GR-55-acoustic 12 w/soft strings + electric guitar
Started by plexified, January 31, 2019, 08:13:55 PM
plexified
Finally got into the Librarian to upload a few patches. This one has the acoustic 12 string with some soft strings and electric guitar. The control settings are not set up and hence the MOD is off with the electric part I was messing with, but just something to check out. The AMP is used as a buffer and is boosted with a Dist Pedal in the Mod. You can plug in a MS1959 and tweak the settings as well. I use that one a lot as a tube buffer amp / Guitar amp with mild crunch and either use the solo switch or the MOD distortion to interject.
