VG-8 - String PitchShift VS Pedal Shift
Started by bosetuno, June 27, 2018, 06:25:40 AM
bosetuno
Is there any difference between these two algorithms? Its perfectly possible to assign the pedal to control the shift in string mode, so I dont see a real reason to use the PedalShift mode
Use string pitch for "B Bender single string pitch shifting with EV-5 Expression pedal.
bosetuno
But pedal shift can be used in the same way. Indeed some of its factory presets use pedal shift for b-bender
