Fishmann Triple Play connect and logic?
Started by Portos123, August 28, 2022, 03:05:52 AM
Portos123
Hi,
I just signed up, but I have been a curious reader for years now and found so many solutions for my problems on this site. Hope this is the right topic.
I just bought a Fishman connect and I would like to use it in logic in a way so I can split each string on separate channels and use different VST instruments with it. Has someone experience with splitting the pick up different channels inside logic?
Thanks in advance
ITL
What I do is put each string on a separate midi track(so 6 tracks) in Logic and or (Mainstage for that matter) and then assign each string/track to a different midi channel (i.e. 1-6) . You can then use a different VST on each string/channel.  Hope this helps.
LGXTSA, Godin Session Custom TriplePlay w/ Fishman Piezo, JTVariax59, Axe-FXII, Integra 7, Motif XS, VoiceLive 3
