Software reset for Arduino
Started by philjynx, March 17, 2019, 03:42:01 PM
philjynx
depends on the Arduino CPU type.
for the Teensy LC or 3.1 it is
SCB_AIRCR = 0x05FA0004;
which will initiate self destruct and reboot the hardware from a cold start.
Would a register/ peripherals flush routine be more elegant ?
another option is a power off reset button (normally closed PB).
If you are using a Nano, you are out of luck, unless you flash it with the UNO boot-loader, and use a WDT routine + the hardware reset input pin.
