GT-001 - changing patches with external click
Started by Carlos Velho, June 05, 2019, 06:49:11 AM
Carlos Velho
I found if I conect a stereo jack in GT 001 I can change the patches by opening and closing the ground with the 2 positive ones. My question is if it can be dangerous in any way to GT 001. Thanks in advance for any answer.
There is no danger to the GT-001 unless there is static discharge or excessive voltage applied.
You might want to solder some switches on the ends of the wire though.
The CTL/EXP socket on the GT-001 is designed for external control switches or an Expression pedal.
Length of the remote switch cable may be an issue  =- use the shortest possible
