MS-3 downloads - drivers - system update - Tone Studio editor
Started by gumtown, August 08, 2017, 04:41:38 AM
Boss MS-3 download page
https://www.boss.info/us/support/by_product/ms-3/updates_drivers/
MS-3
Updates & Drivers
MS-3 System Program ( Ver.1.03 )
MS-3 Editor / Librarian Ver.1.0.0 for Windows
MS-3 Editor / Librarian Ver.1.0.0 for macOS / OS X
MS-3 Driver Ver.1.0.1 for Windows 10
MS-3 Driver Ver.1.0.0 for Windows
MS-3 Driver Ver.1.0.0 for macOS / OS X
MrHaroldA
Firmware v1.04 and the Editor v1.01 are out!
Firmware Bug Fixes
* When the PATCH MIDI parameter of PC, BANK MSB, BANK LSB, CC1 NUM, or CC2 NUM is set to its maximum value, the data in Editor/Librarian goes to "0."
* When BNK.CNG (BANK CHANGE MODE) is set to WAIT, bank switching sometimes fails to occur when number switches ([1] + [2] or [3] + [4]) are pressed or an external pedal is depressed.
* When a "B0" (bass 5th string open) note is input to B.HARMONIST, the harmony pitch is not correct.
QuoteEditor Bug Fixes
* When the PATCH MIDI parameter of PC, BANK MSB, BANK LSB, CC1 NUM, or CC2 NUM is set to its maximum value, the data in Editor or Librarian goes to "0."
* Copying from "patch list" to "LiveSet" is not possible.
* When performing a drag operation or during Apply Liveset in Librarian, the "Wait Cursor" is released when a patch change occurs on the MS-3 itself.
* When a patch change occurs, the values of all PATCH MIDI parameters except CH go to "OFF" or "0."
* AT "1 + 2" in [SYSTEM] - [PLAY OPTION], BANK DOWN was indicated as BREAKDOWN.
Boss MS-3 and Katana library for Arduino: https://github.com/MrHaroldA/MS3
