VGuitar Forums
Please login or register.
Advanced search
Pages: [1]   Go Down
Author Topic: gr-55 want play usb thumb drive  (Read 933 times)
SLIM JIM
  • Lurker
  • Offline Offline
« on: February 02, 2012, 08:17:21 AM »
anyone having trouble  importing tracks from the usb thumb drive on the gr-55.......i insert in the on board gr-55 drive
and comes up blank    i can  insert the  thumb drive back into my  computer and it will play.......what's is going on???
it there a  down load from roland?? or what?  in need your help
Logged
  • Global Moderator
  • Senior Member
  • Offline Offline
    • Flash Enterprises
Re: gr-55 want play usb thumb drive
« Reply #1 on: February 02, 2012, 08:34:01 AM »
Welcome to the group SLIM JIM!  :)
You can't use mp3s, that may be your problem.
  • Global Moderator
  • Senior Member
  • Offline Offline
« Reply #2 on: February 02, 2012, 12:49:58 PM »
The files must be a specific format (*.wav or *.aiff) and sample rate (44.1kHz).
The GR-55 is also fussy about some types of thumb drive, i hope you are using only the side USB port.
Logged
SLIM JIM
  • Lurker
  • Offline Offline
« Reply #3 on: February 02, 2012, 03:52:32 PM »
CAN I  USE MY  MEDIA PLAYER TO DOWNLOAD  ONTO THE USB THUMB DRIVE????
WAV  FORMAT................DO YOU HAVE TO  FORMAT THE THUM DRIVE????
THANKS FOR YOUR HELP
Logged
  • Global Moderator
  • Senior Member
  • Offline Offline
« Reply #4 on: February 02, 2012, 08:31:07 PM »
Windows Media player will typically save song files in *.WMA format, you need to probably convert your song files to *.WAV format and then copy and paste to the thumb drive.
Logged
  • Global Moderator
  • Senior Member
  • Offline Offline
    • Elantric's Tips and Blog
« Reply #5 on: February 02, 2012, 09:05:17 PM »
You can use iTunes or Audacity to convert MP3s to Wav or AIFF.
http://audacity.sourceforge.net/
How to Convert MP3 or AAC Files to AIFF Format with iTunes:
http://support.apple.com/kb/HT1348
The GR-55 Player needs these file types:
File format: WAV, AIFF
Sampling frequency: 44.1 kHz
Bit depth: 8/16/24 bits
The Thumb drive should be FAT-32 format too.
« Last Edit: February 02, 2012, 09:23:04 PM by Elantric »
Logged
Bluesman
  • Contributing Member
  • Offline Offline
    • Delta Express
« Reply #6 on: February 02, 2012, 10:48:16 PM »
Most DAW's will also let you import mp3's etc, you can then edit them to suit (think intro to Pink Floyd - Time as an example) and export as WAV files. You can have a lot of fun with this feature.  ;D
Logged
Robert Cray Fender Stratocaster - GK-3
Fender Stratocaster HH
Maton 225ac
Roland GR-55
Line6 Pod HD 500
Samson Auro D412A's Behringer B1800A's
Reason 6
Rexx
  • Offline Offline
« Reply #7 on: February 25, 2012, 12:12:58 PM »
 This is a great feature on the GR-55.
 I learned the hardway that my USB thumbdrive needed to be formatted FAT 32 to upgrade my firmware, once done I put some music in wave format, cool.
 Question: Is there a way to rewind when learning from songs?
Logged
  • Global Moderator
  • Senior Member
  • Offline Offline
« Reply #8 on: February 25, 2012, 01:48:12 PM »
The Page < > buttons skip 10 seconds with each press.
Logged
Rexx
  • Offline Offline
« Reply #9 on: February 25, 2012, 07:23:29 PM »
 :) Great! Thanks.
Logged
Pages: [1]   Go Up
