Author Topic: GR-55 - Oberheim OB-Xa and OB-8  (Read 2799 times)
Offline greekjgg
« on: March 14, 2012, 07:26:51 AM »
From what I've read, the Oberheim OB-Xa and OB-8 (For Live), is what Van Halen used for recording the synth sounds on 1984.
I'm looking to create the "I'll Wait" synth sound with the GR-55. I'm not even sure where to start looking? I have the "Jump" synth from the German patches but it doesn't sound like "I'll Wait". Any ideas or recommendations?
« Last Edit: March 02, 2015, 06:20:30 PM by Elantric »
Setup:
GR55
Rocktron Talkbox
TC Helicon Voicetone C1
Tech 21 Power Engine 60
Offline A2theT
Re: Oberheim OB-Xa and OB-8
« Reply #1 on: March 14, 2012, 08:09:35 AM »
Not sure about the GR-55 but I used GR-300 and Pipe Synths in VG-99 to create mine.  Then used a drop D tuning on low E string
HEAVY on the METAL
Offline aliensporebomb
« Reply #2 on: March 14, 2012, 10:18:40 AM »
A to the T:  Do you have an MP3 excerpt of that tune so we can hear what it sounds like?
I know Ruppert had a spot-on "Jump" sound he made for the 99 just using cosm effects but "I'll Wait" is a different polysynth type sound.  I will see what I can figure out.
Offline greekjgg
« Reply #3 on: March 14, 2012, 10:35:03 AM »
Here's a you tube clip of the song.
Just a 10 min search I've found: 725 Poly Synth 2
This stock sound is ok, sorta sounds like if there was a karaoke version of the song with cheaper sounds?
I'm also trying to figure out the best way to play this. I have guitar tab that is transcribed for the synth part but as usual the chords are difficult. I did do the drop tune, that was a good play. But I'm trying to play with the arrangement of the string pitches to create the "poor mans" way of playing this if you will.
Setup:
GR55
Rocktron Talkbox
Offline Charles5150
« Reply #4 on: March 14, 2012, 12:03:10 PM »
Ruppert's patch for Jump is the closest sounding to the original I've ever heard in my life comming from a not keyboard instrument, what an amazing pair of ears.
Maybe he could help here. It's very possible Eddie uses his unconventional approach to keyboards here too: i.e. putting a phase 90 after the keyboard and then a Marshall. To me it sounds like there's a guitar cabinet there, highs are very lo-fi
Offline Bill Ruppert
« Reply #5 on: March 14, 2012, 02:24:16 PM »
Charles,
I dont think its through a Marshall. It kind of sound like its distorting the filters a bit.
I hear what you are saying....maybe they reamped it by playing it through the studio speakers in the live room and mixed that in with the direct. OR they overloaded the di.
The OBX I did used two channels of wave synth "saw wave".
I think I used some phaser as well.
That was a while ago...
For the sound asked about i would just close the filter a bit.
http://soundcloud.com/bill-ruppert/obx-vg-99
Bill
« Last Edit: March 14, 2012, 02:25:49 PM by Bill Ruppert »
Offline arkieboy
« Reply #6 on: March 14, 2012, 04:29:00 PM »
bog standard obie brass through some valves: could be a marshall, or just a studio processor overdriven or even a fuzz box
You get the basic sound with a pair of saw waves, one of which should be slightly detuned, a 12dB/octave filter about 2/3rds open with no resonance and an amplitude envelope just backed off from instantaneous.  You should be able to get something like this from a GR55:  my oberheim matrix 6 (surprise surprise) and supernova II both manage this without much sweat.  With the sn II you can drive the filter to get a bit of fuzziness, or use the built in fuzz box emulation - I can't remember if you can drive the filter on an OBX (which I think Eddie was using).
Many synths impersonate this sound - it's usually helpfully called 'Jump' or 'Obie brass' or 'OBX Brass'
This is a perfect sound to begin cutting your teeth at programming.  Get on with it!
Steve
https://www.facebook.com/stephen.john.harris
http://www.agnieszkaswita.com
www.arkmusic.co.uk
Brian Moore and Patrick Eggle controllers
Roland VG99/Axon AX100 MkII
Marshall JMP1
TC Electronic G Major
Marshall EL84/20-20
Marshall 1912 (x2)
Roland FC300/Behringer FCB2020
Offline greekjgg
« Reply #7 on: March 15, 2012, 05:25:43 AM »
I found this clip too last night...not the greatest cover band but somebody's using a Roland something. The clip is older so before GR-55 but the synth sounds real good.
Setup:
GR55
Rocktron Talkbox
Offline greekjgg
« Reply #8 on: March 15, 2012, 05:32:12 AM »
Charles,
Bill
Wow Bill, that Jump sound is better than the one from the German patches of all the "legends". Do you have a spec sheet for that? or is it as simple as you stated? Would love to do a GR55 version of that as well.
Setup:
GR55
Rocktron Talkbox
Offline A2theT
« Reply #9 on: March 15, 2012, 01:19:59 PM »
Ok, I posted it up with mp3 sample so you can hear what it sounds like:  http://www.vguitarforums.com/smf/index.php?topic=5539.0
Its not bad but if anyone wants to improve on the patch then feel free.  It was good enough for my liking at the time.
HEAVY on the METAL
Offline whippinpost91850
« Reply #10 on: March 15, 2012, 08:29:15 PM »
Bill, I'm pretty amazed at the sound you get. You're ears are unbelievable. thanks for sharing Paul
Offline A2theT
« Reply #11 on: March 16, 2012, 09:56:01 AM »
Here's the VG-99 Patch and sample I use to play Jump.  Must be able to replicate the Jump sound on the GR-55.....
http://www.vguitarforums.com/smf/index.php?topic=5548.0
With all due respect, I believe my patch is just a modification of BrentFlash's fantastic work!
« Last Edit: March 16, 2012, 01:46:21 PM by A to the T »
HEAVY on the METAL
Offline Brent Flash
« Reply #12 on: March 16, 2012, 10:39:32 AM »
Re: GR-55 - Oberheim OB-Xa and OB-8
« Reply #13 on: February 04, 2017, 01:15:50 PM »
I'm desperately looking for an OBX-A patch for my GR55 like the one below and have no idea where to start.
Please if anyone has one I would appreciate it.... We just dug up "Working For The Weekend"
https://youtu.be/Ksq263XZeQk?list=LLEJZ2lkbGdViuYKOEcSF7-w
« Reply #14 on: February 04, 2017, 03:39:41 PM »
Not sure if the 55 can do this exactly the way I did it on a track on my new record but....
Have cosm guitar set to Wave Synth
Shape Saw
Try sens 50 attack 50 decay 100 and level 50
Filter type -12 db
cutoff 58 and reso 34
attack 0, decay 100, depth 0
eq (if you have it) low +8db low mid +5db high mid +3db high 0db and total 0 db
Turn compressor on for max sustain, about 40% attack and level about 60%
Modulation set to pan
Some type of chorus, flange, phase or modulation effect (more on this later)
Reverb also set to mod type but plate may work better for you
The reason for being vague about specifying chorus/flange/mod etc is I find the type of effect you use there has a large effect on how "smooth" or how "rough" the sound is.  Rougher, it sounds like synth brass, smoother it sounds more organ like.  Somewhere between the two the "I'll Wait" sound is because it almost sounds like a hybrid of a brass/organ sound.  A similar sound can be done with the same settings for the Loverboy tune.
Also, how it sounds largely depends on how much oomph you've set the GK sens to.  22 like I use often might be a little anemic.  I cranked it up for the tune I did recently.  Try it!
If it's too sharp, filter more.  if it's too smooth - filter less.
I have a patch I uploaded to the VG-99 section called ObieSaws that seems to me to sound like the work Dave Stone did with an Oberheim OB-XA with the band Max Webster (after Terry Watkinson left - he was a prominent Yamaha CS-80 user).  This patch with some edits can sound a bit like the glassy sound of a Yamaha CS-80 - season to taste by editing.
I realize this isn't a patch for the 55 If you load the Pod Obiesaws patch up in the VG-99 editor, you can set the exact settings I used and what order I put everything in.  if you can do a similar thing on the 55 (I don't have one yet!) you should get a lot of the way there.
Then, I set my E and A strings to an octave below and all the other strings standard.
« Last Edit: February 04, 2017, 03:48:35 PM by aliensporebomb »
« Reply #15 on: February 04, 2017, 04:46:43 PM »
Thank you so much... ASB I will give this a shot tonight......Paul
Offline chrish
« Reply #16 on: February 04, 2017, 09:46:00 PM »
There's gold in this thread. :-)
« Reply #17 on: February 05, 2017, 07:54:47 AM »
Yep, read it several times.  I'm getting closer , but not there yet
