GR 09 rattle problem
Started by Stevie M, October 19, 2019, 01:17:25 PM
Stevie M
Hi there, I've just joined.
Not sure if anyone can help here, but i've got a problem with a GR09.
I picked it up one day and it had something rattling about inside.
I took the base panel off and a piece of sprung metal about 30mm x20mm, with an end turned up, and a hole in it, fell out.
Does anyone know if there's an exploded diagram, or anything similar online anywhere that I can find out where this piece comes from?
Any help gratefully recieved.
Cheers.
Quote from: Stevie M on October 19, 2019, 01:17:25 PM
Cheers.
iTS PROBABLY PART OF A FOOT SWITCH
http://www.synfo.nl/servicemanuals/Roland/ROLAND_GR-09_SERVICE_NOTES.pdf
Stevie M
Thanks, that's brilliant, just what I needed. I think I know which bit it is now.
Cheers.
Stevie M
Ok.
I finally got round to fixing this.
It wasn't the part I first thought it was looking at the diagram, in fact it's not shown at all.
I took the whole thing apart, there's nowhere for it to go, nothing missing!!??
Everything still works as it should.
Weird??? ???
Quote from: Stevie M on October 26, 2019, 06:58:33 AM
Ok.
Weird??? ???
Post a pic of the "loose part"
Stevie M
I didn't know I could do that. I should have looked right at the start, found it now. Attachments!  :D
Recognise this bit?
