VG-99 DISCONTINUED by Roland
Started by Gatormike, November 01, 2009, 09:41:57 AM
mbenigni
Autana
#101
QuoteAvoiding direct high impact blows , like dropping on concrete floor from tall heights is important too
Also non use,
Caps dry out and become unformed.
I try and fire stuff up to exercise the the capacitors every so often.
Not 100% sure it helps, but it can hurt.
Heartfelt thanks for the tips guys!
I suspect someone in Roland would be liable for the writing and warnings on some consumer manuals during last 70 years.
It read: DO NOT PUT any person in this washer
Should add:
Do not use to wash VG devices, you could void the warranty.
- Tal Wilkenfeld -
Now_And_Then
Quote from: Bill Ruppert on April 13, 2016, 11:21:43 AM
Also non use, Caps dry out and become unformed. I try and fire stuff up to exercise the the capacitors every so often. Not 100% sure it helps, but it can't hurt (typo corrected).
You've mentioned in other threads that you do this and I actually started a thread to get a more general opinion about such a practice, since there are some people on this forum with electrical engineering experience.
https://www.vguitarforums.com/smf/index.php?topic=12586.msg91582#msg91582
To sum up what was a brief discussion: The opinion seems to be that capacitor life is designed into the capacitor and so can't be extended; that decent (not "super cheap") caps have a lifespan of 15-20 years; that powering up your gear will not increase a cap's lifespan; and the main enemy of caps is heat (and, I assume, humidity).
Regular firing up of equipment will at least let you know when it has finally stopped working (knowing sooner than latter).
Keeping you gear stored in a vessel of inert gas at a constant 20 degrees Celsius might extend the equipment's life time, but not all that practical.
I think if your gear lasts a well used 15~20 years, then it may be worthy of the cost of electrolytic capacitor replacement.
Bill Ruppert
"Now And Then" Sorry don't know your name.
I have been a ham operator for 45 years and hold an extra class license here in the US asW9WCR
75% of my ham gear is high voltage gear using electrolytic capacitors.
It appears the life can be shortened.
http://www.premierguitar.com/articles/the-life-and-death-of-an-electrolytic-cap-1
http://www.qsl.net/g3oou/reform.html
http://www.tivocommunity.com/tivo-vb/archive/index.php/t-491454.html
http://www.angelfire.com/electronic/funwithtubes/Restore_cap.html
http://www.diyaudio.com/forums/parts/51492-reforming-electrolytic-capacitors.html
There is WAY more info that swings either way.
That said no one lives forever and there is a shelf life to these parts.
Bill Ruppert
#105
Quote from: gumtown on April 13, 2016, 07:56:22 PM
Ha if only I last 15-20 years more!!
At that point i wont know if it on or off:-)
I have to look now...
I do have a lot of vintage US radio gear here from the 1950's and 60's with original EL caps still working great.
I dont know, if I have a choice I rather have the gear on every so often rather that let the caps (EL) sit.
Think about a flat unformed cap getting hit with its working voltage after 10 years in storage.
Maybe its different in the high voltage world?
The variac is on every test bench I know.
Quote from: Bill Ruppert on April 13, 2016, 08:53:12 PM
! No longer available
Thanks for the link, good article. Sounds like good venting of the rack, for that type of gear, is also important to keep the caps from a melt down. Time to open 'em up and check for leaks.
kurttttt
Regarding the life span discussion of VG-99 - I couldn't find a specific release date but guess is around 2007-2008, which means early adopters have had it for 12-13 years, approaching the lower end (15 years) of the life span as said above. I'd appreciate if you guys can let people know when your VG-99 stops working for you. I hope VG-99 will last much longer than 15-20 years.
My GR300 released in 1980 is still working as is, my two GR50s released in 1988, and my VG8 released in 1995. So these machines can last a while  especially if they're not abused such as storing them in a hot shed.
Quote from: chrish on May 09, 2020, 02:43:19 PM
I was released in 1948 and I'm still working in spite of being often stored in a hot shed....   ;D 8)
Quote from: gumbo on May 09, 2020, 06:26:26 PM
yea, as long as you can keep the capacitors charged up it should work out  ok ;D
Quote from: chrish on May 09, 2020, 07:50:39 PM
I find the occasional immersion in whiskey has a beneficial effect... ;)
