Author Topic: Cliff UK - Audio DSP Digital Signal Controllers - Fully Programmable  (Read 193 times)
Offline Elantric
http://www.electronicspecifier.com/communications/audio-dsp-digital-effects-modules-are-fully-programmable
http://www.cliffuk.co.uk/products/digital/FM68033.pdf
Cliff Electronics UK announces the availability of its range of Digital Signal Processing Audio Effect modules. Cliff has been supplying components to the music and audio-broadcast industries since its foundation in 1977 and the DSP Digital Effects Modules increases their product offering to this growing market.
Four models are currently available, all of which are fully user programmable. For user convenience they also feature a range of built-in presets which can be modified if required. The entry point is the FM68030 Dual Sound Controller and its Professional version the FM68031, with the FM68032 Professional two input, four output sound controller and the FM68033 Professional Quad channel sound controller completing the range.
All models of Cliff’s DSP Digital Effects Modules are very cost effective and simple to incorporate into audio system designs. Key features include a wide range of digital reverb, echo and delay special effects, including: chorus, flanging, pitch shifting, spring reverb and emulation.
The DSP Digital Effects Modules are designed for use in musical instrument amplification and mixing consoles, these high quality products consist of PCB assemblies incorporating surface mounted components including custom designed CMOS LSI digital processors.
A number of programming methods are available as standard to simplify operation. These include programming from a PC utilising the supplied RC1 software which allows all characteristics to be fully programmable in real time and shown on screen and also via an Alpha-Numerical display using rotary encoders, momentary push button switches or potentiometers. Programming and control software is included with each purchase and a demonstration of the software is available prior to purchase for evaluation of the range of controls functions.
Where required in the end application function and parameter indication may be shown on LED Dot-Matrix displays, seven Segment LED Displays or 2x16 - 4x4Character LCD displays.
Typical applications Include; guitar, keyboard and entertainer amplifiers and combos, audio and powered mixing consoles, effects pedals, Karaoke systems and mono to stereo converters for surround effect enhancing.
John Hall, General Manager, Cliff Electronics, comments; “Our range of Digital Signal Processing Audio Effect modules increases our product offering to the audio industry where we are already recognised as an innovative and highly reliable component source. We have been supplying components to the music and pro-audio markets since 1964 and are always looking for new opportunities to grow our business in this global market.”
Cliff Electronics are market leaders in the design, development and manufacture of audio and power connectors, leads, test lead sets and accessories for a wide range of markets and supply major international OEMs. As a UK manufacturer Cliff are able to respond quickly to customer’s needs for both standard products and custom designs. Cliff manufactures audio, optical and power connectors and accessories, general industrial connectors, foot pedals, lighting connectors, terminal posts and connection blocks, motors, fans and assembly aids. Cliff can also provide a wide range of leads including test and instrumentation, audio, instrument and power.
http://www.cliffuk.co.uk/products/digital/dsp.htm
http://www.cliffuk.co.uk/products/digital/DSC-RC1-Program-Menu-Overview.pdf
Digital Speaker Control DSC2.2This new range is fully programmable and comes with range of built-in presets, which can be modified if required.
Designed for use in musical instrument amplification and mixing consoles, these high quality products consist of PCB assemblies incorporating surface mounted components. These include custom designed CMOS LSI digital processors.
Easy to build into your designs and very cost effective. Featuring a wide range of digital reverb, echo and delay special effects, including:
chorus
flanging
pitch shifting
spring reverb
emulation
Applications
Guitar, keyboard and entertainer amplifiers / combos.
Audio and powered mixing consoles.
Karaoke systems.
Mono to stereo converters for surround effect enlarging.
Please note these products are for OEM applications with a minimum order quantity of 25 for each item.
Samples are available on request.
DSP dimensions
Versatile Parameter Control Methods
Potentiometers.
Binary or Grey Coded Rotary Switches.
Momentary Push Switches.
Rotary Quadrature Encoders.
USART and SPI Interfaces.
USB Interface (no VCP).
Function and Parameter Indication Methods (if required)
LED Dot-Matrix.
7-Segment LED Displays.
Character LCDs 2x16 - 4x4.
« Last Edit: February 22, 2017, 05:01:17 PM by Elantric »
Offline philjynx
I am playing all the right notes. But not necessarily in the right order.
Online admsustainiac
Re: Cliff UK - Audio DSP Digital Signal Controllers - Fully Programmable
« Reply #2 on: June 18, 2017, 06:05:41 AM »
Sad but true
