Hotone - Hotone Friday
Started by admin, April 26, 2019, 07:55:51 AM
Hotone -  Hotone Friday -last Friday of the month Hotone releases updates
Hotone Friday April 2019
Free Choptones ,Dimitry patches
http://hotoneaudio.com/news/322.html
New Ampero Owners manual
http://www.hotoneaudio.com/downloads/manual/Ampero/MP-100%28Ampero%29_Online%C2%A0Manual_EN_V03_1900314.pdf
Reports are good that in less than 24 hours, Hotone will release new Ampero Firmware V3.0 as part of their traditional last Friday of the month batch of new releases  - they call:
"Hotone Friday May Edition"
https://www.thegearpage.net/board/index.php?posts/28596078/
Rico Lee wrote>
The information comes from my friends in China,Hotone will release new firmware V3.0 on May 31. With a little happiness, this may be the best children's day gift.
1. manage signal chain in Edit menu (change order of FX)
2. Improve Tuner reaction speed
3. control USB recording level (Global > USB Audio, Direct Monitor on/off) )
4. set No Cab Mode separately on either L/R channel (Global > I/O)
5.Improve the sound quality of several effects in FX1 and FX2
check here
https://hotoneaudio.com/news/327.htmlAmpero Firmware 3.0
New Features
1. You can now manage your signal chain in Edit menu by double clicking on a module
2. You can connect external footswitch controller to EXP 2 (EXP 2/FS) jack – EXP 2/FS settings added in Global menu for setting footswitch functions and EXP 2/FS jack functions
3. Wait mode added when switching between banks (for external footswitch only)
4. You can now control USB recording level (Global > USB Audio)
5. You can now set No Cab Mode separately on either L/R channel (Global > I/O)
Improvements & Changes
1.Screen Lock function changed to Device Lock function for locking touch screen, MENU/VALUE knob (Main Knob) and Quick Access Knobs
2.Greatly optimized Tuner reaction speed
3.Improved dynamic range and sound quality of these amp modeling effects: Tweed Lux, Baseman Norm, Baseman Bright, Black Twin, Voxy 30HW Norm, Voxy 30HW TB, Superstar Clean, Superstar Drive, Glacian Clean, Glacian Drive
4.Improved the sound quality of several effects in FX1 and FX2
5.BRIGHT switch added for Black Twin and Glacian Clean
6.The Presence control of Superstar Drive changed to Drive control for more wider tonal range
7.Optimized built-in expression pedal stability
8.Optimized USB Audio performance and stability
9.General performance and stability improvements
Bug Fixes
1. When editing presets, some effect parameters may go wrong – FIXED
2. Recorded data may be lost when using Looper – FIXED
3. In some cases, Ampero may crash when setting external expression pedal (EXP 2) – FIXED
4. Factory Reset cannot be selected by MENU/VALUE knob (Main Knob) in Global menu – FIXED
5. Minor bug fixes
PrecautionThis Ampero V3.0 firmware update is Ampero's major update containing more powerful features (e.g. MANAGABLE SIGNAL CHAIN), optimized system performance and bug fixes. We recommend all Ampero users to execute this update for the best possible user experience.
IMPORTANT - Use V3.0 firmware with Ampero Editor V1.2.0 ONLY. The patches of the earlier firmware versions are now not compatible with this V3.0 firmware due to the new features and fatal changes, which means, after updating firmware, ALL YOUR PATCHES IN YOUR AMPERO WILL BE REPLACED BY THE NEW FACTORY/USER PATCHES, AND YOUR CUSTOM IR FILES WILL ALSO BE CLEARED.
Please be sure to export the patches you want to keep by using earlier Ampero Editor software before updating. After updating, you can import them via new Ampero Editor (The Editor will automatically convert your old patch files to new version so that you can use them with V3.0 firmware).
If you accidentally updated to the new firmware before backing up your patches, to get the old patches back, you can roll back to earlier firmware versions (load earlier firmware files when updating) before you edit/save patches with new firmware.
2.Ampero Editor
Version 1.2.0
Released 5/31/2019
New Features
+ You can now manage your signal chain by clicking "Manage Signal Chain" button
+ You can now import user IR file with any bit depth/sample rate
+ You can now set No Cab Mode in Settings > Global
+ You can now check solution methods by clicking "Device Not Found" button when Ampero Editor cannot recognize your device
+ EXP 2/FS settings added in Settings > Global
Improvements & Bug Fixes
+ Some effects in Effect List have no image – FIXED
+ Some effects in Effect List have wrong images – FIXED
+ Optimized USB communication stability between computer and Ampero unit
Precaution
IMPORTANT - Use V3.0 firmware with Ampero Editor V1.2.0 ONLY. The new software will no longer recognize Ampero units with previous firmware (V2.1 and earlier).
