Factory patch set adjusted and re-levelled suited for bass
Started by gumtown, July 22, 2015, 04:31:28 AM
In the patch exchange is a factory patch set which I have re-adjusted the levels, evened them out, so they are more suited either for bass, or guitar if using an external preamp or pedal board which has a level pass through of unity gain.
Using the THRU and RETURN on the SY-300 for the external pedals or preamp, the patch set gives a 50/50 mix on all patches.
The requirements are
1) something plugged into the THRU-RETURN loop, preferably at unity gain.
2) the SY-300 has the SYNTH ON/OFF switch set from the default bypass to SYNTH ON/OFF.
This makes the factory patch set actually usable,
use this to replace the existing factory patch set.
https://www.vguitarforums.com/smf/index.php?topic=15677.msg111876#msg111876
