GR-55 - Paul Gilbert's slapback delay..
Started by kevin123mm, November 15, 2011, 02:39:35 AM
kevin123mm
can anyone make me paul gilbert's cool slapback delay patch?
fbwh
If you mean like in The Echo song, I have a patch for the VG-99 but not GR-55 although it's not too difficult to have a go yourself at it.
Check out this tune which I did similar style to the echo song (music only on this link) I was not using GK just the Mag pick ups on a coil setting.
PS: PG rules!!
Certified Guitar Addict
kevin123mm
ya...tats d one... can u pls give me d delay settings? (feedback,time and all tat )
sharris
You want to set the feedback so that you get 1 echoed note returned. The time between the original note and the eched note is in the 200 to 300 millisecond range. This depends on the tempo of the song. Set the level on the echoed note to match the level of the original note. This is important.
Here is a good vid of Paul showing you how to play the echo song:
Hope this helps.
kevin123mm
i have that video..i've tried it.. if possible make a patch and upload it :D
