Fishman TriplePlay FC-1 Controller, Won't Change Patches
Started by Rolloq, March 06, 2017, 11:31:22 PM
Rolloq
Found this on youtube.
Rolloq
case of Pilot error IMHO
Read the Manual , or join here and ask questions for Fishman Support
FishmanSQA
Quote from: Rolloq on March 06, 2017, 11:31:22 PM
Rolloq
I responded to this person. They are most likely using TP v1.2. (Which predates FC-1 configuration other than use as a basic foot controller.)
"It appears you do not have your FC-1 and Tripleplay controller configured correctly. Please be sure you are using Tripleplay v1.3 (or higher)  to configure the FC-1. My guess is you need to do a Firmware update to your controller and receiver, and configure your presets within the software to get started. Please note that you will not see patch or preset names from the Synth module you are using. The FC-1 displays data contained within your Tripleplay controller or the patch names when connected to the Tripleplay standalone software.   You can also contact support directly at: Support@Fishman.com for additional help.  Hope this helps!"
Sara
FishmanSQA
