GR-55 Stab Lead Marshall
Started by sixeight, May 26, 2015, 10:50:32 AM
OK, here is a patch that I made after I bought my GP-10. It produces no sound, until you press Ctl. Then a Marshall Lead Tone kicks in. In the mp3 example I play this patch together with another clean chorus patch on the GP-10. It is part of my setup strategy as explained here: https://www.vguitarforums.com/smf/index.php?topic=11506.msg107836#msg107836
The tricky part in this patch is in the assignments. I wanted the patch to produce no sound before the CTL pedal is pressed. I needed two assigns (2 and 4) with the internal pedal to turn down the volume when selecting the patch and to turn of the guitar, which kept switching on during patch selection.
Touching the expression pedal switches the sound on. Press CTL to switch it off again.
