GR-33 - Use External Battery power?
Started by Hurricane, September 13, 2017, 03:33:51 PM
Hurricane
8)
¿ Are there any members using a battery power pack/block/ with a Roland
GR33 ?
I've had my FreePlay up and working sans A.C. but not the other gear . I
want to pull the trigger to get the system totally A.C. free for a project  :D
I do not want to come up short on this first outing with the whole ball
of wax hooked up  >:( :
#1: Source Audio Hot Hand 3 base ( ( 9VDC )
#2: Source Audio Programmable EQ ( 9VDC )
#3: Radial Tonebone Bumper Instrument Selector ( 9VDC )
#4: T.C.H Voice Live 3 X ( 12VDC 1.A)
#5: Roland GR33 ( not exactly sure the power supply says : In : A.C.120 ~ 60Hz 35 Watts - Out A.C 14V ~800 mA)
I always prep/plan my move long before I make it and rehearse it over and over
before it's , [ SHOW TIME ] mentally as well as physically , this has been my style
of doing stuff since I was a kid , learning how to run a photography studio/darkroom
with my grandfather the owner , this was one my ( oh yeah - were talking the late 50's )
first serious undertakings as a kind and later into my athletics .
¿ I just saw on Amazon power bank kits at reasonable prices , has anyone explored this
/these rechargeable prospects as well in the forum ?
EZ , Peace & Thank You [Elantric ] and to all who have been a great source of information and help to me
so far since I joined this forum :
HR
Quote#5: Roland GR33 ( not exactly sure the power supply says : In : A.C.120 ~ 60Hz 35 Watts - Out A.C 14V ~800 mA)
Roland GR-33 is older generation  - uses a Roland BRC-120 (14VAC @ 800mA) power supply
https://www.rolandus.com/assets/press_media_resources/ACAdapterGuide.pdf
https://www.amazon.com/HQRP-Adapter-BRC-120T-A41408DC-Processor/dp/B00D42CEHI
https://www.vguitarforums.com/smf/index.php?topic=14682.0
GR-33 14VAC POWER INPUT
If you attempt to use a 14VDC battery external supply -you will not have the -7VDC (-A7) negative voltage Power Rail for the internal opamps and GK-3
Hurricane
Quote from: admsustainiac on September 13, 2017, 04:09:39 PM
Thanks , I have a Godin LGXSA and don't use the GK-3 system .
¿ Will this be an issue still with the Godin's pre amp  ?
EZ :
HR
Yes - because when GK 13 pin cable is connected,  the Godin still uses the -7V supply from the processor for its hex buffer
and the Analog signal path internal to the GR-33 relies on the -A7 power rail
Hurricane
Quote from: admsustainiac on September 14, 2017, 07:46:46 AM
8)
Sound like the solution - - -  is a long walk around the proverbial mountain .
Battery , A.C. inverter - power strip plug and the GR33 wall wart , gonna look fugly :P
Thanks .
EZ :
HR
GuitarBuilder
For another approach; if you could use two 9V batteries to generate 18VDC, there's a simple circuit to generate 14VAC directly, similar to this one:
http://www.electronicshub.org/12v-dc-220v-ac-converter-circuit/
You would not need the step-up transformer in this case.
I would have the Gr33 modified for DC power
Using a modern voltage inverter for the 7v negative  power rail
Or a different guitar to midi system
FTPwith ipad works for mobile gigs
Hurricane
Quote from: admsustainiac on September 15, 2017, 08:33:29 AM
8)
Yep , it's looking like the long way around the mountain -
Oh well it's not the first time I've taken that proverbial hike
& it' won't be the last one either .
A good decent inverter & battery is I guess cheaper than a
FTP/Ipad system or another midi system .
It's time to review inverters I guess , it's just a question of time to
find one that doesn't look like a radar base is at my feet or near me
, I'm after , small , sleek , unobtrusive & good looks . ;)
Modding the GR33 is something that's not going to happen .
EZ :
HR
