Maker Hart - Loop Mixer (cascadeable)
Started by Elantric, February 21, 2017, 11:05:17 AM
http://makerhart.com/index.php?lang=en
Maker Hart - Loop Mixer (cascadeable via DisplayPort jack , rather like the JamHub)
The ideal audio mixer for use in home/office settings for all you multi-taskers with multiple devices, the LOOP MIXER serves to fulfill a need that has not been met till now. Simultaneously play music, video games, watch TV, listen for notifications, etc. from your computers, tablets, phones, MP3 players, instruments and all your other consumer devices. With 3.5mm stereo jacks for input and output, plug in up to 5 devices with AUX cables and output to headphones, a sound system and/or recording device. No need for expensive adapters!
PROFESSIONAL USE
Whether you are a professional musician needing a lightweight and travel-friendly mixer for your music group or a novice DJ needing something simple, the LOOP MIXER is powerful and versatile enough to serve your needs. Powered by a 9V AC adapter, you can amplify and control the signal level for each input channel from Mic to Line level signals without fear of reduced volume, sound distortions or annoying extra noises. Record, output and monitor at the same time.
*Upcoming: Link multiple Loop Mixers to monitor each input device independently without affecting the audio output (Cable will be made available in the future).
CONTROLS AND JACKS
• INPUTS: 5X3.5mm stereo jacks or split up to 10X1/4" mono/stereo jacks (adapters required for 1/4")
• OUTPUTS: Headphones, Speaker, REC (3.5mm jacks)
• BALANCE: Adjust L/R balance for each input
• GAIN: Adjust signal strength for each input
• MASTER and CHANNEL VOLUME: Adjust volume for overall and individual input
• OVERLOAD INDICATOR: Monitor signal distortion
SPECIFICATIONS
Input Impedance: 20kΩ
Output Impedance: 1kΩ
THD: 0.05% or less
Power source: AC Adapter DC 9V
Weight & Dimensions: 10.4oz, 6.9 x 5.1 x 1.2"
Contents: Loop Mixer, AC Adapter, DM2S Adapter, Owner's Manual
https://www.amazon.com/dp/B01M68UK38?psc=1
How to use JUSTMIXER(Keyboard and iPhone)
https://www.amazon.com/MAKER-HART-Guitar-Stereo-Configuration/dp/B01MPW4ODQ
MAKER HART Guitar Just Mixer Stereo 3 in/1 out Configuration
Stereo 3 in/1 out Configuration:3 stereo channel on JUST MIXER can connect up to 5 mono input.
Microphone Setup: By Gain knob adjustment, input signal level is adjusted to input signal level of microphone. (Recommend to use high-sensitive microphone)
Overload Indicators: The L/R OVERLOAD LEDs allow you to set the best signal level for optimum audio performance.
PHONES Jack: Stereo headphones can be connected to this jack for convenient mix monitoring.
POWER: Used with 2 x AAA or USB Power Bank
DisplayPort Cable as replacement for fragile DIN GK-13 pin cable
https://www.vguitarforums.com/smf/index.php?topic=11687.msg84940#msg84940
http://makerhart.com/product_d.php?lang=en&tb=2&id=82&cid=3
Features:
Loop Mixer has 5 stereo input set, therefore it could connect with 10 inputs at most. It also has amplifier for using as the microphone.
When it is applied into the band for multiplayer practicing.It could connect with all loop in and loop out in series. In this situation,
you could switch the voices upon your request. That means you could choose not only to hear the voice you want
but also not to hear the voice which you are not required. In addition, this situation will not affect the mixer output.
Loop Function
Stereo 5 in/2 out Configuration
5 stereo devices on LOOP MIXER can connect up to 10 mono device.
Microphone Setup
With the inclusion of SENS(Sensitivity) knobs, the LOOP MIXER can accommodate a variety of signals from microphone to Line level.
Overload Indicators
REC OUT Jacks
Connection to a recording device can be made through these jacks.
PHONES Jack
LOOP Jack
Through loop cable can be connected plurality LOOP MIXER, and on the respective LOOP MIXER, you can monitor
and adjust the sound volume of other devices freely, and not affect the overall mix effect.
※Note :
1. If the power of battery is too low that  you may be heard some noice. Please check and change new battery.
https://www.gearnews.com/maker-hart-debuts-beefed-up-loop-8-mixer-audio-interface/
Maker hart debuts beefed up Loop 8 mixer/audio interface
An ideal fit for Korg Volca and Pocket Operators?
Approximate reading time: 2 Minutes
Maker Hart Loop 8
Maker Hart Loop 8  ·  Source: Maker Hart
Maker Hart has announced the Loop 8, a beefed up version of the compact Loop Mixer the Taiwanese company has been offering since 2017. The new Loop 8 is a handy 8-channel audio mixer with a built-in audio interface. It looks to be a nice fit for setups involving small gadgets like the Korg volca series or the Teenage Engineering Pocket Operators.
As the name suggests, the Maker Hart Loop 8 offers a total of eight channels—four mono channels and two stereo channels. The mono channels have mini jack inputs and each one comes with a different set of features. Channel 1 can supply 48V phantom power or 1.5V plug-in power (an XLR-to-mini-jack adapter is included). It also features a built-in echo effect. Channel 2 seems to have Bluetooth connectivity, while channel 3 can accept a Phono input signal. Channel 4 has a traditional gain control. On each of the channels 2-4, a tone control knob allows for some basic equalization. The stereo inputs come with standard jacks, gain controls and balance knobs. Each channel also has a mute button and a short level fader.
Maker Hart Loop 8
The Maker Hart Loop 8 has 4 mono and 2 stereo inputs.
Loop 8, without audio loops
The Maker Hart Loop 8 also features its namesake loop function. But don't get all excited: This has nothing to do with audio looping. Instead, the "loop" inputs and outputs allow you to cascade several Loop 8 mixers using optional cables. Each unit can then be used to create a different mix of the same input signals. This seems like a handy solution for creating different monitor mixes for each member of a band, for example. But we do think that Maker Hart's use of the term "loop" is just a tad bit misleading.
What's promising, though, is the addition of a built-in 24 bit / 96 kHz USB audio interface. While we don't yet know its exact specifications, it probably lets you send the input signals digitally to a DAW and vice versa. Eliminating the need for additional hardware makes a lot of sense—especially in the context of a small, portable setup.
The Maker Hart Loop 8 is now available for pre-order for 145.99 US dollars.
https://makerhart.com/
http://cs.rlmicloud.com/account/Download/Product/Audio%20Mixer/Loop%208/LOOP8-EN.pdf
