Alvarez Yairi WY 1 RR
Started by Tony Raven, August 31, 2017, 08:06:15 PM
Tony Raven
Spotted this Blue Book listing while looking for something else --
Quotesimilar to WY 1 Virtuoso (folk style body), except features a thin cutaway body with solid spruce top, mahogany back and sides, has Roland GK2 electronics, available in Satin Graphite finish, mfg. 1998-2004.
MSRP $2,299, worth $650-$1,650 (2004). Per Fjestad's Rule, it's unusual that ANY used guitar is worth 50% of SRP, particularly while still in production, so I figure the valuation has likely gone up.
whoops, maybe spoke too soon --
https://reverb.com/item/323356-alvarez-yairi-wy-1-rr-2003-gray-matte
Went out for $450 + $65 in 2014. :o
https://guitarrasramirez.com/
http://www.instrumentpro.com/p-MTNALXMIDI
Martin Alternative X Midi Features:
CONSTRUCTION: Mortise/Tenon Neck Joint
BODY SIZE: 00-14 Fret Thinbody CUTAWAY
TOP: .032" Graffiti Pattern Aluminum
ROSETTE: none
TOP BRACING PATTERN: Alternative Pattern
TOP BRACES: 00X (A - frame)
BACK MATERIAL: Jett Black HPL Textured Finish
BACK PURFLING: none
SIDE MATERIAL: Jett Black HPL Textured Finish
ENDPIECE: none
ENDPIECE INLAY: none
BINDING: none
TOP INLAY STYLE: none
SIDE INLAY: none
BACK INLAY: none
NECK MATERIAL: Black Stratabond- Thinbody Heel, Strap Button
NECK SHAPE: Modified Low Oval
NUT MATERIAL: Black Corian®
HEADSTOCK: Solid/Square/Tapered
HEADPLATE: Graffiti Pattern Aluminum/ Black Foil Logo
HEELCAP: none
FINGERBOARD MATERIAL: Black Micarta®
SCALE LENGTH: 25.4"
# OF FRETS CLEAR: 14
# OF FRETS TOTAL: 20
FINGERBOARD WIDTH AT NUT: 1 11/16"
FINGERBOARD WIDTH AT 12TH FRET: 2 1/8"
FINGERBOARD POSITION INLAYS: White dots- One at 5th, 7th, 9th, Two at 12th, One at15th and 17th Frets
FINGERBOARD BINDING: none
FINISH BACK & SIDES: none
FINISH TOP: none
FINISH NECK: none
BRIDGE MATERIAL: Black Micarta®
BRIDGE STYLE: 1 Style Belly
BRIDGE STRING SPACING: 2 1/8"
SADDLE: 12" Radius/Compensated/Black Micarta®
TUNING MACHINES: Gotoh Black Knobs w/ CFM Logo
RECOMMENDED STRINGS: MSP+ 4100 Coated Light Phosphor Bronze
BRIDGE & END PINS: Black w/ White Dots
PICKGUARD: none
CASE: 310 SS Hard Shell
INTERIOR LABEL: Foil Label
ELECTRONICS: GK-KIT-G (Roland MIDI) and Fishman® Prefix Pro
OTHER OPTIONS: Available left-handed at no additional charge
OTHER COMMENTS: All prices & specifications are subject to change without notice.
More Factory GK Ready Guitars that once existed
https://www.vguitarforums.com/smf/index.php?topic=19.0
Tony Raven
FWIW, I actually tried out an Alt-X (non-Roland) back in 2002, only because it looked so weird. And I gotta say, it surprised me: one of the best-sounding recent Martins I've tried.
The Ramirez is a total surprise. Ghost saddles?
Quote "The Ramirez is a total surprise. Ghost saddles?"
The other guitar player in the band I was in put that same RMC 13 pin hex system on a steel string Takamine acoustic guitar.
