Ampero expression pedal issues
Started by Jsanz, November 04, 2019, 12:26:05 AM
Jsanz
I'm having some issues with the expression pedal in the Ampero when using for wah. It doesn't sound smooth at all. It jumps so it's not a gradual change,more like steps throughout the whole range. This is more noticeable with distortion and when moving quickly the pedal up and down..I have upgraded to latest firmware as of the tone I'm writing this so wondering if anyone else has noticed this? Do I have a faulty pedal?
Another problem: if I assign fx1 to the exp pedal, and select cry wah for fx1 for example, it works. But if I then change fx1 to a different wah effect, the pedal doesn't do anything. I have to go back to the ctrl/exp and reassign to the same fx1 for it to work. This looks like a bug to me, as you can't check out different wah sounds without a lot of button presses and navigating back and forth menus... any help?
Contact hotone
service@hotoneaudio.com
