Boss SY-300 - Boss Tone Studio for SY-300 User Guide
Started by Elantric, June 25, 2015, 01:43:23 PM
http://bosstonecentral.com/about/
( see 12 page  Boss Tone Studio for SY-300 User Guide inside the Zip )
http://www.boss.info/support/by_product/sy-300/updates_drivers/350622
The above doc should be helpful for all Boss Tone Studio Users ( GT-100 / GT-001 / GP-10 / ME-80 / RC-50)
New Boss Tone Studio for SY300 version 1.10
Now there is a new Boss Tone Studio   "Offline Mode"  - for reviewing patch settings without the actual SY-300 hardware being present and connected!
BBach
I have found that patches that utilize the internal wave function to vary a parameter cause the program to lock up if edited while the wave is changing. Maybe it's just certain parameters (usually cutoff or resonance, have'nt experimented enough yet). Has anyone else noticed this ?  This is occurring in the non-updated version. Maybe the update will fix this, but it wasn't mentioned in the corrected issues on the download page.
szilard
I have had it lock up on editing, but not enough to figure out what the problem is.
BTS for SY-300 is now updated to Version 1.1.0
Update history
[ Ver.1.1.0 ]
Functionality Improvements
Librarian's "multiple patch copy," "multiple patch overwrite," "multiple patch move," and "multiple patch delete" are now supported.
Multiple patch copy to the unit is supported.
Moving live sets is now possible.
https://www.boss.info/global/support/by_product/sy-300/updates_drivers/dfbc4803-224c-4ec3-920a-3e2de8c23ab7/
Quote from: admsustainiac on May 03, 2017, 08:15:08 PM
All Boss Tone Studio for Windows download links have been removed while Roland /Boss sort out why recent MS Windows update/Adobe AIR updates present a conflict for the BTS Installer
If you already have HYS installed ,please DO NOT REMOVE IT .
I might take a few months for Roland/Boss to deliver a fix
Meanwhile ,use Gumtown's Floorboard Editor for your device (Katana,GP-10,GT-100,GT-001)
https://www.thegearpage.net/board/index.php?posts/24057971/
To all those having problems installing tone studio on windows 10: Set your date back (a year will do) and then run the install - this will get it installed and then you can change the date back to the correct date - All Good!
I believe it is probably something like a code signing certificate has expired (or similar) - changing the date gets around whatever check it is performing during the install. Enjoy!
mchad
Quote from: admsustainiac on May 04, 2017, 06:10:36 AM
This worked on my Win 7 machine. I haven't hooked up my SY300 yet but I am pretty happy!
jongrant
BTS saves your patches on your computer, even when you uninstall the app. Does anyone know where this data is svaed on your HDD? I am hoping to backup my patches to the cloud, to make sharing and transfer between computers easy.
Thanks!
jongrant
Never mind! I found the files. On my PC, they were in
AppData/Roaming/
This will save me some time and fuss.
SY.Borg.300
My first contribution to this forum. When the download instructions say copy exe  to your drive. It means your C: drive root directory. Normally I run exe files from my documents folder to keep my C drive clean. But nooooo ,  the editor wouldn't find my sy300 even though reaper found it no problem.  I screwed around for over 2 hours until I got a little smart and put it on the root. Then it found it like a dog finds a milkbone. Just sayin...
Quote from: SY.Borg.300 on May 26, 2021, 01:19:19 PM
Welcome to V-Guitar Forums SY.Borg.300
The *.exe file is the Tone Studio editor installer, and should not worry about where it launches from to install the editor, as the editor installs and runs from the Program Files folder.
The connection issue you first had would have been the USB driver software not downloaded and installed (separate from the editor software), most likely you are running Windows 10, and it would have recognized the SY-300 USB connection and automatically downloaded and installed the USB driver.
Lots of SY-300 resources here to dig into, and plenty of SY-300 users to help with any questions.
