How to use Mainstage audio patches in Garageband?
Started by vic_peacock, July 11, 2016, 03:12:22 AM
vic_peacock
Hello people,
I created some nice patches for guitar in Mainstage and I would to use them to record in Garageband.
I know how to use Mainstage instruments, but I could not do the same for audio patches. Of course, I can recreate the patch by using the Mainstage plugins, but I would like to work first in Mainstage and afterwards feed it to Garageband.
By the way, is there any way to re-route Mainstage strip output (e.g. a bus strip's output) into Garageband input?
Thanks in advance for your help.
Cheers,
    Vincenzo
I'm not sure if I understand your Q but you can record in Mainstage and open the file(s) in GarageBand
utensil
One way u could do this is to use soundflower , it's free and let's u route audio between 2 OS X apps, I use it to send main stage into ableton live so I can record into a track.
vic_peacock
Thanks @utensil for the recommendation. I will check Soundflower...
Besides, I would like to record a track directly in Garageband using the Mainstage audio patch. For software instruments it's doable. But not with audio patches. I can see all the plugins from Garageband, but i have to reassemble and set them again in Garageband to recreate the same patch I have created in Mainstage.
Also an "export" function (e.g. the .caf file) would be great for that purpose.
Cheers,
     Vincenzo
