New to Variax...What now?
Started by futuresman, January 16, 2019, 10:01:19 AM
futuresman
Hi All,
I recently picked up a JTV59 (used) and want to get going on optimizing it with my Helix LT. I'm curious as to normal "first steps" etc. Like should I upgrade to the latest version (2.0 I thin) in order to use Workbench. I would like to try some of the bundles (variax) that I found here on another thread, so do I have to have a certain version to make that work. Meaning, how do I download those bundles, then upload them to myJTV59. I assume I need Workbench to do it all, but want to make sure I have all the right software/firmware version and the process down. Any input is greatly appreciated!
Quote from: futuresman on January 16, 2019, 10:01:19 AM
Hi All,
The the JTV-59 was 1st sold to the original owner - it came with the Line-6 Workbench USB box and VDI adapter cables
after 2012  - this version was included
Sadly these important bits often get lost and not included with (used) JTV-59
if you do not own the Workbench USB adapter  - then
*Update Firmware in Helix LT to (latest version)
* Install the Helix LT USB Driver
* Install the Helix Edit  - to verify your Helix LT is working  / communicating over USB
* Download Line-6 Monkey app (latest version)
* Use a genuine VDI cable to connect JTV-59 to the VDI input on the Helix LT
* Be sure you are connected to the internet
* Run Line-6 Monkey, and follow the instructions to update your JTV-59 to latest version and follow the procedure here
https://line6.com/support/page/kb/guitars/james-tyler-variax-guitars/variax-reflash-and-software-update-instructions-r103/
QuotePlease go through the following checklist before updating the flash memory of your Variax guitar to ensure the update completes successfully:
Ensure that the interface you are using to update the Variax with (Workbench Interface, Helix LT) isNOT connected to the computer through a USB hub.
Make sure to connect the interface into a USB port directly into the computer, especially into the back of a desktop.
If problems persist, make sure to test all of the USB ports on the computer.
Avoid plugging into USB ports found on keyboards, monitors, or laptop docks.
  • When using the Workbench Interface to update or edit the Variax guitar, ensure that a charged battery is in the guitar and a 1/4" TS mono cable is inserted into the guitar's output jack, or that the stereo TRS cable is plugged into the Variax providing power from the XPS power supply to power on the guitar.
  • On a James Tyler Variax guitar, ensure that the Volume knob on the guitar is NOT set to the '0' position as it will put the guitar into Power Save Mode. Make sure that the Volume knob is set higher than 0 when updating or editing the JTV guitar.
  • Please use the VDI Cable that comes with the JTV guitar when updating the flash memory on that guitar. Avoid using VDI or CAT5 cables longer than 10 ft. in length when updating any Variax guitar.
  • During the update, select 'NO' when asked if you would like to keep the presets on the guitar. Use the Workbench software to back up your guitar presets before updating if you would like to keep them.
  • Close out any other applications running on your computer before updating the Variax guitar.[/i]
* Install Workbench HD
https://line6.com/support/forum/39-james-tyler-variax-guitars-workbench-hd/
* Enjoy the Variax HD Patch files we host here
https://www.vguitarforums.com/smf/index.php?board=138.0
futuresman
Mine actually came with the connections in the 2nd pic so I can use those
So I should:
- update Helix to latest
- update Variax to latest
- install Workbench HD
In that order?
Thanks for the help btw
In  that case  - I would use your "Workbench HD USB Interface
1 ) Run the latest Line-6 Monkey for your OS
https://line6.com/software/index.html
And find more answers at the official Line-6 Tyler Variax Forum
