GR-55 - Octave Divider Bass
Started by marksmartus, April 13, 2019, 08:09:08 AM
marksmartus
Bass patch using octave divider effect on normal pickups.
Mark Smart
mark@marksmart.net
marksmartus
Here is the patch in text format:
GR55 Patch Name = Divider Bass
TONE
  PCM1 Switch = Off
  PCM2 Switch = Off
  MODEL Switch = Off
  NORMAL PICKUP Switch = On
    Tone Level = 100
EFFECT
  STRUCTURE 1
  AMP Switch = On
    Type = TW Clean     Presence = 0
    Gain = Middle       Bright Sw = Off
    Level = 99          Speaker Type = Off
    Gain Sw = 25        Mic Type = Flat
    Solo Sw = Off       Mic Distance = On mic
    Solo Level = 50     Mic Position = 5
    Bass = 97           Mic Level = 100
    Middle = 0
    Treble = 0
  MOD Switch = On
    Pan = Center
    Effect = On
    Effect Type = Octave
      Octave Level = 50
      Direct Level = 34
    NS Switch = On
    NS Threshold = 40
    NS Release = 30
  MFX Switch = Off
  DELAY Switch = Off
  REVERB Switch = On
    Type = Hall 1
    Time = 2.0S
    High Cut = 6.0K
    Level = 83
    MFX Send = 100
    MOD Send = 48
    Bypass Send = 30
  CHORUS Switch = Off
EQ Switch = On
    Lo Cut = Flat            Hi Mid Freq = 4.00K
    Low Gain = 4dB           Hi Mid Q = 1
    Lo Mid Freq = 500 Hz     Hi Mid Gain = 0dB
    Lo Mid Q = 1             High Gain = 5dB
    Low Mid Gain = 0dB       High Cut = Flat
                             Level = 12dB
                             Character = 0
MASTER
  PEDAL GK CTL
    CTL                        EXPSW
      Status = Off               Status = Off
    EXP                        GKS1
      Function =                 **SYSTEM**
    EXPON                      GKS2
      Function = Pitch Bend     **SYSTEM**
      Depth = 12               GKVOL
      PCM Tone 1 = On           **SYSTEM**
      PCM Tone 2 = On
      Modelling Tone = Off
  ASSIGN
    ASSIGN 1 Switch = Off
    ASSIGN 2 Switch = Off
    ASSIGN 3 Switch = Off
    ASSIGN 4 Switch = Off
    ASSIGN 5 Switch = Off
    ASSIGN 6 Switch = Off
    ASSIGN 7 Switch = Off
    ASSIGN 8 Switch = Off
  OTHER
    Patch Level = 17
    Patch Tempo = 90
    GK Set Select =
    Guitar Out Source = System
    ALT Tuning Switch = Off
    ALT Tuning Type = Open D
    V-Link Pallet = LAST
    V-Link Clip = LAST
    V-Link Note Clip = 1
    EXP = Bright
    EXP ON = Play Speed
    GK VOL = Off
Mark Smart
mark@marksmart.net
