VG-8 - Background noise through amp(grounding issue)
Started by VGXPL_1908, July 01, 2019, 02:57:51 PM
VGXPL_1908
VG-8, GK-2A
I'm having what appears to be a grounding issue with my VG8/GK2A.  There is a large amount of feedback and a muddy sound, particularly through an amp or (through the mix-out mono).
I've double checked and verified all the system settings, and manual and everything looks to be correct, so that doesn't appear to be the issue.
The other issue I am having is the guitar only and mix channel is not coming through when selected.  I replaced the GK2 to guitar wire, and the guitar pickups will only come with some significant jiggling.
I'm hoping both of these issues is just with the GK2A, (or something I've missed in the setup) but I'm worried it could be with the VG.  Has anyone experienced this or have any suggestions before I start buying random parts 🤣?
Quote from: VGXPL_1908 on July 01, 2019, 02:57:51 PM
VG-8, GK-2A
I'm having what appears to be a grounding issue with my VG8/GK2A.  There is a large amount of feedback and a muddy sound, particularly through an amp.
I've double checked and verified all the system settings and they look to be correct, so that doesn't appear to be the issue.
I'm hoping both of these issues is just with the GK2A, but I'm worried it could be with the VG.  Has anyone experienced this or have any suggestions before I start buying random parts 🤣?
squealing microphonic high pitched Feedback = must wax dip your GK Pickup
https://www.vguitarforums.com/smf/index.php?topic=43.0
Hum - Noise solutions
Fix your Audio Ground Loop Buzzes and Noises
https://www.vguitarforums.com/smf/index.php?topic=2078.0
QuoteThe other issue I am having is the guitar only and mix channel is not coming through when selected.  I replaced the GK2 to guitar wire, and the guitar pickups will only come with some significant jiggling.
Must maintain the GK VOL control assignment set to Patch level on the VG-8  - else the three way Guitar/Mix/Synth switch will cease working
https://www.vguitarforums.com/smf/index.php?topic=2246.msg12877#msg12877
VGXPL_1908
Quote from: admin on July 01, 2019, 03:06:08 PM
Thanks man!  This could be it as it's been a while since I've used it, let alone not just  through MIDI.
I'm also looking into the driver settings as it's on a new guitar than it was previously, (in hind sight I that was pretty dumb of me not to do earlier 🤣)
Quote from: VGXPL_1908 on July 01, 2019, 03:15:54 PM
1st backup any old User patches
https://www.vguitarforums.com/smf/index.php?action=downloads;cat=22
Often things clear up after a VG-8 Factory reset
https://www.sweetwater.com/sweetcare/articles/roland-vg-8-initializing-vg-8-restoring-factory-settings/
Roland VG-8 Initializing the VG-8 – Restoring the Factory Settings
Article #1706352 Added on Mar 20, 2012 at 3:11 PM
The following procedure can be used to clear the internal memory and reload the
factory settings:
(CAUTION: All USER information will be lost. Be sure to back up any information
you wish to keep.)
1) Hold down F1, F3 and F5 while powering up.
2) Press F4 [Patches] (to restore only factory patches), F2 [System] (to
restore only factory system parameters,) or F6 [All] (to restore all factory
settings).
QuoteThanks man!  This could be it as it's been a while since I've used it, let alone not just  through MIDI.
FWIW - there is no MIDI used on the GK-2A or the GK 13 pin cable and VG-8 does not function using MIDI Note on/off messages
How a "13pin MIDI Cable" destroyed the Roland V-Guitar DSP Modeling brand
https://www.vguitarforums.com/smf/index.php?topic=14088.0
