Zoom H3-VR
Started by admin, September 13, 2018, 11:37:17 AM
Zoom H3-VR
https://www.bhphotovideo.com/explora/audio/news/the-zoom-h3-vr-handy-recorder-goes-beyond-vr-recording
Zoom is turning heads with the announcement of its latest handy recorder, the H3-VR, which not only records in Ambisonics format, but also offers binaural stereo, standard stereo, 5.1 surround support, and live streaming. What's more, the recorder is self-contained and provides a fast and easy way to record 360-audio and monitor in real time. Whether you are a filmmaker, musician, or gamer, 360-audio is the undeniable future of content creation.
In the past, capturing VR audio required a dedicated Ambisonics microphone, a separate recorder, and a computer for decoding the audio from raw Ambisonics A format to VR-ready Ambisonics B format. The H3-VR offers a simple and elegant solution, allowing for fast setup and easy processing. The recorder can even adjust the audio rotation of the Ambisonics playback for an unprecedented amount of control.
The H3-VR's four-capsule microphone captures 360-degree audio recordings, precisely, up to 24-bit/96 kHz. The binaural setting provides a hyper-realistic spatial recording that enhances 2D productions with 3D audio. And compared to procuring a very expensive binaural head, the H3-VR offers an incredible value proposition for binaural recordings.
The conical enclosure is lightweight (120g) and features a backlit LCD screen that automatically adjusts to the unit's positioning. The two independent 3.5mm audio outputs with dedicated volume controls provide headphone monitoring and a line out to a camera, while the input volume gain easily adjusts the gains for all four mic capsules simultaneously. The precision internal clock is highly accurate, with 0.5 ppm discrepancy to reduce audio/visual drift and jitter. Onboard transport controls provide quick access to Home, Play/Pause, Forward, Reverse, and Menu buttons. The built-in limiter prevents clipping and distortion during dynamic moments, while the high-pass filter removes unwanted low-end frequencies and rumble. The onboard SD card slot accept cards up to 512GB, allowing for the recorder to operate in stand-alone fashion. The H3-VR can be powered by two AA batteries for up to 24 hours. For longer recording time, the unit can be connected via USB into an AC adapter or host device.
The H3-VR can also function as a high-quality stereo microphone for live-streaming, video conferencing, and direct recording for your computer or iOS device. Should you wish to control the recorder remotely, an optional Bluetooth adapter (BTA-1) allows the H3-VR Control application to access transport controls, set levels, and input metadata notes directly from the iOS device. The companion Zoom Ambisonics Player software (Mac/Windows) takes the work out of post-production by easily converting the Ambisonics files to stereo, binaural, and 5.1 surround; allowing you to play, trim, re-orient, and export your audio files in minutes. The H3-VR ships with a foam windscreen, dual mount adapter, and two AA batteries.
Expected End of October 2018
https://www.bhphotovideo.com/c/product/1434530-REG/zoom_zh3vr_h3_vr_360_vr_audio.html
vanceg
That's pretty interesting.  I was just ordering a tetra mic and a Sennheiser.... but for our basic VR capture field recording systems, this looks like a great idea.
Quote from: vanceg on September 13, 2018, 02:51:50 PM
FWIW - Zoom has partnered with Sennheiser , and created new firmware for F8/F4 to support the Sennheiser AmbeoVR Mic
https://www.zoom.co.jp/news/AmbeoVR
https://ir.zoom.co.jp/news/auto_20170915474149/pdfFile.pdf
mooncaine
Thanks so much for sharing that! I am pretty intrigued.
FWIW   -Zoom H3-VR on sale for $299 at B&H  - limited time
  Zoom H3-VR Handy Audio Recorder with Built-In Ambisonics Mic Array
For Video, Audio, VR & AR Production
Ambisonics, Binaural & Stereo Modes
Export to 5.1 Surround via Computer
Ambisonics Array with Four Microphones
On-Board Ambisonics A-to-B Conversion
Up to 24-Bit / 96 kHz Resolution
Built-In Slate Function
3.5mm Output with Binaural Monitoring
Record to SD Card or Stream via USB
Automatic Mic Position Detection
