VGuitar Forums
Please login or register.
Advanced search
Pages: [1]   Go Down
Author Topic: Peavey Sanpera Pedal MIDI Transmission Data  (Read 3586 times)
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
« on: February 10, 2011, 10:32:24 PM »
This question is for the midi/electronic wizards amongst you. :)
Could a Peavey Sanpera midi foot controller - meant to work with the Vypyr amps - be modified (if needed) to be used with the GR-55?
That'd be very cool as it seems pretty well build and fairly cheap.  8)
« Last Edit: February 26, 2015, 02:09:40 PM by Elantric »
Logged
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
Re: Peavey Sanpera Pedal MIDI Transmission Data
« Reply #1 on: February 10, 2011, 11:10:56 PM »
I've found an old post in another forum...
The pedal should work on its own if you supply the power. I have a rig in the lab with a little breakout box that has the 8-pin connector, two 5-pin connectors for hooking to the PC (in and out), and a power input for, well, power. A +9 vdc supply at 500 mA would be sufficient. (300 mA could work, but 500 mA would be safer.)
The switches (including toe switches) and pedals always send the same command, and the LEDs respond to commands from the amp - all independent of mode, etc.
Logged
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
« Reply #2 on: February 10, 2011, 11:19:32 PM »
Some useful info?
The midi commands being sent by the Sanpera:
http://e-lectronics.net/img/Sanpera/index.html
A thread on the subject:
http://forums.peavey.com/viewtopic.php?f=33&t=13970
Logged
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
« Reply #3 on: February 10, 2011, 11:27:24 PM »
Any use?  ???
===> MIDI-   OX Vers   ion: 7.   0.2.372
===> Log Opened:       Sun 10-Oct-2010 10:28:53:00 AM            ===>
TIMESTAMP   IN PORT   STATUS   DATA1   DATA2   CHAN   NOTE   EVENT      Pedal Operation/function
000FE868   1  --   90   10   7F   1   E  0   Note On      Bank Down
000FE94F   1  --   90   10   0   1   E  0   Note Off
000FF31B   1  --   90   0E   7F   1   D  0   Note On      Bank Up
000FF411   1  --   90   0E   0   1   D  0   Note Off
1.00E+12   1  --   90   5   7F   1   F -1   Note On      Preset 1
1.00E+06   1  --   90   5   0   1   F -1   Note Off
100579   1  --   90   4   7F   1   E -1   Note On      Preset 2
100695   1  --   90   4   0   1   E -1   Note Off
00100A4A   1  --   90   9   7F   1   A -1   Note On      Preset 3
00100B5B   1  --   90   9   0   1   A -1   Note Off
00100F72   1  --   90   7   7F   1   G -1   Note On      Preset 4
0010106A   1  --   90   7   0   1   G -1   Note Off
0010207B   1  --   90   0C   7F   1   C  0   Note On      Manual mode
102181   1  --   90   0C   0   1   C  0   Note Off
102840   1  --   90   5   7F   1   F -1   Note On      Stompbox (button1)
0010292B   1  --   90   5   0   1   F -1   Note Off
00102B4D   1  --   90   4   7F   1   E -1   Note On      effect (button2)
00102C59   1  --   90   4   0   1   E -1   Note Off
00102EEB   1  --   90   9   7F   1   A -1   Note On      delay (button3
00102FF7   1  --   90   9   0   1   A -1   Note Off
0010335D   1  --   90   7   7F   1   G -1   Note On      reverb (button4)
103450   1  --   90   7   0   1   G -1   Note Off
108482   1  --   90   0   7F   1   C -1   Note On      "record/play (left looper button, momentary operation)"
001085D2   1  --   90   0   0   1   C -1   Note Off
0010947F   1  --   90   2   7F   1   D -1   Note On      "stop/reset (right looper button, momentary operation)"
0010957D   1  --   90   2   0   1   D -1   Note Off
0010AE7F   1  --   90   2   7F   1   D -1   Note On      "stop/reset (right looper button, held down for 5 seconds)"
0010C15B   1  --   90   2   0   1   D -1   Note Off
110787   1  --   90   15   7F   1   A  0   Note On      volume pedeal fully depress to enable tuner
115046   1  --   90   15   7F   1   A  0   Note On      volume pedeal fully depress to disable tuner
0011A95A   1  --   B0   24   7F   1   ---   Control   Change   volume pedal 100% (toe fully depressed)
0011AAA3   1  --   B0   24   3F   1   ---   Control   Change   volume pedal 0% (heel fully depressed)
0011C4C6   1  --   90   11   7F   1   F  0   Note On      wah pedal  fully depressed to enable wah function
0011D4A1   1  --   B0   22   7F   1   ---   Control   Change   wah pedal 100% (toe fully depressed)
0011D5D4   1  --   B0   22   0   1   ---   Control   Change   wah pedal 0% (heel fully depressed
0011E2F3   1  --   90   11   7F   1   F  0   Note On      wah pedal  fully depressed to disable wah function
1.21E+08   1  --   90   0B   7F   1   B -1   Note On      tap tempo
001215EC   1  --   90   0B   0   1   B -1   Note Off
<=== MIDI-   OX Log   Closed:   Sun 10   #NAME?   10   10:31   :44 <===
Logged
paults
« Reply #4 on: February 11, 2011, 12:29:58 AM »
Here are at least some of the MIDI CC numbers that are sent by each of these buttons.
(source: http://www.ibiblio.org/emusic-l/info-docs-FAQs/MIDI-doc/MIDI-Controllers.txt)
000FE868   1  --   90   10   7F   1   E  0   Note On      Bank Down     Continuous controller #16
000FF31B   1  --   90   0E   7F   1   D  0   Note On      Bank Up        Continuous controller #14
1.00E+12   1  --   90   5   7F   1   F -1   Note On      Preset 1         Continuous controller #5
0010207B   1  --   90   0C   7F   1   C  0   Note On      Manual mode    Continuous controller #12
0011C4C6   1  --   90   11   7F   1   F  0   Note On      wah pedal  fully depressed to enable wah function    Continuous controller #17
0011E2F3   1  --   90   11   7F   1   F  0   Note On      wah pedal  fully depressed to disable wah function   Continuous controller #17
1.21E+08   1  --   90   0B   7F   1   B -1   Note On      tap tempo              CC#11
MCK
  • Site Administrator
  • Senior Member
  • Total likes: 2
  • Rating: 15
  • Offline Offline
« Reply #5 on: February 11, 2011, 02:27:14 AM »
If you're looking for a cheap and sturdy midi floor board I suggest Behringer FCB1010 coupled with an UNO chip. Its very powerful and quite open.
Logged
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
« Reply #6 on: February 11, 2011, 06:59:00 AM »
Nice find, paults. ;)
Thanks MCK but I'm thinking smaller "add-on" that could be powered via midi by the GR-55, not a full-blown pedalboard. :)
Logged
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
« Reply #7 on: February 11, 2011, 07:10:53 AM »
P.S: Paul, these are generic values, though, not Sanpera specific, correct?
Logged
pjmuck
« Reply #8 on: February 11, 2011, 07:20:49 AM »
Tech 21 Midi Mouse? Can't get any smaller than that.  ;)
Logged
Live gear:
Boss GT Pro
Roland GR-33
Atomic Reactor 50-112 amp
Ground Control Pro midi foot controller
Boss EV-5
Godin LGX-SA guitar (lefty)
Line 6 Variax 500 guitar (lefty)
Carvin LB50 w GK3B
Shure PSM 600 Wireless In-Ear Monitor System w Custom UE-7 buds
Zoom A3
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
« Reply #9 on: February 11, 2011, 07:26:30 AM »
>> Indeed :)
Logged
Macciza
« Reply #10 on: February 11, 2011, 07:42:52 AM »
High
Re the data post. It is as it says
All the lines with the 90 and the noteon/off comment are note messages on midi channel 1
The lines with B0 are continuos controllers on midi channel 1
Cheers
MM
Logged
'70s Strat, Brian Moore iM, VG-8, VG-99, FC-300, VL-70m, StringPort, SoftStep, Sentient6, iMac QC i7 27".
pjmuck
« Reply #11 on: February 11, 2011, 07:49:26 AM »
>> Indeed :)
Sorry, I must have read your mind (or subliminally filed away) your other post regarding this that I just now noticed. So consider this post a validation of your own thoughts.  ;D
Logged
Live gear:
Boss GT Pro
Roland GR-33
Boss EV-5
Carvin LB50 w GK3B
Zoom A3
ddlooping
  • Patron Supporter
  • Senior Member
  • Total likes: 2
  • Rating: 95
  • Offline Offline
    • Diaz Guitars
« Reply #12 on: February 11, 2011, 09:25:22 AM »
High
The lines with B0 are continuous controllers on midi channel 1
Cheers
MM
Thanks, MM. :)
So, if I understand correctly, only the continuous controller messages sent by the Sanpera footpedal are usable with the GR-55, the note ON/OFF not being assignable on the latter.  :(
Ok, thanks.  ;D
Logged
Pages: [1]   Go Up
