Mooor GE300 - USB Class Compliant Audio/MIDI
Started by admin, August 21, 2019, 09:39:00 PM
GE300 24 bit USB recording to Android 8.0 LG V20 smartphone with "Field Recorder" (android) app.
Using only Cable Creations USB-C (LG V20) to USB Type B ( GE300) cable)trivia MOOER is Chinese abbreviation for "Magic Ear". (
This is the USB-C to USB-B cable I used
https://www.amazon.com/CableCreation-Printer-Compatible-MacBook-Printers/dp/B012V563B6/
Here is Field Recorder app
https://play.google.com/store/apps/details?id=de.pfitzinger.rec&hl=en_US&referrer=utm_source%3Dgoogle%26utm_medium%3Dorganic%26utm_term%3Dandroid+field+recorder
(Android Music Creation  /Audio / MIDI  Apps)
https://www.vguitarforums.com/smf/index.php?board=211.0
1) Power on GE300
2 ) Insert the USB Client "B" side of the USB cable to the GE300
3) With LG V20 smartphone ( Android 8.0) powered on , insert the USB-C side of the USB cable to the LG V20,
4) Upon USB connection, the LG V20 recognizes the GE300 as a 24 bit USB Audio / MIDI Device, and a pop up message asks which app should be launched ( I have several Android Audio / MIDI apps ) I chose "Field Recorder"
5 ) Field Recorder app launches, and it showed the connected audio device as "GE300 24 bit @ 96kHz Stereo USB Audio" and I recorded GE300 3 minutes as a test.
6) I hit stop , and rewind, and upon hitting"Play" ,, clean recorded audio is heard from the GE300 headphones jack.
7) i closed "Field Recorder app", and tried my other Android audio apps - they all worked with GE300 as my audio / MIDi Interface
8 ) I tested GE300 MIDI over USB transmission with an app called "MIDI Monitor" - and saw that with each patch change, GE300 transmits MIDI Program Change ( PC) messages
9) I moved all knobs and switches to see if GE300 transmits any default MIDI CC messages, but none were detected
(MacOS/ OSX)   - tested GE300 with my Macbook Pro , and GE300 was recognized as 2 in /2 out 24 bit USB Audio / MIDI device  - recorded test track in Logic-X DAW
IOS/iPad)  - Sadly on my IOS Devices there are problems I get an error pop up " GE300 device not compatible"  - even using the Apple Lightning USB 3 Adapter with external Power
-despite the error message, IOS Apps can playback using the GE300 as a USB Audio DAC, but recording on IOS from GE300 does not appear to work on iPad/ iPhone ( running IOS 12)
On WIndows,  - must install the MOOER GE300 ASIO driver
Recording 24 bit USB Audio (USB Class Compliant) from Mooer GE300, into 2020 Apple iPad Pro 12.9 using a USB-C Hub.
Works very well , using this USB-C Hub
https://www.amazon.com/gp/aw/d/B0915B3NPY
