VGuitar Forums
Please login or register.
Advanced search
Pages: [1]   Go Down
Author Topic: Audioslave - Gasoline - Drop B tuning  (Read 896 times)
jezebabe
  • Contributing Member
  • Offline Offline
« on: September 18, 2011, 05:02:03 PM »
This provides the main guitar sound (with low E detuned to low B) plus the tremelo sound in the verse via the CTRL switch.
For some reason echo/delay from a previous patch is also enabled when I enable the tremelo.  ???
This does not show up in GR55Floorboard unless I'm missing something as I'm still new to this.
If anyone can spot the error then please enlighten me, thanks  ;D {Update - now fixed see 3rd post below}
Enjoy
J
« Last Edit: September 19, 2011, 02:23:06 AM by jezebabe »
Logged
  • Global Moderator
  • Senior Member
  • Offline Offline
Re: Audioslave - Gasoline (beta) - Drop B tuning
« Reply #1 on: September 18, 2011, 06:00:22 PM »
Look under 'Pedal/Gk' in GR-55FloorBoard, and you will see the CTL pedal control function is set to 'Delay Sw'.
You just need to set that to 'off'
Logged
jezebabe
  • Offline Offline
Re: Audioslave - Gasoline - Drop B tuning
« Reply #2 on: September 18, 2011, 06:15:03 PM »
Great, many thanks Gumtown.  I had set it under assign 1 but didn't know about the setting under Pedal/GK.
I have attached a "fixed" version.
Also thanks for the excellent GR55 editor. It makes editing so much quicker!
J
« Last Edit: September 18, 2011, 06:18:33 PM by jezebabe »
Logged
jezebabe
  • Offline Offline
« Reply #3 on: September 22, 2011, 05:08:04 AM »
Hey Gumtown,
Since I am using your editor quite a bit I decided it was time to buy you a beer!
Not sure how much beer costs in your part of the world but this will hopefully cover it  :)
Jez
Logged
kevin123mm
  • Offline Offline
« Reply #4 on: November 09, 2011, 08:52:37 AM »
i dont know why but everytime i load this patch it works fine and when i save it ,the tremelo effect is gone.. cant save it with d tremelo on...
Logged
Pages: [1]   Go Up
