Author Topic: EBS & Rockboard - Low Profile 1/4" flat patch cables for FX Pedal boards  (Read 150 times)
Offline Elantric
EBS Flat Patch Cable Specifications:
Model Number: PCF-28
Conductor: Flexible copper conductor low voltage audio signal system
Operating Temperature: -15ºC to +70°C
Outer Insulation: PVC (Polyvinyl Chloride)
Signal copper cores: 20 x 0.12 mm
Signal Insulation: PE (polyethylene)
Copper Twisted Shield: 32 x 0.12 mm
Capacitance Cond./Shield: < 10 pF/decimeter
Conductor Resistance: < 10 mOhm/decimeter
Dimensions: 7 x 3 mm (rectangular cable)
Connectors: 1/4" 90º angled audio plug
http://www.fullcompass.com/prod/520471-EBS-Flat-Patch-Cable
« Last Edit: May 08, 2017, 12:03:33 PM by Elantric »
Offline Elantric
Warwick "RockBoard" low profile  1/4" cables
Description:
The new RockBoard patch cables are extra flat and space-saving. Designed to optimize pedalboard real estate, they feature a slim rectangular body and extra thin angled plugs, to keep your setup tidy and neat looking.
Features:
flat patch cables with rectangular profile
compact and super flat angled plugs
flexible copper conductor 20 x 0.12 mm
twisted copper shielding 34 x 0.12 mm
PE (polyethylene) signal insulation
outer PVC insulation
capacitance of less than 10 pF/decimeters
conductor resistance of less than 10 mOhm/decimeters
angled 6.3 mm mono audio plugs
operating temperature: -15º C to +70° C
outer dimensions cable (W x H): 7 x 3 mm (rectangular)
outer dimensions plugs (W x H): 12.5 x 7.5 mm
black
length: 5 cm (2")
« Last Edit: May 08, 2017, 12:06:00 PM by Elantric »
Offline Elantric
