEL
1541 FX2:TREMOLO WAVE SHAPE
1542 FX2:TREMOLO RATE
1543 FX2:TREMOLO DEPTH
1544 FX2:TREMOLO EFFECT LEVEL
1545 FX2:TREMOLO DIRECT LEVEL
1546 FX2:VIBRATO RATE
1547 FX2:VIBRATO DEPTH
1548 FX2:VIBRATO TRIGGER
1549 FX2:VIBRATO RISE TIME
1550 FX2:VIBRATO EFFECT LEVEL
1551 FX2:VIBRATO DIRECT LEVEL
1552 FX2:WAH TYPE
1553 FX2:WAH PEDAL POSITION
1554 FX2:WAH PEDAL MIN
1555 FX2:WAH PEDAL MAX
1556 FX2:WAH EFFECT LEVEL
1557 FX2:WAH DIRECT LEVEL
# CATEGORY TARGET
(continued)
1558 FX3 ON/OFF
1559 FX3 TYPE
1560 FX3:AC RESONANCE TYPE
1561 FX3:AC RESONANCE RESONANCE
1562 FX3:AC RESONANCE TONE
1563 FX3:AC RESONANCE LEVEL
1564 FX3:AUTO WAH FILTER MODE
1565 FX3:AUTO WAH RATE
1566 FX3:AUTO WAH DEPTH
1567 FX3:AUTO WAH EFFECT LEVEL
1568 FX3:AUTO WAH FREQUENCY
1569 FX3:AUTO WAH RESONANCE
1570 FX3:AUTO WAH WAVEFORM
1571 FX3:AUTO WAH DIRECT LEVEL
1572 FX3:CHORUS MODE
1573 FX3:CHORUS RATE
1574 FX3:CHORUS DEPTH
1575 FX3:CHORUS PRE-DELAY
1576 FX3:CHORUS EFFECT LEVEL
1577 FX3:CHORUS WAVEFORM
1578 FX3:CHORUS LOW CUT
1579 FX3:CHORUS HIGH CUT
1580 FX3:CHORUS DIRECT LEVEL
1581 FX3:CHORUS RATE1
1582 FX3:CHORUS DEPTH1
1583 FX3:CHORUS PRE-DELAY1
1584 FX3:CHORUS EFFECT LEVEL1
1585 FX3:CHORUS WAVEFORM1
1586 FX3:CHORUS LOW CUT1
1587 FX3:CHORUS HIGH CUT1
1588 FX3:CHORUS RATE2
1589 FX3:CHORUS DEPTH2
1590 FX3:CHORUS PRE-DELAY2
1591 FX3:CHORUS EFFECT LEVEL2
1592 FX3:CHORUS WAVEFORM2
1593 FX3:CHORUS LOW CUT2
1594 FX3:CHORUS HIGH CUT2
1595 FX3:CHORUS OUTPUT MODE
1596 FX3:CLASSIC-VIBE RATE
1597 FX3:CLASSIC-VIBE DEPTH
1598 FX3:CLASSIC-VIBE EFFECT LEVEL
1599 FX3:COMPRESSOR TYPE
1600 FX3:COMPRESSOR SUSTAIN
1601 FX3:COMPRESSOR ATTACK
1602 FX3:COMPRESSOR EFFECT LEVEL
1603 FX3:COMPRESSOR DIRECT LEVEL
1604 FX3:COMPRESSOR TONE
1605 FX3:DEFRETTER SENS
1606 FX3:DEFRETTER DEPTH
1607 FX3:DEFRETTER TONE
1608 FX3:DEFRETTER EFFECT LEVEL
1609 FX3:DEFRETTER ATTACK
1610 FX3:DEFRETTER RESONANCE
1611 FX3:DEFRETTER DIRECT LEVEL
1612 FX3:DEFRETTER BASS SENS
1613 FX3:DEFRETTER BASS TONE
1614 FX3:DEFRETTER BASS EFFECT LEVEL
1615 FX3:DEFRETTER BASS ATTACK
1616 FX3:DEFRETTER BASS DIRECT LEVEL
1617 FX3:DELAY TYPE
1618 FX3:DELAY TIME
1619 FX3:DELAY FEEDBACK
1620 FX3:DELAY EFFECT LEVEL
1621 FX3:DELAY HIGH CUT
1622 FX3:DELAY DIRECT LEVEL
1623 FX3:DELAY TAP TIME
1624 FX3:DELAY TRIGGER
1625 FX3:DELAY CARRY OVER
1626 FX3:DELAY DUAL D1 TIME
1627 FX3:DELAY DUAL D1 FEEDBACK
1628 FX3:DELAY DUAL D1 HIGH CUT
1629 FX3:DELAY DUAL D1 EFFECT LEVEL
1630 FX3:DELAY DUAL D2 TIME
1631 FX3:DELAY DUAL D2 FEEDBACK
1632 FX3:DELAY DUAL D2 HIGH CUT
1633 FX3:DELAY DUAL D2 EFFECT LEVEL
1634 FX3:DELAY MOD MOD RATE
1635 FX3:DELAY MOD MOD DEPTH
1636 FX3:DELAY TWIST MODE
1637 FX3:DELAY TWIST RISE TIME
1638 FX3:DELAY TWIST FALL TIME
1639 FX3:DELAY TWIST FADE TIME
1640 FX3:FLANGER RATE
1641 FX3:FLANGER DEPTH
1642 FX3:FLANGER RESONANCE
1643 FX3:FLANGER MANUAL
1644 FX3:FLANGER SEPARATION
1645 FX3:FLANGER LOW CUT
1646 FX3:FLANGER HIGH CUT
1647 FX3:FLANGER EFFECT LEVEL
1648 FX3:FLANGER DIRECT LEVEL
1649 FX3:FLANGER BASS RATE
1650 FX3:FLANGER BASS DEPTH
1651 FX3:FLANGER BASS RESONANCE
1652 FX3:FLANGER BASS MANUAL
1653 FX3:FLANGER BASS SEPARATION
1654 FX3:FLANGER BASS LOW CUT
1655 FX3:FLANGER BASS HIGH CUT
1656 FX3:FLANGER BASS EFFECT LEVEL
1657 FX3:FLANGER BASS DIRECT LEVEL
1658 FX3:FOOT VOLUME VOLUME MIN
1659 FX3:FOOT VOLUME VOLUME MAX
1660 FX3:FOOT VOLUME VOLUME CURVE
1661 FX3:FOOT VOLUME PEDAL POSITION
1662 FX3:GRAPHIC EQ 100Hz
1663 FX3:GRAPHIC EQ 200Hz
1664 FX3:GRAPHIC EQ 400Hz
1665 FX3:GRAPHIC EQ 800Hz
1666 FX3:GRAPHIC EQ 1.6kHz
1667 FX3:GRAPHIC EQ 3.2kHz
1668 FX3:GRAPHIC EQ 6.4kHz
1669 FX3:GRAPHIC EQ LEVEL
1670 FX3:HARMONIST VOICE
1671 FX3:HARMONIST HR1:HARMONY
1672 FX3:HARMONIST HR2:HARMONY
1673 FX3:HARMONIST HR1:LEVEL
1674 FX3:HARMONIST HR1:PRE-DELAY
1675 FX3:HARMONIST HR1:FEEDBACK
1676 FX3:HARMONIST DIRECT LEVEL
1677 FX3:HARMONIST HR2:LEVEL
1678 FX3:HARMONIST HR2:PRE-DELAY
1679 FX3:HUMANIZER MODE
1680 FX3:HUMANIZER VOWEL1
1681 FX3:HUMANIZER VOWEL2
1682 FX3:HUMANIZER SENS
1683 FX3:HUMANIZER RATE
1684 FX3:HUMANIZER DEPTH
1685 FX3:HUMANIZER MANUAL
1686 FX3:HUMANIZER EFFECT LEVEL
1687 FX3:ISOLATOR BAND
1688 FX3:ISOLATOR RATE
1689 FX3:ISOLATOR DEPTH
1690 FX3:ISOLATOR BAND LEVEL
1691 FX3:LIMITER TYPE
1692 FX3:LIMITER THRESHOLD
1693 FX3:LIMITER RATIO
1694 FX3:LIMITER EFFECT LEVEL
1695 FX3:LIMITER ATTACK
1696 FX3:LIMITER RELEASE
1697 FX3:LO-FI BIT DEPTH
1698 FX3:LO-FI SAMPLE RATE
1699 FX3:LO-FI BALANCE
1700 FX3:OCTAVE -2OCT
1701 FX3:OCTAVE -1OCT
1702 FX3:OCTAVE DIRECT LEVEL
1703 FX3:OCTAVE BASS -2OCT
1704 FX3:OCTAVE BASS -1OCT
1705 FX3:OCTAVE BASS DIRECT LEVEL
1706 FX3:PAN TYPE
1707 FX3:PAN WAVE SHAPE
1708 FX3:PAN RATE
1709 FX3:PAN DEPTH
1710 FX3:PAN EFFECT LEVEL
1711 FX3:PAN POSITION
1712 FX3:PARAMETRIC EQ LOW CUT
1713 FX3:PARAMETRIC EQ LOW GAIN
1714 FX3:PARAMETRIC EQ LOW-MID FREQ
1715 FX3:PARAMETRIC EQ LOW-MID Q
1716 FX3:PARAMETRIC EQ LOW-MID GAIN
1717 FX3:PARAMETRIC EQ HIGH-MID FREQ
1718 FX3:PARAMETRIC EQ HIGH-MID Q
1719 FX3:PARAMETRIC EQ HIGH-MID GAIN
1720 FX3:PARAMETRIC EQ HIGH GAIN
1721 FX3:PARAMETRIC EQ HIGH CUT
1722 FX3:PARAMETRIC EQ LEVEL
1723 FX3:PEDAL BEND PITCH
1724 FX3:PEDAL BEND PEDAL POSITION
1725 FX3:PEDAL BEND EFFECT LEVEL
1726 FX3:PEDAL BEND DIRECT LEVEL
1727 FX3:PHASER TYPE
1728 FX3:PHASER RATE
1729 FX3:PHASER DEPTH
1730 FX3:PHASER RESONANCE
1731 FX3:PHASER MANUAL
1732 FX3:PHASER STEP RATE
1733 FX3:PHASER EFFECT LEVEL
1734 FX3:PHASER DIRECT LEVEL
1735 FX3:PITCH SHIFTER VOICE
1736 FX3:PITCH SHIFTER PS1:PITCH
1737 FX3:PITCH SHIFTER PS2:PITCH
1738 FX3:PITCH SHIFTER DIRECT LEVEL
1739 FX3:PITCH SHIFTER PS1:MODE
1740 FX3:PITCH SHIFTER PS1:FINE
1741 FX3:PITCH SHIFTER PS1:PRE-DELAY
1742 FX3:PITCH SHIFTER PS1:LEVEL
1743 FX3:PITCH SHIFTER PS1:FEEDBACK
1744 FX3:PITCH SHIFTER PS2:MODE
1745 FX3:PITCH SHIFTER PS2:FINE
1746 FX3:PITCH SHIFTER PS2:PRE-DELAY
1747 FX3:PITCH SHIFTER PS2:LEVEL
1748 FX3:REVERB TYPE
1749 FX3:REVERB TIME
1750 FX3:REVERB PRE-DELAY
1751 FX3:REVERB EFFECT LEVEL
1752 FX3:REVERB LOW CUT
1753 FX3:REVERB HIGH CUT
1754 FX3:REVERB DENSITY
1755 FX3:REVERB DIRECT LEVEL
1756 FX3:REVERB CARRY OVER
1757 FX3:REVERB SPRING SENS
1758 FX3:RING MOD INTELLIGENT
1759 FX3:RING MOD FREQUENCY
1760 FX3:RING MOD FREQ MOD RATE
1761 FX3:RING MOD FREQ MOD DEPTH
1762 FX3:RING MOD EFFECT LEVEL
1763 FX3:RING MOD DIRECT LEVEL
1764 FX3:ROTARY SPEED SELECT
1765 FX3:ROTARY RATE SLOW
1766 FX3:ROTARY RATE FAST
1767 FX3:ROTARY DEPTH
1768 FX3:ROTARY RISE TIME
1769 FX3:ROTARY FALL TIME
1770 FX3:ROTARY EFFECT LEVEL
1771 FX3:ROTARY DIRECT LEVEL
1772 FX3:SITAR SIM SENS
1773 FX3:SITAR SIM DEPTH
1774 FX3:SITAR SIM TONE
1775 FX3:SITAR SIM EFFECT LEVEL
1776 FX3:SITAR SIM RESONANCE
1777 FX3:SITAR SIM BUZZ
1778 FX3:SITAR SIM DIRECT LEVEL
1779 FX3:SLICER PATTERN
1780 FX3:SLICER RATE
1781 FX3:SLICER TRIGGER
1782 FX3:SLICER EFFECT LEVEL
1783 FX3:SLICER ATTACK
1784 FX3:SLICER DUTY
1785 FX3:SLICER DIRECT LEVEL
1786 FX3:SLOW GEAR SENS
1787 FX3:SLOW GEAR RISE TIME
1788 FX3:SLOW GEAR EFFECT LEVEL
1789 FX3:SLOW GEAR BASS SENS
1790 FX3:SLOW GEAR BASS RISE TIME
1791 FX3:SLOW GEAR BASS EFFECT LEVEL
1792 FX3:SOUND HOLD TRIGGER
1793 FX3:SOUND HOLD RISE TIME
1794 FX3:SOUND HOLD EFFECT LEVEL
1795 FX3:TOUCH WAH FILTER MODE
1796 FX3:TOUCH WAH POLARITY
1797 FX3:TOUCH WAH SENS
1798 FX3:TOUCH WAH FREQUENCY
1799 FX3:TOUCH WAH RESONANCE
1800 FX3:TOUCH WAH DECAY
1801 FX3:TOUCH WAH EFFECT LEVEL
1802 FX3:TOUCH WAH DIRECT LEVEL
1803 FX3:TOUCH WAH BASS FILTER MODE
1804 FX3:TOUCH WAH BASS POLARITY
1805 FX3:TOUCH WAH BASS SENS
1806 FX3:TOUCH WAH BASS FREQUENCY
1807 FX3:TOUCH WAH BASS RESONANCE
1808 FX3:TOUCH WAH BASS DECAY
1809 FX3:TOUCH WAH BASS EFFECT LEVEL
1810 FX3:TOUCH WAH BASS DIRECT LEVEL
1811 FX3:TREMOLO WAVE SHAPE
1812 FX3:TREMOLO RATE
1813 FX3:TREMOLO DEPTH
1814 FX3:TREMOLO EFFECT LEVEL
1815 FX3:TREMOLO DIRECT LEVEL
1816 FX3:VIBRATO RATE
1817 FX3:VIBRATO DEPTH
1818 FX3:VIBRATO TRIGGER
1819 FX3:VIBRATO RISE TIME
1820 FX3:VIBRATO EFFECT LEVEL
1821 FX3:VIBRATO DIRECT LEVEL
1822 FX3:WAH TYPE
1823 FX3:WAH PEDAL POSITION
1824 FX3:WAH PEDAL MIN
1825 FX3:WAH PEDAL MAX
1826 FX3:WAH EFFECT LEVEL
1827 FX3:WAH DIRECT LEVEL
1828 AMP ON/OFF
1829 AMP TYPE
1830 AMP GAIN
1831 AMP SAG
1832 AMP RESONANCE
1833 AMP LEVEL
1834 AMP BASS
1835 AMP MIDDLE
1836 AMP TREBLE
1837 AMP PRESENCE
1838 AMP BRIGHT
1839 AMP GAIN SW
1840 AMP SOLO SW
1841 AMP SOLO LEVEL
1842 AMP SP TYPE
1843 AMP MIC TYPE
1844 AMP MIC DISTANCE
1845 AMP MIC POSITION
1846 AMP MIC LEVEL
1847 AMP DIRECT LEVEL
1848 DISTORTION ON/OFF
1849 DISTORTION TYPE
1850 DISTORTION DRIVE
1851 DISTORTION TONE
1852 DISTORTION LEVEL
1853 DISTORTION BOTTOM
1854 DISTORTION DIRECT LEVEL
1855 DISTORTION SOLO SW
1856 DISTORTION SOLO LEVEL
1857 EQ1 ON/OFF
1858 EQ1 LOW CUT
1859 EQ1 LOW GAIN
1860 EQ1 LOW-MID FREQ
1861 EQ1 LOW-MID Q
1862 EQ1 LOW-MID GAIN
1863 EQ1 HIGH-MID FREQ
1864 EQ1 HIGH-MID Q
1865 EQ1 HIGH-MID GAIN
1866 EQ1 HIGH GAIN
1867 EQ1 HIGH CUT
1868 EQ1 LEVEL
1869 EQ2 ON/OFF
1870 EQ2 LOW CUT
1871 EQ2 LOW GAIN
1872 EQ2 LOW-MID FREQ
1873 EQ2 LOW-MID Q
1874 EQ2 LOW-MID GAIN
1875 EQ2 HIGH-MID FREQ
1876 EQ2 HIGH-MID Q
1877 EQ2 HIGH-MID GAIN
1878 EQ2 HIGH GAIN
1879 EQ2 HIGH CUT
1880 EQ2 LEVEL
1881 MASTER DELAY ON/OFF
1882 MASTER DELAY TYPE
1883 MASTER DELAY TIME
1884 MASTER DELAY FEEDBACK
1885 MASTER DELAY EFFECT LEVEL
1886 MASTER DELAY HIGH CUT
1887 MASTER DELAY DIRECT LEVEL
1888 MASTER DELAY TAP TIME
1889 MASTER DELAY TRIGGER
1890 MASTER DELAY CARRY OVER
1891 MASTER DELAY:DUAL D1 TIME
1892 MASTER DELAY:DUAL D1 FEEDBACK
1893 MASTER DELAY:DUAL D1 HIGH CUT
1894 MASTER DELAY:DUAL D1 EFFECT LEVEL
1895 MASTER DELAY:DUAL D2 TIME
1896 MASTER DELAY:DUAL D2 FEEDBACK
1897 MASTER DELAY:DUAL D2 HIGH CUT
1898 MASTER DELAY:DUAL D2 EFFECT LEVEL
1899 MASTER DELAY:MOD MOD RATE
1900 MASTER DELAY:MOD MOD DEPTH
1901 MASTER DELAY:TWIST MODE
1902 MASTER DELAY:TWIST RISE TIME
1903 MASTER DELAY:TWIST FALL TIME
1904 MASTER DELAY:TWIST FADE TIME
1905 DELAY1 ON/OFF
1906 DELAY1 TIME
1907 DELAY1 FEEDBACK
1908 DELAY1 EFFECT LEVEL
1909 DELAY1 HIGH CUT
1910 DELAY1 DIRECT LEVEL
1911 DELAY1 CARRY OVER
1912 DELAY2 ON/OFF
1913 DELAY2 TIME
1914 DELAY2 FEEDBACK
1915 DELAY2 EFFECT LEVEL
1916 DELAY2 HIGH CUT
1917 DELAY2 DIRECT LEVEL
1918 DELAY2 CARRY OVER
1919 REVERB ON/OFF
1920 REVERB TYPE
1921 REVERB TIME
1922 REVERB PRE-DELAY
1923 REVERB EFFECT LEVEL
1924 REVERB LOW CUT
1925 REVERB HIGH CUT
1926 REVERB DENSITY
1927 REVERB DIRECT LEVEL
1928 REVERB CARRY OVER
1929 REVERB SPRING SENS
1930 NOISE SUPPRESSOR ON/OFF
1931 NOISE SUPPRESSOR THRESHOLD
1932 NOISE SUPPRESSOR RELEASE
1933 NOISE SUPPRESSOR DETECT
1934 FOOT VOLUME1 VOLUME MIN
1935 FOOT VOLUME1 VOLUME MAX
1936 FOOT VOLUME1 VOLUME CURVE
1937 FOOT VOLUME1 PEDAL POSITION
1938 FOOT VOLUME2 VOLUME MIN
1939 FOOT VOLUME2 VOLUME MAX
1940 FOOT VOLUME2 VOLUME CURVE
1941 FOOT VOLUME2 PEDAL POSITION
1942 CHORUS ON/OFF
1943 CHORUS MODE
1944 CHORUS RATE
1945 CHORUS DEPTH
1946 CHORUS PRE-DELAY
1947 CHORUS EFFECT LEVEL
1948 CHORUS WAVEFORM
1949 CHORUS LOW CUT
1950 CHORUS HIGH CUT
1951 CHORUS DIRECT LEVEL
1952 CHORUS RATE1
1953 CHORUS DEPTH1
1954 CHORUS PRE-DELAY1
1955 CHORUS EFFECT LEVEL1
1956 CHORUS WAVEFORM1
1957 CHORUS LOW CUT1
1958 CHORUS HIGH CUT1
1959 CHORUS RATE2
1960 CHORUS DEPTH2
1961 CHORUS PRE-DELAY2
1962 CHORUS EFFECT LEVEL2
1963 CHORUS WAVEFORM2
1964 CHORUS LOW CUT2
1965 CHORUS HIGH CUT2
1966 CHORUS OUTPUT MODE
1967 COMPRESSOR ON/OFF
1968 COMPRESSOR TYPE
1969 COMPRESSOR SUSTAIN
1970 COMPRESSOR ATTACK
1971 COMPRESSOR EFFECT LEVEL
1972 COMPRESSOR DIRECT LEVEL
1973 COMPRESSOR TONE
1974 SEND/RETURN ON/OFF
1975 SEND/RETURN MODE
1976 SEND/RETURN SEND LEVEL
1977 SEND/RETURN RETURN LEVEL
1978 SEND/RETURN ADJUST
1979 SEND/RETURN PHASE
1980 DIVIDER MODE
1981 DIVIDER CH SELECT
1982 MIXER A/B BALANCE
1983 MIXER A:PAN
1984 MIXER B:PAN
1985 BALANCER 1 A/B BALANCE
1986 BALANCER 1 A:PAN
1987 BALANCER 1 B:PAN
1988 BALANCER 2 A/B BALANCE
1989 BALANCER 2 A:PAN
1990 BALANCER 2 B:PAN
1991 BALANCER 3 A/B BALANCE
1992 BALANCER 3 A:PAN
1993 BALANCER 3 B:PAN
1994 MAIN OUT MAIN OUT PHASE
1995 MAIN OUT MAIN OUT R PHASE
1996 SUB OUT SUB OUT PHASE
1997 SUB OUT SUB OUT R PHASE
1998 MIDI MIDI CC#
1999 MIDI MIDI PC#
Might allow older mac users to use SY-1000 and Boss Tone Studio
How to Install macOS 10.14 Mojave on an Unsupported Mac
http://dosdude1.com/mojave/
Quotevtgearhead said: ↑
Essentially, yes. Mac OS X checks the hardware during early boot and refuses to proceed if it thinks you need to spend more money. Fortunately, a smart guy with the nickname DosDude developed a workaround that has allowed me to run Mojave on my 2008 Mac Pro 3,1. It's still more than adequate for DAW use and has outlasted about three Windows boxes.
Choose which active input to use when creating patches
GK 13 pin input
or
1/4" Guitar Input
Go to MASTER block at End and Toggle "Change Patch Type"
FWIW - The Normal Input has 10 memory slots to Store Normal Input Settings
Likewise the  The GK Input has 10 memory slots to Store GK Input Settings
Be sure to click "WRITE" to save each setting
One of the KNOBS under the LCD may be assigned to allow the user to to select the current desired NORMAL INPUT Setting
Another  KNOB under the LCD may be assigned to allow the user to to select the current desired GK Setting
Both these INPUT SETTINGS should have the options for GK SET (1-10)  / NORMAL SET (1-10) to be stored in the current SY-1000 patch,(as provided in the  VG-99)
and/or able for GK SET (1-10)  / NORMAL SET (1-10) to be Assignment Targets for MIDI CC# Control
INPUT SETTING GK SET (1-10)
INPUT SETTING NORMAL SET (1-10)
Instead of these settings being strictly a  SYSTEM Common Global assignment only accessible with one of the Knobs
https://www.vguitarforums.com/smf/index.php?topic=26924.msg203104#msg203104
SY-1000 MIDI Implementation
https://static.roland.com/assets/media/pdf/SY-1000_MIDI_Implementation.pdf
Each of the Knobs under the LCD display may be mapped to specific user functions on each patch
* TABLE 1 : KNOB SETTING TABLE FOR GUITAR MODE
# CATEGORY TARGET
0 PATCH PATCH SELECT
1 TUNER ON/OFF
2 MASTER BPM
3 MASTER KEY
4 MASTER PATCH LEVEL
5 CONTROL MODE CONTROL MODE
6 INPUT SETTING GK SET
7 INPUT SETTING NORMAL SET
8 OUTPUT SETTING MAIN OUTPUT-L LEVEL
9 OUTPUT SETTING MAIN OUTPUT-R LEVEL
10 OUTPUT SETTING MAIN OUTPUT-L SELECT
11 OUTPUT SETTING MAIN OUTPUT-R SELECT
12 OUTPUT SETTING SUB OUTPUT-L LEVEL
13 OUTPUT SETTING SUB OUTPUT-R LEVEL
14 OUTPUT SETTING SUB OUTPUT-L SELECT
15 OUTPUT SETTING SUB OUTPUT-R SELECT
16 TOTAL TOTAL REVERB LEVEL
17 TOTAL TOTAL NS THRESHOLD
18 MAIN GLOBAL EQ L/S LOW CUT
19 MAIN GLOBAL EQ L/S LOW GAIN
20 MAIN GLOBAL EQ L/S LOW-MID FREQ
21 MAIN GLOBAL EQ L/S LOW-MID Q
22 MAIN GLOBAL EQ L/S LOW-MID GAIN
23 MAIN GLOBAL EQ L/S HIGH-MID FREQ
24 MAIN GLOBAL EQ L/S HIGH-MID Q
25 MAIN GLOBAL EQ L/S HIGH-MID GAIN
26 MAIN GLOBAL EQ L/S HIGH GAIN
27 MAIN GLOBAL EQ L/S HIGH CUT
28 MAIN GLOBAL EQ R LOW CUT
29 MAIN GLOBAL EQ R LOW GAIN
30 MAIN GLOBAL EQ R LOW MID FREQ
31 MAIN GLOBAL EQ R LOW MID Q
32 MAIN GLOBAL EQ R LOW MID GAIN
33 MAIN GLOBAL EQ R HIGH MID FREQ
34 MAIN GLOBAL EQ R HIGH-MID Q
35 MAIN GLOBAL EQ R HIGH-MID GAIN
36 MAIN GLOBAL EQ R HIGH GAIN
37 MAIN GLOBAL EQ R HIGH CUT
38 SUB GLOBAL EQ L/S LOW CUT
39 SUB GLOBAL EQ L/S LOW GAIN
40 SUB GLOBAL EQ L/S LOW-MID FREQ
41 SUB GLOBAL EQ L/S LOW-MID Q
42 SUB GLOBAL EQ L/S LOW-MID GAIN
43 SUB GLOBAL EQ L/S HIGH-MID FREQ
44 SUB GLOBAL EQ L/S HIGH-MID Q
45 SUB GLOBAL EQ L/S HIGH-MID GAIN
46 SUB GLOBAL EQ L/S HIGH GAIN
47 SUB GLOBAL EQ L/S HIGH CUT
48 SUB GLOBAL EQ R LOW CUT
49 SUB GLOBAL EQ R LOW GAIN
50 SUB GLOBAL EQ R LOW-MID FREQ
51 SUB GLOBAL EQ R LOW-MID Q
52 SUB GLOBAL EQ R LOW-MID GAIN
53 SUB GLOBAL EQ R HIGH-MID FREQ
54 SUB GLOBAL EQ R HIGH-MID Q
55 SUB GLOBAL EQ R HIGH-MID GAIN
56 SUB GLOBAL EQ R HIGH GAIN
57 SUB GLOBAL EQ R HIGH CUT
58 USB AUDIO MAIN MIX LEVEL
59 USB AUDIO SUB MIX LEVEL
60 USB AUDIO IN LEVEL
61 USB AUDIO OUT LEVEL
62 USB AUDIO USB AUDIO ROUTING
63 USB AUDIO USB IN POSITION
64 USB AUDIO USB OUT POSITION
65 GUITAR TO MIDI GUITAR TO MIDI SW
IMPORTANT Info for using Boss Tone Studio for SY-1000 to create a User Patch
szilard wrote>
Roland often has a temporary area for the patch that is selected. And you have to select a patch to edit it.
Editing occurs in the temporary patch area.
This seems to be the case with the SY-1000.
I usually start sound design with Write->Clear and when you do this you get the message The temporary tone setting will be initialized.
If you switch to another patch, the original patch that you cleared is restored.
I often do this when noodling around and recording.
So editing isn't changing a patch; the patch isn't changed until you write it.
I haven't created any livesets with the 1000 yet, but BTS looks similar to the 300.
In creating a liveset you specify a patch and it is read out of HW and saved in the liveset.
Based on what you wrote you get the results I would expect.
You need to write your changes before you save them to a liveset.
Internal View
Switch
SY-1000 / GT-1000 appear to use these type PCB Mount Momentary Switch for the Footswitches
https://www.amazon.com/Momentary-Tactile-Through-Breadboard-Friendly/dp/B07WF76VHT/ref=ac_session_sims_328_3/133-3627959-3894751
Is Roland / Boss Product disconnecting from Windows PC  after 10 minutes?
ANSWER VALID FOR ALL WINDOWS :
Go to the classic device manager. Here since windows 10 :
"C:\Windows\System32\control.exe"
In USB controllers, double-click EACH component to open its properties.
Once in the properties panel of the USB component, go to the "Power" tab and check that the USB devices do not exceed the consumption of the USB port which is usually 500mah. I had this problem because my wifi antenna was consuming 200mah and was plugged in hub with another device that was consuming 450mah, so we were above 500mah and it was constantly bugging.
Then check in the "power management" tab that the computer is not allowed to turn off a component to save power.
WARNING: try to take your time to do all the checks on each USB component, so you won't forget anything. There you go, I hope that those I've seen struggling for a long time will come by. I think this solution is the right one, I tried everything, it's only with this one that I'm finally quiet ;)
hoping it'll help you. ;)
Ps: The explanations in the links are in French and can be easily understood by all.
Quote from: JiveTurkey, post: 30108783, member: 126265Dumb question. Admittedly up front. I've rtfm but maybe I am misreading :anon I should know how this works by now so apologies in advance.
Can I connect 2 FS6 dual switches to the SY? Or just one? I would like to have 4 switches at my feet if possible but the manual makes it look like only one can be connected. Thanks in advance.
(^ image courtesy of Gumtown)
Which Footswitch do I need? .. Latch or Unlatch?
SY-1000 assign  [toggle] + FS-7  [Latch] = double latching, pedal requires 2 presses to do one function (effect on/off)
SY-1000 assign  [toggle] + FS-7  [Moment] = press once to toggle effect on/off, pedal led only lights while held down
SY-1000 assign  [moment] + FS-7  [moment] = effect only on while pedal held down, pedal led only on while held down
SY-1000 assign  [moment] + FS-7  [Latch] = press once to toggle effect on/off, pedal led toggles with effect status
