Author Topic: MIDI Bass Pedal using Arduino and 3D printer for the keys  (Read 94 times)
Offline Piing
« on: April 26, 2017, 08:55:30 PM »
I have started this project. So far I have only printed one key, as a prototype for testing.
For MIDI control I will use one Arduino MEGA.
I am still unsure about the design of the box and how to attach the keys to the box.
I have posted the details on Thingverse.com:
http://www.thingiverse.com/thing:2277033 (it may not be available until they approve it because I am a newby on Thingverse)
Offline gumtown
Re: MIDI Bass Pedal using Arduino and 3D printer for the keys
« Reply #1 on: April 26, 2017, 10:47:58 PM »
Looks great !!
Are you going to use one switch per key and have fixed velocity, or 2 switches and have key velocity (one switch closes before the other and time measured between switches both closing determines velocity)
Offline Piing
« Reply #2 on: April 27, 2017, 01:24:03 AM »
Hi Gumtown. Thank you for the tip!! I didn't thought about making it velocity sensitive, but now I am going to consider it.
I didn't even knew that it is actually made with two switches!  :D
The mechanical part will be very easy, just setting two switches at different heights. I'll start modifying the 3D design right now (I am using OpenScad)
Micro-switches are very cheap. I've ordered 20 units for $2.79
http://www.ebay.com/itm/302026954222?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
What I don't know is if it will be so easy to implement the calculation of the lapse time between the 2 switches in Arduino.
So far my most complex experience with Arduino is this simple and ecologic MIDI controller for the Axe-FX:
https://forum.fractalaudio.com/threads/diy-axe-fx-foot-controller-for-50-open-project.119882/
I will dig deeper.
« Last Edit: April 27, 2017, 01:33:37 AM by Piing »
