Boss GT-1 - Owners Manual , Parameter Guide Documents
Started by admin, September 12, 2016, 06:46:10 AM
Observations
* GT-1 is cut down and essentially 1/2 the signal routing options of GT-100/ GT-001
• GT-1's Six Control Assignments Omit external MIDI CC# as Source
* No MIDI CC# transmission
Gumtown mentions
No dedicated Chorus effect, and no custom preamps or speaker cab detailed settings, only generic cabinets.
I guess this is the most they could 'shoe-horn' into a cheaper DSP package.
http://www.thegearpage.net/board/index.php?threads/new-boss-gt-1-mxf-pedal.1744000/page-9
Boss GT-1 - Parameter Guide
The Boss GT-1 Facebook page is getting a good international user base - including  Japanese Guitarists
https://www.facebook.com/groups/BOSSGT1/
http://www.ikebe-gakki.com/ec/pro/disp/1/476896
I hope we can pursue global dialogues and compare our wishes for future Roland / Boss products there.
Boss GT-1 Multi-Effects Pedal
http://www.reidys.com/blog/roland-grand-piano-boss-katana-amps-909-reissue-and-more-909-day-1501/
This is a new multi-effects pedal processor. It's got a very simple layout that means it's incredibly easy to use, for any level of player. It's got a huge variety of sounds, effects and even COSM-fueled amp models in there so it's just as suited to beginners as it is pros. The simple layout means you can turn effects on/off, call up the on board tuner and looper, or completely switch sounds at the push of a button or the kick of a switch. However, it's also got deeper editing capabilities meaning you can really shape your tone to your liking. It can run off batteries (up to 7 hours), and fits in a guitar gigbag, so is great for busking or for any other musicians on the go. With classics such as the Boss OD-1 and more built in, the new Boss GT-1 is sure to be a hit with a massive range of guitar players for all sorts of different purposes.
These FX appear to be exclusive to Boss GT-1
A-DIST:
This effect uses MDP (Multi-Dimensional Processing) technology to provide ideal distortion in all pitch ranges of the guitar, from low to high.
OVERTONE:
This effect uses MDP (Multi-Dimensional Processing) technology to add new harmonics to the sound, producing resonance and richness that was not present in the original sound.
more details here:
GT-1 Parameter Guide
https://static.roland.com/assets/media/pdf/GT-1_parameter_e01.pdf
BTS  for BOSS GT-1 patch Edit page in Boss Tone Studio
BTS  for BOSS GT-1 Control Assignments
Control target assignment options for Boss GT-1 "UP & "DOWN" foot pedals are:
* OFF
* OD SOLO (which reveals SOURCE MODE (Momentary or Toggle), SOLO Level (0-100)
* PREAMP SOLO(which reveals SOURCE MODE (Momentary or Toggle), SOLO Level (0-100)
* FX1 (which reveals SOURCE MODE (Momentary or Toggle)
* OD/DS (which reveals SOURCE MODE (Momentary or Toggle)
* PREAMP (which reveals SOURCE MODE (Momentary or Toggle)
* FX2 (which reveals SOURCE MODE (Momentary or Toggle)
* DELAY (which reveals SOURCE MODE (Momentary or Toggle)
* REVERB (which reveals SOURCE MODE (Momentary or Toggle)
* PEDAL FX (which reveals SOURCE MODE (Momentary or Toggle)
* TUNER (which reveals SOURCE MODE (Momentary or Toggle)
* BPM TAP
* DELAY TAP
* LEVEL +10
* LEVEL +20
* LEVEL -10
* LEVEL -20
* PATCH NUMBER +1
* PATCH NUMBER -1
* LED ON/OFF (which reveals SOURCE MODE (Momentary or Toggle)
new  Boss GT-1  firmware 1.05
https://www.boss.info/us/support/by_product/gt-1/updates_drivers/172811a8-0d42-42fb-b827-00bee833e1b1/
[ Version 1.05 ] OCT 2016
Bug Fixes
The following bug were fixed.
The sound fails to change when "OUTPUT SELECT" is used to switch the amplifier type while headphones are connected to the PHONES jack.
The indicators for the UP, DOWN, and CTL1 switches sometimes flash at tuner startup.
DELAY sometimes fails to be applied during EASY EDIT changes.
Noise sometimes occurs when TYPE is changed for OD/DS or PREAMP.
Noise sometimes occurs when REVERB TYPE is changed from DELAY to another TYPE setting.
Executing a factory reset for the GT-1 while BOSS TONE STUDIO for GT-1 is connected results in unmatching displays on the GT-1 and in BOSS TONE STUDIO.
The color of the [UP] and [DOWN] switches remains lighted in red.
When the [UP] or [DOWN] switch is used to select a patch number, the switch color sometimes lights up in red.
ON/OFF is displayed on the editing screen for NS (NOISE SUPPRESSOR).
Functionality Improvements
The trigger position when switching TUNER on and off by operating an expression pedal has been corrected.
The characteristics of "OUTPUT SELECT" when PREAMP TYPE is BGNR UB or ORNG ROCK have been corrected.
The functioning of CTL1 was set to OFF when not using TAP DELAY with EASY EDIT.
https://www.boss.info/global/support/by_product/gt-1/updates_drivers/
The Boss GT-1 USB Audio Driver for Apple OSX allows 24 bit @ 44.1kHz, 48kHz, 96kHz Core Audio sample rate
and it appears as an Apple OSX MIDI I/O hardware device too
PLEASE READ THE "README.html" file that is included with the USB driver download
( 90% of ALL problems with Roland/Boss computer connectivity via USB occurs from folks who disregard following the supplied "README instructions contained inside the zip / rar/ tgz files .
https://www.boss.info/global/support/by_product/gt-1/updates_drivers/a90352a2-ae87-4e29-b887-af751d3f477e/
GT-1 SYSTEM PROGRAM (VER.1.08)
How to tell the version
Please check the version of the system working on your GT-1 before downloading the archive file.
Hold down the [ ENTER ] button and connect a cable to the INPUT jack to turn on the power.
The current version is shown on the display.
Disconnect the cable to turn off the power.
* Don't perform the update if the product is already up-to-date.
Update history
[ Ver.1.08 ] MAR 2018
Bug Fixes
The function for simultaneously depressing the [DOWN + UP] pedals or the [UP + CTL1] pedals at the TUNER screen does not function correctly.
When a pedal is depressed and held while the FX TYPE list is displayed on the CHAIN screen, the FX TYPE list disappears.
Clicking the "CLEAR" button in BOSS TONE STUDIO does not clear the CTL or ASSIGN function on the GT-1 unit.
[ Ver.1.07 ] JUN 2017
Bug Fix
The following bug was fixed.
When switching patches, it may take a while until the pitch-shifted sound is output.
[ Ver.1.05 ] OCT 2016
Bug Fixes
