Jamman Solo XT and FS3X MODE switch function when three jamman XT's are synced
Started by bosjef, March 23, 2017, 08:28:41 AM
bosjef
Hi,
A question for those who have more than one jamman solo xt and an FS3X switch.
I plan to put up  two solo XT and one vocal XT and sync all three.
The FS3X foot-switch will be plugged on the MASTER solo XT.
Questions:
1. when all three are recording/playing/overdubbing and I press the MODE switch do all three stop at the same time?
2. if I press and hold the MODE switch, will all three loops (that are not yet stored) get erased?
3. if all three loopers have existing loops and are all stopped (as in Question 1) what happens when I press the MODE switch once again? do all three play their respective loops simultaneously or will it be just the master?
Thank you for your answers
jeff
http://www.customliveelectronics.com/en/effets-guitare/accessoires-pedales/24-syncman-jamman-synchronisation-midi-korg
http://www.customliveelectronics.com/syncman/index-en.html
SyncMan
Print   Email Category: SPÉCIAL
Working with loopers, sequencers, rythm boxes... need all these devices to share the same precise clock to get in perfect syncro.
Using MIDI is a good solution but some recent compact devices doesn't support it, particularly Digitech JamMan XT series.
So, here comes SyncMan! It use MIDI syncronization or external Clock ((TTL, CV, Korg synchro...) and keep your JamMan(s) in perfect sync with them.
NEW : For SyncMan informations and support please follow : syncman.customliveelectronics.com
Features
Syncronize Digitech JamMan XT loopers with External Clock : CV signal, TTL clock or Korg sync system ( exemple Volca Beats, Volca bass, Volca Keys, Monotron, SQ1 etc...)
Syncronize Digitech JamMan XT loopers with MIDI devices : hardware sequencers, DAW, beatbuddy pedal...
Firmware upgrades are possible by MIDI link.
http://www.customliveelectronics.com/syncman/syncman-faq-en.html#QAAJOxCO
http://www.harmonycentral.com/forum/forum/guitar/acapella-29/1678586-
QuoteJamSync is a midi link but with SysEx (coded) signals.
Using reverse engineering, i manage to send sucessfully JamSync signals and build a device able to convert Midi Beat Clock into JamSync.
Tests was done on this SyncMan : http://www.customliveelectronics.com...monotribe-midi
It can handle Midi syncro AND TTL signal from korg machine. A must!
Regards
http://www.customliveelectronics.com/en/effets-guitare/accessoires-pedales/24-syncman-jamman-volca-monotribe-midi
