VG-99- 5 Channel Amp Fender patches
Started by Mark Haydon, August 07, 2017, 10:59:22 AM
Mark Haydon
These patches are set progressively from Clean to Drive , almost like an amp with 5 channels, except that the Amp models vary from the first to the fifth.Need to use the FC 300 to enable the assigns which are as under:
1) FC 300 EXP Pedal 1 = Pedal Position
2) FC 300 EXP Pedal 1 SW = Wah Switch
3) FC 300 EXP pedal 2 = Mod 1 Efx level
4) FC 300 EXP Pedal 2 SW= Mod 1 Switch
5) FC 300 CTL pedal 1 = OD Sw or Amp gain switch medium to high depending on the patch
6) FC 300 CTL Pedal 2 =Amp Solo Sw+ Delay FX level + Delay Feedback
7) FC 300 CTL Pedal 3 = Chorus SW
8 ) FC 300 CTL Pedal 4 = Mod 2 SW
9) FC 300 EXP Pedal 5 = Volume.
10) VG 99 CTL SW= Fender tp P 90
All 5 patches are balanced for volume, but do tweak as needed
I have uploaded the same 5 patches as MID files
ATTENTION: This is a LIBRARIAN file not an EDITOR file!
