GK2/3 raw recordable output from the US-20 signal splitter
Started by Vholiik, September 11, 2019, 12:45:38 PM
Vholiik
Has Roland or anybody else created a box to independently record the raw signals from the gk2/3 as six independant outputs?  And would said junction box be capable of sending the signals back in to be processed by any VG or GR synths?  Any info on wire specs of the 13 pin cable so I can make one myself?   I would use the US-20 stomp selector to simultaneously record the raw six signals from the gk2/3 pickup.  The raw signals then could be edited and cleaned up manually from a DAW and sent/bounced back into VG/GR synths or be used to create independant effects from plugins and/or outboard pedal/racks.  I have been wanting to do this ever since I bought my first GR1 back in 1993.
CodeSmart
QuoteHas Roland or anybody else created a box to independently record the raw signals from the gk2/3 as six independent outputs?
Boss GP-10 works as a 8 in  / out out USB Audio interface for real time processing of each guitar string on your PC/Mac with third party tools
https://www.vguitarforums.com/smf/index.php?topic=11796.0
Or
for analog I/O
BilBax Separate Strings
https://www.vguitarforums.com/smf/index.php?board=182.0
or use a RMC Fanout box
https://www.vguitarforums.com/smf/index.php?board=177.0
or Spicetone 6Appeal
https://www.vguitarforums.com/smf/index.php?topic=12104.0
or Wayne Joness boxes
https://www.vguitarforums.com/smf/index.php?board=178.0
others  found here
GK Accessories
https://www.vguitarforums.com/smf/index.php?board=13.0
most are only available in the used gear channels
