VG-99 and Ftp simultaneously into iPad - is it possible?
Started by Smash, August 06, 2017, 03:05:03 PM
Smash
I have an itrack pro dock an iPad air 2.
At the moment the VG99 midi is going in via Roland UME. But I'd also like to be able to run my FTP in at the same time.
I don't think the itrack will accept a hub - is there any route I can achieve this and if so what's the best the option?
Use the new Apple USB camera adapter and a powered USB HUB and a different audio interface or accept the 16 bit VG-99 standard USB audio mode
Details:
Smash
Brilliant info - thanx  ;D
Could I plug the FTP into a USB host and then the 5 pin out into the VG99 5 pin midi in so that passes through to the 5 pin out of VG99? So botht eh VG99 and FTP midi was going into the itrack via the MIDI out of the VG99 - would that work?
No idea what hardware you are talking about
What IOS Lightning to USB HOST adapter has 5pin MIDI I/O
If you are using FTP for MIDI ,why have an IOS MIDI I/O Connection to the VG-99?
