GT-100 - Pedal bend and wah at same time?
Started by OldPunk, January 30, 2017, 12:14:05 PM
OldPunk
Hello... I'm trying to get a pedal bend and wah wah at the same time. I have tried every way I know how, but if I have pedal bend, it can only go w foot volume as it's other use. I tried using an assign, but I could not seem to select a wah pedal to control.
It gave me an option for a sub wah...but I don't know what that means, as i could not select a wah type after that.
Thanks for your advice.
You can't use pedal-bend and Wah from the Pedal Effects both at the same time,
but you can use pedal bend and FX2-Sub Wah together.
Attached is a patch I put together to demonstrate.
The EXP pedal switch will engage the Pedal FX 'Pedal Bend' and also switch 'on' FX2-Wah
Sub Wah means it is a secondary Wah effect, separate from the main Pedal function wah.
OldPunk
Thank you, I'll give it a try.
Now does this necessitate an outboard exp pedal? Or do both the sub wah and pedal bend run off the main exp pedal?
It will do Wah and Pedal Bend with the one pedal motion of the GT-100 built in Expression pedal,
you did want both effects happening at the same time ?
OldPunk
