VG-99 Editor working on macOS Sierra 10.12.4 (16E195), but only on laptop.
Started by mooncaine, May 07, 2017, 09:33:31 PM
mooncaine
Well, the editor opened on this new MacBook Pro, and it opens my saved patch files. No kernel panic yet.... Cautiously optimistic.
arkieboy
While I haven't tried it out on my 2017 MBP yet, I've been running the editor and librarian on whatever has been the latest version of OS X for quite some time without any hitches.  Have been using 10.12.4 since released on my mac mini with no problems.
I have old hardware lying around just incase, but I have to say the editor and drivers for Mac have been pretty spot on for the last three years.  Well done, Roland!
mooncaine
But it still crashes my Mac Pro, hard. I installed the macOS Sierra driver today on that Mac Pro, and reinstalled the VG-99 Editor. Both were downloaded today.
I still get an instant kernel panic and a restart if I try to open the Editor. I should mention that I tried all this while csrutil was disabled, which I disabled before doing any of today's tests.
Bummer. I don't know why it's working on the MBP running its own Sierra, but not on the MP, so I don't feel reassured that it'll keep working on the laptop.
What year/model number Mac Pro?
Is it the round black cylinder or older silver Aluminum tower ?
mooncaine
The cylinder, the Darth Vader's Wastebasket model.
Mac Pro (Late 2013)
3.5 GHz 6-Core Intel Xeon E5
32 GB 1866 MHz DDR3
1 TB internal SSD
Running macOS Sierra 10.12.5 (16F73)
Might obtain a USB <> MIDI adapter (iConnectivity MIO,Roland UM-One MkII )  and try connecting the VG-99 Editor using the 5pin MIDI Interface (and not use the VG-99 USB driver /USB cable  )
mooncaine
Kinky. I'm game to try it if USB stops working on the new MacBook Pro. It is working, even after a recent OS update (last couple days).
But on the Mac Pro, the prob is that the editor won't run. It's the software that crashes the Mac, I think.
I'm not sure I need to solve this prob, but I did want to report it, to help others here who might be doing research before they buy something.
mooncaine
I should probably add that this Mac Pro has another undiagnosed kernel panic cause, so maybe this is my last report until I know more.
When I open Audio MIDI Setup, the same Mac Pro crashes. I fixed that once, but forgot what I did. When/if I rediscover that fix, I'll be able to try VG-99 software on that Mac Pro again.
Quote from: mooncaine on May 16, 2017, 03:26:08 PM
Might try the VG-99 Editor download from Australia
VG-99 EDITOR/LIBRARIAN VERSION 1.01A (MAC)
https://www.rolandcorp.com.au/support/by_product/vg-99/updates_drivers/4995
- its different than the RolandUS version
https://www.vguitarforums.com/smf/index.php?topic=21414.msg154218;topicseen#msg154218
mooncaine
I want to update you on the weird kernel panic I reported when using VG-99 Editor on my Mac Pro, running Sierra. The editor's fine.
I learned that one of my 2 Apple Cinema LED displays is causing it. When that monitor's USB connector is attached to the computer, either directly or thru powered hub, it seems to cause a kernel panic related to MIDI.
If I try the Editor, or Ableton Live, or Audio MIDI Setup, I get the kernel panic. But the fix is easy: I unplug that particular monitor's USB connector, sacrificing 3 USB ports on the monitor. No kernel panic. I have 2 identical monitors (same order, same shipment).
You just wouldn't believe the hours I wasted trying to troubleshoot that. And mac tech visits. And a support call. I missed an important step, so it's my fault: I should have booted the Mac with only one monitor, 1 Apple keyboard, and 1 mouse attached... NOTHING else. Had I done so, I might not have found the problem, because I regarded the monitors as identical and I wasn't actually thinking of trying each one separately.... but one of them uses an extension cable for USB/Thunderbolt. The other doesn't. So... that's the only reason I eventually tried booting with each one, alone. Nevertheless, I wasted a lot of time because I forgot that each monitor has USB and is a device that interacts with the Mac. I had gotten used to thinking of a monitor as a passive receiver, not as an active transmitter.
[btw, these aren't mine... they're my employer's. No way would I shell out for an Apple display]
Quote from: mooncaine on January 30, 2018, 01:06:35 PM
Each Apple Monitor employs a USB Hub
https://discussions.apple.com/thread/5064487
https://forums.macrumors.com/threads/thunderbolt-display-drops-usb-ports.1372018/
( you can have too many !
https://discussions.apple.com/thread/1781064
mooncaine
Thank you. Hmm, maybe I can replace that cable. I'll look it over tomorrow.
