electro harmonix stereo memory man with hazarai loopers true stereo .
Started by Brak(E)man, May 21, 2018, 07:33:44 AM
Can't find the answer to if the electro harmonix stereo memory man with hazarai loopers is true stereo.
Iow if the loops are recorded in stereo or not.
Quote from: Brak(E)man on May 21, 2018, 07:33:44 AM
Yes its stereo
Up to 30 seconds of loop time.
https://www.ehx.com/assets/instructions/stereo-memory-man-with-hazarai.pdf
QuoteSTEREO MEMORY MAN WITH HAZARAI
Congratulations on your purchase of the Electro-Harmonix Stereo Memory Man with
Hazarai. The Stereo Memory Man with Hazarai (SMMH) is a digital delay pedal with three
different types of echoes and a full-fledged looper all of which work in true stereo.
Special Features of the Stereo Memory Man with Hazarai:
• Up to 3 seconds of delay time.
• Up to 30 seconds of loop time.
• Tap Tempo Footswitch allows you to set the delay time with your foot.
• Multi-Tap delay allows you to set the exact number of echo repeats.
• A full-featured looper gives you the ability to record a loop of exactly what you
are hearing at anytime, set to any length up to 30 seconds.
• Record overdubs over your loop at anytime.
• Loop mode allows you to reverse the loop, change just the tempo or change
both pitch and tempo.
• Reverse Echo is an intelligent reverse delay that monitors your picking to create
optimal reverse delays of the notes you play.
• Multi-Tap plus Reverse allows you to use a straight echo and also have a
Footswitch controlled reverse effect.
• Echo + Mod gives you delay modulation where the user controls the total
amount of modulation.
• A Low Pass or High Pass filter is always available to process the delayed or
looped signals.
• Save and load up to 8 presets: 1 preset for each different mode.
• Mono In to Stereo Out creates a ping-pong effect where the echoes bounce
between the two outputs.
Thanx , I managed not to see the two last words in the first sentence  ::)
