Alps Mini Style Concentric 500K Log and 50K linear pot source
Started by stublito, May 26, 2016, 07:14:43 PM
stublito
Anyone have a source? Has to be mini. Alps seem like the smallest.
Would also need the black metal knurled knobs (set screw type).
Extra points for an additional push pull DPDT section.
Anyone? Beuler?
Stublito
stublito
I found this:
https://www.muffwiggler.com/forum/viewtopic.php?t=56318
So for a 500K dual concentric log, I could "linearize" the second section using a 60K resistor between the wiper and the top (full clockwise position) connector. This will produce 20% less current flow than a 50K linear but should be acceptable for the Roland voltage control.
Does that sound right to you guys?
Stublito
adding parallel resistor network as described above is an acceptable functional compromise.
