Author Topic: Beagleboard - SEEEDSTUDIO Beaglebone Green Wireless board  (Read 315 times)
Offline admsustainiac
« on: November 04, 2016, 06:05:05 PM »
SEEEDSTUDIO Beaglebone Green Wireless board ($45) running embedded Linux and Linux Jack Audio should provide  a fast low latency USB Host to MIDI conversion
https://hackaday.com/tag/beaglebone-black/
https://hackaday.com/2016/09/27/new-part-day-wireless-beaglebones-on-a-chip/
https://groups.google.com/forum/#!categories/beaglebone/seeedstudio-beaglebone-green-wireless
http://www.vguitarforums.com/smf/index.php?topic=17561.msg133134#msg133134
Its a bit faster than Raspberry Pi solution here:
http://www.vguitarforums.com/smf/index.php?topic=11998.0
https://beagleboard.org/green-wireless
Processor: AM335x 1GHz ARM® Cortex-A8
512MB DDR3 RAM
4GB 8-bit eMMC on-board flash storage
3D graphics accelerator
NEON floating-point accelerator
2x PRU 32-bit microcontrollers
Connectivity
USB client for power & communications
USB host with 4-port hub
WiFi 802.11 b/g/n 2.4GHz
Bluetooth 4.1 with BLE
2x 46 pin headers
2x Grove connectors (I2C and UART)
Software Compatibility
Debian
Android
Ubuntu
Cloud9 IDE on Node.js w/ BoneScript library
plus much more
« Last Edit: April 20, 2017, 09:09:15 AM by admsustainiac »
Offline snhirsch
Re: Beagleboard - SEEEDSTUDIO Beaglebone Green Wireless board
« Reply #2 on: November 04, 2016, 08:12:34 PM »
In my opinion, Beaglebone is far less quirky than RPi.  My Fender Mustang bridge software runs on both, but I've had occasional slow response and USB glitches when using the Pi.
Offline Elantric
« Reply #3 on: March 10, 2017, 12:18:00 PM »
http://elinux.org/Beagleboard:BeagleBone_Capes
http://elinux.org/Impressx:Arduino_Shield_Adapter
The Shield I/O Cape provides the ability to mount (almost) every Arduino Shield on the BeagleBone Black, no matter if it’s using 3.3V or 5V logic levels. Changing from 3.3V to 5V is done by software. It can also be ordered with an onboard 16 pin I/O expander which is accessible over the I2C bus.
The Logic Supply BeagleBone EEProto Cape provides an easy workspace for creating protoypes. Through-hole solderpoints are spaced at 2.54mm (0.1") pitch. It includes two 46 pin headers (soldering required) and provides convenient SOT23 SMD IC's breakouts. The GND, 3V, 5V, SYS5V and P8-P9 trace banks are all clearly marked on the PCB for easy identification. NOTE: On the EEproto cape the BUS labelled SYS5V is connected to the external DC jack, and VDD5V is connected to the internal 5V. Prototype quickly with surface-mount EEProm pre-installed. Includes write-protect jumper and dip-switch for easy addressing. Has support for up to four capes Using available pass-through header pins.The Proto Cape works with both the original BeagleBone and the BeagleBone Black.
Specifications
http://www.streamunlimited.com/products/wifiaudiocape.html
Beagle Synth
Title: Beagle Synth
https://code.google.com/archive/p/beagle-synth/
beagleboard.org project: http://beagleboard.org/project/beagle-synth/
Short project description: DSP MIDI synthesizer based around the beagleboard
Homepage: http://code.google.com/p/beagle-synth/
Expected results: Initially a basic MIDI controllable subtractive synth with 3 oscillators, low pass, high pass, and band pass filters, 2 envelope generators, and 2 LFO's. From there the intention is to add some type of control surface (either physical controls or perhaps a touch screen), some effects (phaser, distortion, reverb), and perhaps other types of synthesis options (FM, additive, maybe some type of patchibility). The result will be a fully featured MIDI instrument comparable to many commercial synths. This project is to be a learning experience with the intention of exploring using DSP for music synthesis. As of now this project is in the concept phase and is still in need of hardware for implementation.
Contact: dpanseri [at] gmail [dot] com
« Last Edit: March 10, 2017, 12:19:43 PM by Elantric »
« Last Edit: April 20, 2017, 03:47:12 AM by admsustainiac »
Offline snhirsch
« Reply #5 on: April 20, 2017, 05:43:30 AM »
It can be a pitched battle disabling all the cutesy development interfaces and web services for embedded use.  Here's a helpful thread:
https://groups.google.com/forum/#!category-topic/beaglebone/seeedstudio-beaglebone-green-wireless/NCowLviCWtc
